Old 09-27-07, 04:11 AM   #16 (permalink)
Car 1: 88 Legend Coupe
Honda charges $18 for a gallon of coolant premixed at 50/50.
Ripoff!
That means to flush and refill I gotta buy two gallons and pay $36 bucks.
They dont even sell undiluted coolant so that means you gotta add extra coolant to flush out the water so you dont end up with a mixture below 50/50.
Any bright ideas on where to buy this shit cheaper?
happygomez is offline
Old 09-27-07, 04:19 AM   #17 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
its best to flush your system with water. leave the drain plug open and run the car. just use your water hose to keep filling the radiator. thats what i did to drain my shit. my coolent was out and all i could see was clear water coming out of the radiator. when the car is pretty much hot. turn off your vehicle and stop pouring water into the radiator. that way most of the water can come out with the thermostat open. Then just refill it with the honda radiator fluid. bleed it so air won't be in your system. mine works perfectly. i did this a couple of months ago. i dont have any problems yet.
l4zy415 is offline
Old 09-28-07, 04:20 AM   #18 (permalink)
Ken
aka desired_speeds
Ken's Avatar
Car 2: 91 Legend L - parts
Car 3: 96 Honda Saber 32v
Send a message via AIM to Ken
I did mine a while back with Prestone. Filtered water with 50/50 coolant.
I took the thermostat, radiator drain plug, and top radiator hose off and ran tap water through it all until it was fully clean, then I bolted everything back on and filled it with the coolant/water.
. k e n
Ken is offline
Old 09-28-07, 05:49 PM   #19 (permalink)
489,000 km's stil going
TO90LEGEND's Avatar
Car 1: 90 Legend V6L
Car 2: 93 Indy P/C Camaro
Car 3: 83 Trans AM
How do you all get rid of the old antifreeze?
TO90LEGEND is offline
Old 09-28-07, 07:01 PM   #20 (permalink)
take that; take that
pnoye2's Avatar
Call your local garage. Not the auto parts store, but the service station, and ask them directly about recycling the radiator fluid.
pnoye2 is offline
Old 09-28-07, 07:33 PM   #21 (permalink)
Thumbs up
If your coolant is not contaminated with oil, you should be able to just flush it down your toilet (but not the street drain). Coolant is largely water and alcohol and bacteria in the sewer love this stuff...
legendvr is offline
Old 09-28-07, 07:39 PM   #22 (permalink)
legend89chopped's Avatar
Car 1: 89 Legend Convertible
Car 2: 93 Legend LS 6-Speed
Car 3: 89 Parts Coupe
Honda fluid is always best. Here's a tip when draining-there are two water jacket drains on the engine, and they look like bleeder fittings. You can only see them from underneath, and they are located under the middle cylinder on each bank. Crack those open when you drain the old fluid, or you'll never get that stuff out. Even when you flush the system, it doesn't get that water jacket area very well. Leave 'em open while you flush water or a flushing solution through to make sure you get it real clean. Just remember to close them back up, obviously.
Dang Bro!! Looks SICK!! I wish I had the guts to cut my junk like that..
...foreskin?
legend89chopped is offline
Old 09-30-07, 03:45 AM   #23 (permalink)
Spiral descent
telafonic's Avatar
Car 2: KA7_8 SWP 6-speed
Car 3: 1996 A6
The impression I have kind of gotten over the years is that the G1's are much more tolerant of different brands than the G2's are. Even though I've had temperature issues with my G1 in the past, I don't believe they were due to the brand of coolant, as much as improper maintenance by the previous owner.
Last time I talked to my knowledgeable Acura parts guy, he said that Acura doesn't recommend flushing the coolant. A simple drain and refill is all that is needed unless the coolant looks really bad.
Ripoff!
Not quite sure why it's more expensive there. I paid about $12 for a gallon of premixed 50/50 solution. I didn't think Honda was even selling non 50/50 coolant anymore. I would call around or double check on that.
telafonic is offline
Old 12-20-07, 12:37 PM   #24 (permalink)
VIP Premium Member
VIP Legend's Avatar
Car 1: LEGEND 2door Hardtop V6 2700 = Driver's Prestige Super LEGEND!
I doubt the validity of this statement.
VIP Legend is offline
Old 06-26-08, 05:59 PM   #25 (permalink)
Car 1: 1990 Legend Coupe LS, auto
Hi, I'm a noobie. I've been lurking on the site for about 4 years and have always found the info I needed so I never had a reason to join and post.
Now that I've got some time, I joined and wanted to reply to the use of distilled water in the radiator.
My dad is an engineer on a Navy base and he has a chemical engineer coworker that uses tap water with his coolant. He said distilled water would could corode your motor more than tap water. The reason is that water likes having mineral type things in it. And if you take them out, it wants to get them back so it will take them from your aluminum insides though corrosion.
I like the idea of filtered water best. My tap water is full of mineral crap. Its so bad, one time we had a leaky tub faucet for about half a year and the drips would spash onto the side of the tub and dry. There was a layer of white mineral stuff by the time the leak was fixed. I used CLR and it came off in thin sheets. I definately don't want that stuff in my engine. I think my Britta filter gets most of it out because it plugs up about every 3 months.
PS By the way, I've got a 90 LS coupe . 170K miles. Works great and its worth investing money into when it needs it which I couldn't say for my 94 Mazda MPV...THAT vehicle was waste of earth's resources.
Legendo is offline
Old 06-26-08, 06:14 PM   #26 (permalink)
l4zy415's Avatar
Welcome, thats some good advice about tap and filtered water. Also, we gotta see some pics of your ride. Enjoy your stay here.
l4zy415 is offline
Old 06-26-08, 06:42 PM   #27 (permalink)
Got Legend!
jmoser1981's Avatar
Car 1: '89 Acura Legend L (5speed)
Car 2: '02 Durango R/T
Me too, I will use distilled water...
I have no idea what they(the shop) put in when they changed my water pump a few months ago
MY GAS HOG
jmoser1981 is offline
Old 06-29-08, 03:41 AM   #28 (permalink)
Cool
Why?
Unless the tap water already has aluminum in it at saturation concentration, it will still "take" it from the engine block. That is precisely why coolant contains inhibitors - substances that have lower half-cell redox potential than your metal block alloy. So these substances oxidize before your block does.
Tap water these days is, typically, basic (pH ~8.5) to protect pipes from corrosion. It probably won't harm your engine block, but may do harm to rubber seals.
Purified water is pH~6 because of dissolved carbon dioxide. Carbon dioxide exists in equilibrium with carbonic acid in water and does cause corrosion. However, the amaizing chemical engineers at Prestone also know this and that is why coolant has inhibitors to protect the metal block. Also, the solubility of carbon dioxide is very small in water-alcohol mixture (ever tried to mix fizzy water and vodka??).
So, in general, because you don't really know what ions are exactly in your tap water without elemental analysis, I would use purified water instead.
Take it from a chemical engineer.
legendvr is offline
Old 06-29-08, 11:10 PM   #29 (permalink)
Thanks Dr. Chem, that settles it for me. I guess the dilemma boils down to what water to use for rubber seal protection.
Legendo is offline
Old 06-30-08, 01:34 AM   #30 (permalink)
pnoye2's Avatar
I'd follow the manufacturers recommendation, it has work for me so far ...but you can't argue with a Chemical Engineer
pnoye2 is offline
Is it risky to temporarily use water instead of radiator fluid? 88legendMaroon First Generation Legend (1986-1990) 6 10-02-04 05:12 AM
HELP ID => black hose w/radiator fluid behind drive belts 88legendMaroon First Generation Legend (1986-1990) 2 10-01-04 02:41 PM
My radiator leaked hella fluid today jose3030 Second Generation Legend (1991-1995) 2 03-10-04 12:27 PM
radiator fluid leak firestorm First Generation Legend (1986-1990) 10 08-06-03 02:50 AM
HELP-Steps in changing radiator fluid? Dawk Second Generation Legend (1991-1995) 0 03-27-02 01:42 PM
