Stainless Steel Brake Line Failure
In the ongoing debate between stainless steel braided lines and oem rubber lines, we always said no one had ever had a stainless steel line fail, until now. My right rear line broke internally (the shorter of the two) and I ended up with no brakes. Here's the kicker... the lines are about 4 months old! I'm in the process of getting a replacement (they have a lifetime warranty) but am wondering if it's something to do with the braiding that caused premature failure?
As a temporary fix, I limped to the junkyard with a combination of engine braking and e-braking in hopes that I could find a G1 coupe to cannibalize. Unfortunatly there were no G1s ( ) but there were a number of G2s... The place was about to close so I snatched a rear line from a '93 G2 sedan, and I was very lucky to find out that it fit perfectly (it's a lot longer than I needed but the fittings are exactly the same). Should do until I get a replacement...
SOLD: '87 Auto Sedan (12/31/2003) |
For anyone installing or planning to install braided hoses for any type of service (brakes, cooling, luberication, etc.): you just can't slap on a replacement set of braided hoses and drive down the road. There are other considerations that need to be taken into account. C&P the link:
http://www.holley.com/data/Catalogs/Earl's%20Technical%20Info.pdf Pay particular attention to Page 13.
'87 L-Coupe 5-Speed Stock; NO Mods 393K Miles - original engine and drivetrain. |
Page 13 on that link you provided is what I think may have caused the premature failure, in particular the section about bend radius. The second short hose from the caliper to the steel line (the one that failed) has quite a tight bend and the excess strain is probably what caused it to tear. I'm not sure if the OEM lines are molded differently but the lines I bought were all straight and required quite a bit of force to bend/secure tightly.
Legend driver
When a brake line ruptures, don't you still have brakes on 2 wheels? I thought that there were 2 separate fluid circuits in the master cylinder: one for the front left and rear right and the other for the front right and rear left. Is that not true?
I've had brake lines break on me three times... Once on my '87 and now twice on my '89. Each time I lost almost all braking because the fluid in the master cylinder drained out. I say almost because if I did floor the pedal, I did get a minimal amount of braking and the car did pull to the right supporting the independent system idea...
Legend driver
I'm wondering if your master cylinder is working correctly, or if there is possibly another problem on your car. I wrecked my 72 Cadillac when I blew a front brake hose (long time ago). I was driving the car with one of the brake circuits already failed (I didn't know this at the time). When the second line ruptured, I had no brakes and crashed into a car ahead of me. I was told that if the first brake circuit hadn't already been dead, then this second rupture would not have caused a complete loss of braking. Just something to think about.
VIRGIN
Alls I know is... oem rubber lines ftw!
=p. That's scary though, I'm glad you're alright. I experienced a similar pull to the side when my master cylinder went out, and then again when my brake lines went out after replacing the master cylinder. |
Find Em Fuck Em Forget Em
If he didn't realize his brakes were out quite quickly, he probably lost so much fluid that the whole system went to shit. I've lost a caliper before and still had brakes as long as I pumped the pedal to get stopped, the first time.
You know how solid brake lines are usually looped and bent in seemingly senseless ways before connecting to the master cylinder? This is to help take the chassis flex stress off the lines and distribute it over a larger area. As far as PTFE SS braided line, most people think the stuff is indestructible, but it isn't. That's a great link! If you don't secure the line itself it can wear a hole in whatever it rubs against as well. I've had it rub through a valve cover, because I didn't know any better.
3.5RL With/Without Nitrous Comparo Video |
Personally, I wouldn't put ss brake lines in any of my cars. Even though they may last longer there is no easy way to inspect them to make sure they need to be replaced. SS brake lines also have a tendency to epicly rupture and eliminate all braking power in the vehicle.
_______________________ I don't know if it's just me, but I can't help but giggle a bit when people refer to transmission fluid as tranny fluid... |
#11 (permalink) | |||
VIRGIN
You lost an entire caliper?! That sounds quite precarious haha. Quote:
I think that's probably the most common belief about SS lines... |
33mpg 6spd Coupe
I have been toying with the idea of having SS Brake lines made by slipping SS sleeves over rubber lines. It would add the SS expansion resistance and blingyness to the rubber lines.
Someone stole maracura91's new wheels one day after he bought them. (10/09/2008) This link will search for "Nitto" + "C2" + "Racing Hart" on all of craigslist for the last 24 hours. Click it to help him find his wheels! maracura91's thread Inflation is your friend! I mean really, who doesn't want to own a $100,000 car? |
#13 (permalink) | |
just a thought
I'm Parting out TWO Black/Black Sedans. MANY MANY Parts available. PM me. SELLING MY 94' GS http://www.acura-legend.com/vbulleti...ck-tan-128046/ 94' Acura Legend GS -158k Miles, Timing Belt DONE, Head Gasket: DONE, Tail Light Red-Out: DONE, Tint (35%): DONE, Viper Remote Start/Keyless Entry DONE Progress Thread<Update! 6/12/08 Future: 2 8" JL Subs+Amp, Ashtray Ipod Dock/Sunroof Tilt DIY |
