If you have a Coupe, the ECU is located on the passenger foot well. You'll need to pull back the carpet, then you'll need to remove the cover to access the ECU.
If you have a Sedan, its under the passenger seat. Place the key in the ON position (engine not running), then you should be able to see a red light blinking. Count the blinks and let us know what the code is.
If there isn't any code, where is the RPM needle staying at when neutral? Does it feel like the gas pedal is sticking?
