Speedometer Cable Replacement - Page 2 - The Acura Legend & Acura RL Forum
Old 12-13-03, 03:21 PM   #16 (permalink)
Car 1: 93 Legend LS 4 DR Auto Geneva Green Metalic
Send a message via MSN to smth_hckr
make sure your indiglos are pressed flat against the guage face, and that there are no gaps. If they stick up even a little, the needles can rub against them and get stuck.
Old 12-21-03, 02:13 PM   #17 (permalink)
Car 1: 1989 Acura Legend L
Send a message via AIM to Dynamic_Stylez Send a message via Yahoo to Dynamic_Stylez
speedometer
thx man i did what you said pressed them down flat no gaps nothing. But i put my gauge cluster together and i start to go down the road i check my speedometer it was fine for like 15mins
then i hit a red light soon as it turns green i take off normally then i check again and its stuck on 20mph so i go a little faster and it jumps to 40mph and gets stuck i dont understand could this be my needle or my upper and lower speedo cables i really hate it when you dont no what speed you are going please help!!!!! Stylez out
Dynamic_Stylez is offline   Reply With Quote
Old 12-24-03, 03:24 AM   #18 (permalink)
Qualified Driver
90Legendman(LS)'s Avatar
Car 1: 90LS Sedan
Car 2: 07 Suzuki GSXR 600
Originally posted by chuckee98
I paid $ 29.50 for a speedo cable set from A&H motorsport , which included both the upper and lower cables. Most people have issues with the upper, but since it was cheaper to buy both rather than just the upper (don't know why, doesn't make sense), I bought the set. I was only going to change the upper, but decided to get over my laziness and do both. The lower is a pain because of trying to get the end seated properly into the transmission, and then get that %$^#%*^% clip into place, and then the %$#*&%$ rubber boot over it without popping the clip off. All in all, it was a relatively easy job, and it fixed my bouncing speedo with all that racket in the cabin.
So that little noise coming from the cluster is the speedo cable right? like a buzzing sound and my speedo is woobly..
90 LS Sedan
90Legendman(LS) is offline   Reply With Quote
Old 12-24-03, 04:18 AM   #19 (permalink)
Car 1: 1989 LS Coupe
yup.
chuckee98 is offline   Reply With Quote
