Old 05-06-08, 01:55 AM   #31 (permalink)
Muffo's Avatar
Car 1: 88 ADM coupe
Car 2: 88 JDM coupe
Car 3: 87 coupe
Do you know if they were made in japan its my most wanted thing but no good to me in miles
Muffo is offline
Old 05-06-08, 03:37 AM   #32 (permalink)
Eh...What up Doc
Xcaliber003's Avatar
Car 1: 1989 Acura Legend LS 4Dr
BUT there is a button that lets you change measurements from miles to kilometers. Truly an international gadget.
"love em all,trust a few,and fear none". . .Mos Def
"Don't look at your car as it is now, see it the way it'll be when you're done fixin it up."
"ridin down the block like what else should a brotha do."
Xcaliber003 is offline
Old 05-06-08, 04:34 AM   #33 (permalink)
Muffo's Avatar
Car 1: 88 ADM coupe
Car 2: 88 JDM coupe
Car 3: 87 coupe
really? ok well i gotta get me one from over there
Muffo is offline
Old 05-07-08, 02:20 AM   #34 (permalink)
What you crave.
WhtCastle's Avatar
Car 1: 1990 Acura Legend LS Coupe 5-Speed, 2001 Jeep Grand Cherokee Limited
Thanks guys!
To which are you referring? The coolant reservoir or the coolant temp?
The reservoir wire is ready, just needs to be hooked up (but it checks out as okay for now so I dont get a CEL ) and the coolant temp simply splices into the wire that goes to the temp gauge on the cluster....it does some kind of monitoring, but it doesnt tell you the temp readings or anything (which would actually be really cool!!).
Maybe I should try grounding out my temp gauge to see if it gives me some kind of warning
I was talking about the res; I wasn't aware it noted on the temp as well. (Probably a good thing I am unaware of it - car has not ran hot.)
WhtCastle is offline
Old 05-07-08, 10:43 AM   #35 (permalink)
Originally Posted by guyad View Post
It was only an option for the L coupe
It was standard equipment on "L" coupes in '87.
'87 L-Coupe 5-Speed
Stock; NO Mods
394K Miles - original engine and drivetrain.
paulo57509 is offline
Old 05-07-08, 10:49 AM   #36 (permalink)
Just a quick update...I fixed the MPG calculator problem....lol tapping into the clutch switch wire instead of the #1 injector wire will give you ENORMOUS mpg gains btw!!! It works perfectly now!!
Also, I was able to get it to think that engine oil was low, and guess what! It threw me a PGM-FI light (thats a Check Engine Light for the rest of you) and the info center told me "Check Oil Level"!! Nice!!! After grounding it out, the warning and the PGM-FI light went away...yes...this technology is definitely ahead of its time!!
The oil level sensor is in the crankcase (you have to drop the pan to get to it) and the electrical connector exits out thru the oil pump/cooler plate. I would bet that the hole for the connector is there.
BTW, the box mounts under the dash above the glove box. I'm wondering if the mounting holes are there.....
'87 L-Coupe 5-Speed
Stock; NO Mods
Old 05-07-08, 11:12 AM   #37 (permalink)
Mr. X (aka #5)
IkeRay's Avatar
Car 1: 1997 BMW 528i
Car 2: 1994 Accord Sedan EX
Car 3: 1987 Legend Coupe
I'm wondering the same...
IkeRay is offline
Old 05-07-08, 12:43 PM   #38 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
Sadly, the answer on my car is a resounding "no" on both points.
My 87 has a different design dash than you guys and the computer will not fit in the same location as yours (under the dash, above the glovebox), there is just not enough space....hence why it must go behind the console....the DIY will address this.
Also, perhaps MAYBE something might exist on 2.7's for the oil level sensor, but when my 2.5 engine was available, the info center was still but a gleam in Honda's eye....so I'm pretty sure existing knockouts and unused mounting hardware are nonexistent....
Same story for the Auto climate conversion (coming soon ).....you guys have knockouts and stuff available that I do not....oh well...I just have to get creative is all
sam o nela is offline
Old 05-07-08, 11:16 PM   #39 (permalink)
I wonder if a 2.7 oil pump with the knockout would fit a 2.5?
'87 L-Coupe 5-Speed
Stock; NO Mods
Old 05-15-08, 08:17 PM   #40 (permalink)
190k n lifters ticking.
Car 1: 1989 L sedan.
Car 2: n/a
Car 3: n/a
sick. did it require a lot to convert a clock into a freakin legend genie??? i seen one at the junkyyard when i picked up a new gas door and front lip (yay) and was wondering if it was worth the pull.
n0rcal2wheeler is offline
