Mo*or Mo**h
Power Steering....pumping iron
Well, put off too long replacing that power steering belt.
Today it finally gave up. Now, I'm trying to drive without power steering. Real workout. New appreciation. It's o.k. on the highway, but just getting out of the driveway is a real chore, essentially unsafe, too. So, guess what I'll be doing this weekend? On the bright side, and the reason I decided to post, there's a very significant gain in pep from the old horse. It makes me wonder how much of a drag the PS pump actually is on the engine. Is the PS pump spec'd to some required HP or torque requirement of the engine to which it is attached? I'm pretty sure there's at least a 10-20 HP gain without that belt. btw, it broke at that instant when I was getting scratch out of 2nd on an expressway ramp. The steering torqued so hard I almost lost it. More than it ever had due to the gain in power after the belt snapped.
Stock 1987 Legend LS Coupe 180k (11/07) |
Wowoweeee
Love the thread title KAHruzer and yes, I can relate to that
...you've got my attention on that HP gain w/o the PS pump drive belt?!?
293K+ miles; original power/drive trains |
Legend driver
Hmmmm. This is interesting. Could I cut my ps pump belt to improve the MPG on my car? I can see how driving without power steering could be somewhat dangerous. Is there any harm done to the car if you manually steer a non-working power steering system? Anyone know if Legends ever had the option for non-power steering?
No.
While the PS pump IS always "pumping" when the engine is running, it's not actually doing anything when you aren't turning. When you turn the wheel, passages in the rack open and route the fluid to push against certain parts within the rack, left or right, respectively. When cruising, AKA going straight, the pump is hardly doing any work at all, not draining the engine at all. On top of that, it's bad for an automatic steering system to be driven like a manual steering car. There's a pencil thick torsion bar within the steering rack, and without fluid pressure, you put a lot of strain on that bar. You can feel through the wheel just how hard it is to turn, now imagine all that force on a pencil thick metal bar. Ker-snap? Yes. If you're "feeling" an HP gain from your PS pump being disengaged, then there are one of two things happening: 1) You have some form of resistance within the pump itself that is causing friction and fighting the engine. 2) You've established a placebo effect and your butt dyno is agreeing. As far as a Legend without a power steering option? It's an Acura luxury car. What do you think? |
#8 (permalink) | |
To answer your remaining question, all Legends came standard with power steering. I like the butt dyno concept, though I'm pretty sure that mine needs recalibrated as it picks up 5hp when I give it bath.... |
Legend driver
Thanks for the input, fellas. If it wasn't going to damage the car, I would consider cutting the ps belt, just to see what kind of change in MPG might result. But since it can cause damage, I won't do it. Small cars are not too bad without power steering. I hear you though on that XJ6. That thing is a beast.
Would love to see some photos of the XK-E, sometime. Those are very, very special cars. |
#10 (permalink) | |
Mo*or Mo**h
It does kind of make me scratch my head because there is a noticable difference. I'm not that crazy. My PS pump has been making one of those "Push-Chew" noises in recent months which led me to believe it on the way out. Might even explain the belt problem to some degree. So, it's entirely possible the pump was actually producing drag when none is normal. Then again, the system does need to pressurize upon start, I'd imagine. That noise did eventually dissipate. How long that process normally takes may be a question because mine did take several minutes. And, this event did occur within minutes of startup, but was shortly after another run which had the car warm. Don't know, but it still feels light on its' feet without the belt. Haven't done the work yet due to weather. I've almost acclimated to the steering, which is only really hard when the car isn't moving. At highway speeds, it's normal. I think they actually refer to this as "power assisted" steering, meaning it only works at low speeds and backs off as speed increases.
^Again, at high speeds, how much are you really turning? Maybe moving the wheel a few inches at most? And since the tires are rolling, the effort needed to move them is minimal.
It also sounds like your pump is faulty and would need to be replaced. I'd be willing to be that if you did and replaced the belt, you'd still notice the "new" pep. |
Legend driver
I am in the process of finding out the expensive way (from my mechanic) that the power steering in the G1 Legends is actually "variable assist". The system provides more assistance at low speeds, and virtually no assistance at higher speeds. How does it know what speed you are traveling? Well, come to find out that the power steering system has a fluid line that passes through the VSS (vehicle speed sensor), and that has some kind of valve in it that regulates the pressure in the line. Trust me, you don't want to find out what replacing these parts costs. It's a friggin small fortune.
rising chuckmaster
as a joke, one of my co-workers released all the air in my car a few days ago and i had to drive to the gas station to fill it up again. that wasn't fun, especially getting out of the lot. hope you get that fixed soon man!
#14 (permalink) | |
BTW, the VSS was next to nothing at the junkyard, but putting it in is a little tricky. There are a lot of vacuum connections in the way and you have to avoid snapping any off. Plus the housing is made of pot metal, and it is real easy to snap the mounting tab off if you over-tighten it.... |
