Old 07-06-08, 11:50 AM   #1 (permalink)
fred clark's Avatar
Car 1: 1987 acura legend
QUESTION: Power Steering Fluid leak
Vehicle: 1987 Legend L
I check my fluid levels almost every day before starting the car in the morning; I also park the car over a piece of cardboard so I can monitor changes in oil leaks, etc.
Recently, I have begun to notice that after using the car most of the day in running errands (about 25-30 miles), the following morning my PSF reservoir
is down about 1/4"; also there is at least one dime-sized spot of PSF on the cardboard located on the left side (driver) of the vehicle, about mid-engine.
With all the plumbing in the engine bay and the undercarriage plastic below, I can't see from where the leak is occurring.
Question:
From where do these leaks generally occur?
Has anyone recently diagnosed the same problem?
What was your repair?
Is this just normal old age or a more serious problem?
Thanks as always.
1987 Legend L
Auto 4DR Sedan
156,000 miles
Extremely ugly exterior, badly in need of paint.
When we have a martian in the White House, I might get around to it.
fred clark is offline
Old 07-06-08, 12:38 PM   #2 (permalink)
kR@zYm@N's Avatar
Car 1: 1988 Legend LS Sedan
Car 2: 1987 Chevy S-10 POS
Car 3: Size 12 Shit Kickers
My 88 sedan started the same way. Could be 2 possible items. Either high pressure lines between pump and rack & pinion, or the rack & pinion itself. Mine ended up being, lucky me, the rack & pinion. Rebuilt rack was about $225 and labor was about $325...however, I had them replace upper arms, lower ball joints, outer tie rod ends (inner tie rod ends were included with rack) just a rack might be cheaper. Make sure whoever looks at it looks real close as to not overlook a line in addition to the rack. Hope this helps, although bad news it might be.
By the way, I've heard mixed feelings about it so you might want to ask around...Lewis Power Steering Sealer. Heard from some it's the best thing since sliced bread, but due to Honda specific fluids, I've heard other say no way. Haven't tried it myself, so I can't vouch for it either way.
Good luck and keep it alive.
Daily Driver with Custom CAI w/ K&N Cone, Intrax Springs, APC Budget Front Strut Bar, Addco 3/4" Rear Anti-Sway Bar (SOON!!!).
Bolt on for Autocrossing:
Drag DR-19 17x7.5 Rims with Falken Azenis RT-615 225/45ZR17
More images of my ongoing project and Auto-X follies can be found at http://flickr.com/photos/onsitegeeks/
kR@zYm@N is offline
Old 07-06-08, 12:40 PM   #3 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
Have you tried having someone turn the wheel lock to lock while you take a look at all the components? That might just reveal to you where the leak is...
sam o nela is offline
Old 07-07-08, 10:36 PM   #4 (permalink)
Mo*or Mo**h
KAHruzer's Avatar
Car 1: 1987 Legend LS Coupe
I just blew out the HP hose on mine. It started as a drip, then dribble and expanded over a week or so to uncontrollable.
I'm waiting on a part now, but it's supposed to be here tomorrow.
Thought I'd successfully patch the original leak at the seam of the 2nd steel fitting from the pump. But, that seemed to create new problems. It's like the hose material is disintigrating. Patch one place, pops another leak elsewhere.
Doesn't seem quite normal.
BUT, about February, I put some AutoRX in the power steering reservoir to run awhile. Don't drive much so it's been in there about 4 months now, at least before the leaks caused refills every day. Wondered if it rotted my hose somehow.
Probably shouldn't have left it in so long, but was working along the 1500 miles spec. Like I said, I don't drive much, 100 miles a week or so. It's just now at the mileage for changing.
Anyway, I'd bet on the hose rather than the steering box. But, it could be either. If it's the hose, it's going to get worse in a hurry.
KAHruzer is offline
