Old 07-03-07, 05:15 AM   #1 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
radiator fluid
anyone knows any good fluid for the legends? i pretty much like the acura kind, but is there anything better?
l4zy415 is online now
Old 07-03-07, 07:46 AM   #2 (permalink)
Eh...What up Doc
Xcaliber003's Avatar
Car 1: 1989 Acura Legend LS 4Dr
Personally I would stick with the honda/acura brand antifreeze because it doesn't have a chemical called silicate(?) in it. Honda engines also use softer seals than other engines so antifreeze with silicate(?) in it would wear the seals out quicker. That could cause big problems like a leaking water pump, leaking gaskets, etc.
"love em all,trust a few,and fear none". . .Mos Def
"Don't look at your car as it is now, see it the way it'll be when you're done fixin it up."
Xcaliber003 is offline
Old 07-03-07, 09:25 AM   #3 (permalink)
Peak Long Life and Peak Global Long Life are silicate free coolants.
'87 L-Coupe 5-Speed
Stock; NO Mods
392K Miles - original engine and drivetrain.
paulo57509 is offline
Old 07-04-07, 01:21 PM   #4 (permalink)
Wowoweeee
pnoye2's Avatar
I've used Prestone antifreeze/coolant to all my vehicles and have yet to run into any problem(s) with them... I just follow the scheduled change intervals and they seems to work.
291K+ miles; original power/drive trains
pnoye2 is offline
Old 07-05-07, 07:26 PM   #5 (permalink)
Car 1: 1990 Acura Legend L Coupe
What about Prestone? Do they have silicates in them?
Mouse is offline
Old 07-05-07, 11:10 PM   #6 (permalink)
Yes, Prestone does. You can read the labeling on the back of the container.
'87 L-Coupe 5-Speed
Stock; NO Mods
Old 07-05-07, 11:29 PM   #7 (permalink)
I have a .pdf of a Honda Service News bulletin regarding coolant containing silicates. I'd attach it but it's too large a file.
Maybe this will work:
FWIW, not counting the initial factory fill of coolant, my Legend has had nothing but Prestone in it between 59,694 miles (9/20/1989) and 293,590 miles (6/9/2001). That's 233,896 miles. Within that time, the car has had two water pump replacements. Not because they were bad, but replaced along with the timing belt.
I doubt that silicates affects water pump life to any significant extent. I will say that it did lead to a plugged radiator; engine temps would climb when driving up steep grades at highway speeds. The original radiator lasted 320,460 miles before I replaced it with a new one.
As long as coolant containing silicates is replaced BEFORE it gets old enough to where the silicates come out of suspension (meaning regular flush and fills), Prestone is fine. That white crusty stuff you see in neglected cooling systems.....that's silicate.
'87 L-Coupe 5-Speed
Stock; NO Mods
Old 07-06-07, 01:09 AM   #8 (permalink)
Oh my god.
All this time I went with the most expensive brand name and thought I was actually being good to my car. And yes you are so right, I do find that slimey white stuff in my system also.
Tell me, is it all right to mix Prestone with Peak or the Honda antifreeze because when I drain and refill, not all of it will be flushed out?
Mouse is offline
Old 07-06-07, 03:13 PM   #9 (permalink)
Oh my god.
A little mixing is probably OK, but I wouldn't mix the two. Reason being that silicate and non-silicate coolants use different corrosion inhibiting mechanisms and the two aren't rerally compatible. One inhibiting mechanism might hinder the other, then you'll be left with marginal protection.
You need to not only drain the radiator, but open the engine block drains too (be environmentally aware.....catch the drainage in a bucket or pan. Don't let it go down the sewer).
Close the drains and refill with water only. Let the engine idle until the cooling fans cycle twice. Drain. Repeat this until the water comes out clean. Run the heater full HOT when you run the engine.
After the final drain, you can now run whatever coolant you want.
If you're worried that you can't get all the clear water out of the system, take the total capacity of the cooling system, calculate how much coolant you'd need for a 50/50 mix, add that amount of coolant and top off with water.
BTW, for the final fill, I'd use distilled water.
'87 L-Coupe 5-Speed
Stock; NO Mods
Old 07-06-07, 10:59 PM   #10 (permalink)
89HondaLegend's Avatar
Car 2: 1989 Honda Legend
I am not keen on spending money for 'Honda' products. But being on this forum for a couple of years I have learnt three things.
Use only Genuine Honda Coolant, PSF and ATF.
I got water in mine at the moment because my top radiator hose burst a while back and I couldn't afford the Honda coolant lol.
I don't want to get any just yet because my bottom radiator hose and all those other little water hoses are definetly in need of replacement.
Regards,
Steve
Love to Love the Legend
Pictures of My Legend
89HondaLegend is offline
Old 07-08-07, 06:38 AM   #11 (permalink)
Thank you for the excellent instructions.
Mouse is offline
Old 07-09-07, 12:07 AM   #12 (permalink)
L*v da* Legend
Car 1: 90L Blue Sedan
Silicate free and a nice additive like Purple Ice helps.
http://www.royalpurple.com/prodsa/prpice.html
Chomot is offline
Old 07-11-07, 02:47 AM   #13 (permalink)
Wowoweeee
pnoye2's Avatar
^^^ this I've yet to try, ALL of my 50/50 mix is just common tap water... I use distilled water for my battery, but if you dont mind me asking; what are the advantages of substituting from plain old tap water to distilled water, less minerals?
pnoye2 is offline
Old 07-11-07, 01:24 PM   #14 (permalink)
Yes, less minerals. I live in an area with "hard" water. I wouldn't want all that crusty stuff in the cooling system.
For less than a $1 a gallon for distilled water, I think it's a much better alternative to tap water.
'87 L-Coupe 5-Speed
Stock; NO Mods
Old 07-11-07, 02:37 PM   #15 (permalink)
Wowoweeee
pnoye2's Avatar
Thanks paulo ...I'll try that on my next coolant flush!
pnoye2 is offline
Is it risky to temporarily use water instead of radiator fluid? 88legendMaroon First Generation Legend (1986-1990) 6 10-02-04 04:12 AM
HELP ID => black hose w/radiator fluid behind drive belts 88legendMaroon First Generation Legend (1986-1990) 2 10-01-04 01:41 PM
My radiator leaked hella fluid today jose3030 Second Generation Legend (1991-1995) 2 03-10-04 11:27 AM
radiator fluid leak firestorm First Generation Legend (1986-1990) 10 08-06-03 01:50 AM
HELP-Steps in changing radiator fluid? Dawk Second Generation Legend (1991-1995) 0 03-27-02 12:42 PM
