Technical Service Bulletins - Page 2 - The Acura Legend & Acura RL Forum
Old 05-30-05, 10:10 PM   #16 (permalink)
Car 1: 1989 legend coupe
February 1, 1999
Creaking Noise While Turning
(Supersedes 92-009, dated February 7, 1995)
** Indicates updated information **
Black bars in illustrations indicate updated information.
SYMPTOM
A clicking noise is heard while making right or left turns at 10 mph or less.
PROBABLE CAUSE
^ Worn outboard driveshaft joint.
^ The outboard driveshaft joint boot has split, allowing contamination to enter the
** CORRECTIVE ACTION
Replace the noisy outboard driveshaft joint. **
WARRANTY CLAIM INFORMATION
In warranty:
The normal warranty applies.
Out of warranty:
Any repair performed after warranty expiration may be eligible for goodwill
consideration by the District Technical Manager or your Zone Office. You must
request consideration, and get a decision, before starting work.
Defect code: 042
Contention code: B07
Failed part: Use the replacement part number
Skill level: Repair Technician
PARTS INFORMATION
** Refer to the Parts Catalog or Parts Information Bulletin 95-0004 for the appropriate
outboard joint kit application and part number.
REQUIRED SPECIAL TOOLS
Threaded Adapter:
T/N 097XAC-001010A; 22 mm
T/N 07XAC-001020A; 24 mm
T/N 07XAC-001030A; 26 mm **
DIAGNOSIS
(Driving Method)
1. Drive the car in a circle in an open parking lot at approximately 10 mph with the
brakes lightly applied.
2. Have an assistant stand in the center of the circle and listen for the clicking
noise.
3. Drive the car in the opposite direction. The assistant should be able to tell
which axle is making the noise.
DIAGNOSIS
(On-Hoist Method)
1. Raise the car on a hoist and start the engine.
2. With the transmission in first gear (manual transmission) or D4 (automatic
transmission), increase the engine speed to 2000 rpm.
3. While maintaining the same throttle position, apply the brakes to load the
engine speed to 1500 rpm.
4. Turn the wheels slowly to full left and full right positions. Have an assistant
listen to determine which axle is making the noise.
NOTE :
A driveshaft with a light degree of noise may not be detected by this on-hoist
method.
REPAIR PROCEDURE
1. Remove the driveshaft as described in Section 16 of the appropriate service
manual.
2. Use diagonal cuffers to cut the two boot bands and the outboard joint boot,
then remove them from the driveshaft.
3. Wipe off the grease to expose the outboard joint. Measure and record distance
"A" (from the splined end of the driveshaft to the inner race) as a reference for
reassembly.
4. Carefully clamp the driveshaft in a vise.
5. Remove the outboard joint using a threaded adapter (see REQUIRED SPECIAL
TOOLS) and 5 a commercially available 5/8 x 18 slide hammer.
6. Remove and discard the "C" clip from the driveshaft. Clean and inspect the
driveshaft splines and ring groove for burrs or other defects.
7. Install the new outboard joint boot provided in the kit. Slide it slowly onto the
driveshaft to avoid damaging the boot.
8. Install the new "C" clip in the ring groove of the driveshaft.
9. Insert the new outboard joint onto the driveshaft. Make sure the "C" clip is
centered on the shaft and is resting against the chamfered edge of the inner
race.
10. Remove the driveshaft from the vise.
11. To drive the outboard joint on the rest of the way, pick up the assembly and let
it fall from about 10 cm (4 to 5 inches) onto a hard surface.
NOTICE
Do not use a hammer; excessive force may damage the driveshaft.
12. Measure distance "A" (from the end of the splines to the inner race of the joint).
If the distance is more than your measurement in Step 3, repeat Step 11.
13. When distance "A" equals your measurement in Step 3, the "C" clip should be
seated in the joint. Tap on the inner race with a plastic hammer to make sure the
14. Fit the small end of the boot into the boot groove on the driveshaft.
15. Install the small boot band provided in the kit. Bend both sets of locking tabs
over, then lightly tap them flat.
16. Pack the outboard joint with the grease included in the kit. Pack the outboard
boot with the remaining grease, then fit the boot over the outboard joint.
17. Install the large boot band provided in the kit. Bend both sets of locking tabs
18. Reinstall the driveshaft assembly in the car. Refer to Section 16 of the
appropriate service manual.
Disclaimer
jmm67 is offline   Reply With Quote
Old 05-30-05, 10:10 PM   #17 (permalink)
BULLENTIN NO.
98-005
YEAR
ALL
MODEL
ALL
VIN APPLICATION
ALL
Boot Band Tool
The replacement boot bands for driveshaft CV joint boots have changed. The
replacement bands are a double loop type that requires a new required special tool for
proper installation.
One Boot Band Tool (TIN KD-3191) was shipped to each current dealer. To order
additional boot band tools, they are available from American Honda using the normal
parts ordering procedures, or from your local tool supplier.
Boot Band Tool: TIN KD-3191
PROCEDURE
1. Remove the old boot band. Take care not to damage the boot.
2. Remove and inspect the boot. Replace the boot if it is worn or damaged.
3. Install the boot, and fill it with the specified amount of grease. Refer to the
appropriate service manual for the grease type and amount.
4. Install the replacement boot band onto the boot with the end of the band toward
the front of the vehicle.
5. Take up the slack in the boot band by hand, and hold the boot band in place.
6. Measure and mark the band with a felt-tip pen the specified distance from the
clip:
- If you are installing a new boot, mark the band approximately 10 to 14 mm
(0.4 to 0.6 in.) from the clip.
- If you are reinstalling the original boot, mark the band 10 mm (0.4 in.) from
the clip.
7. Thread the free end of the band through the nose section of the boot band tool
and into the slot on the winding mandrel.
8. Take up the slack in the boot band by hand, then slowly turn the winding
mandrel with a wrench. Tighten the band until the mark you made in step 6
meets the edge of the clip.
9. Raise up the boot band tool to bend the free end of the band 90 degrees, then
center-punch the clip.
10. Unwind the boot band tool, and cut off the excess 5 to 10 mm (0.2 to 0.4 in.) from
the clip.
11. Secure the end of the boot band by tapping it down over the clip with a hammer.
12. Make sure that the band and clip do not interfere with anything and that the
band does not move.
13. Repeat steps 4 through 12 to install the boot band on the other end of the boot.
Old 05-30-05, 10:11 PM   #18 (permalink)
Imagevember 11, 1997
BULLETIN NO.
97-034
YEAR
1988-90
1987-90
MODEL
LEGEND 4-dr Std. & L
LEGEND 2-dr Std. & L
VIN APPLICATION
ALL
ALL
CD Player Upgrade Kit
4:54 PM
The accessory CD players shown are no longer repairable because parts are not
available for them.
CORRECTIVE ACTION
On a customer-pay basis, a radio and CD player upgrade kit is available.
The upgrade kit includes a radio, CD player, CD player trim piece, antenna adapter, an
anti-theft card, and an owner's manual.
NOTE
The radio is equipped with an anti-theft feature. Make sure you inform your
customer of this feature.
EXCHANGE PROCEDURE
Have your parts manager fill out an Audio Diagnostics Form (E2201) and carefully
pack it, along with a dealership check for $250, with the customer's CD player and
radio in a box. Send it prepaid via UPS to:
Alpine Electronics
19145 Gramercy Place
Torrance, CA 90501
(800) 421-2284, ext. 8888
(800) 262-4150 (CA only)
Alpine will send the new CD player and radio to your dealership within five working
days of receiving your package.
Imagemoving the Old Radio and the CD Player
1. Write down the customer's radio station presets, and disconnect the negative
cable from the battery.
2. Remove the radio panel, and disconnect the 16-pin connector and the antenna
leads from the radio and the CD player.
3. Remove the center console; refer to section 20 of the appropriate service
manual.
4. Remove the radio and the radio bracket from the radio panel.
5. Remove the CD player from the radio bracket, then remove the side brackets
from the CD player.
6. Straighten the tabs of the old CD player trim piece, and remove it from the radio
panel.
7. Reinstall the radio panel and the center console.
8. Pack the loose bolts and brackets in a plastic bag, and leave the bag inside the
glove box.
9. Reconnect the negative battery cable, and reset the customer's clock.
10. Return the old radio and the CD player as described in EXCHANGE
PROCEDURE.
Installing the Upgraded Radio and the CD Player
11. Disconnect the negative cable from the battery.
12. Remove the center console and the radio panel.
13. Install the new CD player trim piece onto the radio panel, and bend the tabs to
secure it.
14. Retrieve the plastic bag form the glove box, install the side brackets onto the
new CD player, then install the CD player onto the radio bracket.
15. Install the radio bracket onto the radio panel, and install the new radio.
16. Attach the CD player DIN cable to the radio, and insert the small end of the
antenna adapter, supplied with the upgrade kit, into the antenna receptacle at
the back of the new radio.
17. Connect the 16-pin connector and the antenna leads to the radio and the CD
player, and reinstall the radio panel.
18. Reinstall the center console.
19. Reconnect the negative battery cable, enter the anti-theft code, and reset the
customer's radio station presets.
20. Reset the clock.
21. Check the operation of the radio, the tape player, and the CD player according
to the owner's manual supplied with the upgrade kit.
22. Put the anti-theft card and the owner's manual for the upgraded radio/CD player
in the glove box.
Old 05-30-05, 10:14 PM   #19 (permalink)
Imagetober 7, 1997
BULLETIN NO.
90-010
YEAR
ALL
MODEL
ALL with CD Player / Changer
VIN APPLICATION ALL
Audio Unit Error Codes
(Supersedes 90-010, dated February 19, 1991)
If the audio unit displays an error code, use the troubleshooting tables in this service
bulletin to troubleshoot the problem. Refer to Service Bulletin 87-015 for CD
CD Changer Troubleshooting (All except SLX)
CD Player Troubleshooting (All except SLX)
Radio Troubleshooting (All except SLX)
CD Player/Changer Troubleshooting (SLX only)
Image. Remove the changer from the vehicle.
2. Remove the rear cover plate from the changer, and look for a jammed disc.
3. If a disc is jammed between the player and the magazine, turn the loading gear until
the disc returns to the player mechanism. Do not attempt to reload the disc back into
the magazine.
4. After the disc is loaded into the player mechanism, turn the changer so that its front
is facing you.
5. Insert a thin stainless steel ruler or a "Slim Jim" under the magazine, about 1-1/2"
from the right side of the opening.
6. Push the ruler in until it presses against the eject lever at the back of the unit.
7. Slowly remove the ruler and magazine at the same time.
Image. Remove the changer from the vehicle. [NEW]
2. Remove the top cover plate from the changer, and look for a jammed tray. [NEW]
3. If a tray is stuck in the player, reinstall the cover and replace the changer. If all the
trays are inside the magazine, insert a thin stainless steel ruler or a "Slim Jim" under
the magazine, about 1/2" from the right side of the opening. [NEW]
4. Push the ruler in until it presses against the eject lever at the back of the unit. [NEW]
5. Slowly remove the ruler and magazine at the same time. [NEW]
Image. Open the changer door. [NEW]
2. Check to see if all the trays are in the magazine. [NEW]
^ If a tray is stuck in the changer, replace the changer. [NEW]
^ If all the trays are in the magazine, place the changer in a horizontal position, and
insert a thin stainless steel ruler or a "Slim Jim" under the magazine, about 1/2"
3. Push the ruler in until it presses against the eject lever at the back of the unit. [NEW]
4. Slowly remove the ruler and magazine at the same time. [NEW]
2. Remove the top cover plate from the changer, and inspect for a jammed tray. [NEW]
insert a thin stainless steel ruler or a "Slim Jim" under the magazine, about 1/2 in.
Imag Image
^ Handle a CD by its edges; never touch the flat surfaces. Contamination from
fingerprints, liquids, felt-tip pens, and labels can cause the CD to not play properly, or
possibly jam in the drive.
^ When cleaning a disc, use a clean soft cloth. Wipe across the disc from the center to
the outside. Do not wipe the disc in a circular motion.
^ A new CD may be rough on the inner and outer edges. The small plastic pieces
causing this roughness can flake oft and fall on the recording surface of the disc,
causing skipping or other problems. Remove these pieces by rubbing the inner and
outer edges with the side of a pencil or pen.
^ Various accessories are available to protect CDs and improve the sound quality of
CDs. These accessories increase the thickness or diameter of the discs and should not
be used in CD changers .
Old 05-30-05, 10:15 PM   #20 (permalink)
BULLETIN NO.
86-014
YEAR
ALL
MODEL
ALL Except NSX
VIN APPLICATION
ALL
Brake Disc Refinishing
(Supersedes 86-014, dated September 29, 1986)
[NEW]
Brake disc replacement under warranty is not allowed unless the disc is beyond its
and rear brake disc maximum refinishing limit specifications.
Front Brake Discs
[NEW]
Whenever a front brake disc is replaced, it must be refinished on the car. Refinishing
new front discs is included in the flat-rate time for disc replacement.
[NEW]
To avoid brake vibration, always refinish brake discs on the car with the Kwik-Way or
Snap-on brake lathe. Purchasing information for these lathes is in Service Bulletin
87-035, Front Brake Disc Refinishing Equipment, filed in the Special Tools section.
[NEW]
Follow these tips to get the best results from your on-car brake lathe. (For detailed
instructions, refer to the lathe's operating manual.)
[NEW]
^ Before refinishing, warm the engine to normal operating temperature.
[NEW]
^ On 2WD vehicles, lift both front wheels off the ground. On the SLX, lift all four
[NEW]
^ On the SLX, make sure the hub nut is properly adjusted (with no end play) and the
transmission is in 4H.
[NEW]
^ On all vehicles, use a tie-down strap to secure the disc opposite to the one being
refinished.
[NEW]
^ Install the vibration damper on the disc, and install the protective band around the
wheel lug nuts.
[NEW]
^ Mount the lathe to the caliper bracket with Honda Quick-Mount Adapters. The
adapters can be ordered through the Honda Tool and Equipment Program; contact
Special Tools at 800-346-6327. The advantage of using the adapters is that they
don't have to be removed from the lathe once they are installed.
[NEW]
^ Use the aligning bar tool to ensure that the lathe moves square to the center of the
brake disc. The disc should turn toward the cutting bits.
[NEW]
^ Use "Kwik-Way" cutting bits, P/N KW109-1092-23, and the holding screws that
come with them. These bits are stamped "K W." They can be purchased from
American Honda using the normal parts ordering procedures, or by contacting a
Kwik-Way distributor. The Kwik-Way P/N is 109-1092-23.
[NEW]
^ Before using the lathe, inspect the tips of the cutting bits with a magnifying glass
to make sure they are not worn out. Each bit has three tips.
[NEW]
^ Do not set the cutting depth on the lathe to more than 0.2 mm (0.008 in.). This is
two divisions on the cutting knob.
[NEW]
^ To refinish, the transmission must be in first gear (D3 or D4, if the shift selector
doesn't have a first gear position) with the engine at idle (not fast idle). If the
transmission and engine are at higher gears and speeds, you will damage the
cutting bits.
Rear Brake Discs
Refinish brake discs off the car with conventional disc refinishing equipment.
[NEW]
None; information only.
Old 05-30-05, 10:15 PM   #21 (permalink)
BULLETIN NO.
97-013
YEAR
ALL
MODEL
ALL
VIN APPLICATION
ALL
Denso HLD-100 Halogen Leak Detector
A new tool is required to accurately detect A/C refrigerant leaks in all Acura
vehicles. The Denso HLD-100 Halogen Leak Detector has the following features:
^ Works with both R-12 and R-134a systems.
^ Impact resistant polyethylene case.
^ Auto balance adjustment; eliminates false alarms by adjusting for background
gasses in the air.
^ A calibration reference vial provides a leak signal to check the unit's accuracy.
^ Has a flexible probe extension; finds leaks in hard-to-reach places.
^ Small and portable; the battery, cables, and flexible probe extension probe can be
transported together as a unit.
NOTE:
Yokogawa H-10P, H-10N, and Kent Moore # J39400 are equivalent to the HLD-100.
SPECIFICATIONS
Sensing Element Positive Ion
Emission Heated Diode
Sensitivity (moving probe test per
SAE Std. J1627)
Alarm Sensitivity:
Switch Position R-134a R-12
Leak Check 3.0 oz./yr 1.0 oz./yr
Search 2 0.5 oz./yr 0.1 oz./yr
Search 1 0.1 oz./yr 0.05 oz./yr
Leak Alarm Audible with visible
neon lamp
Response Time Approximately 1 second
(slightly longer with flexible probe extension)
Warm-Up Time Approximately 2 minutes
Accuracy Exceeds SAE J1627
Hose Length 4.5 feet
Probe Extension Length 14 inches
Ambient Operating Temp 32 to 104F
Dimensions 5.5" x 10.5" x 8.5"
Weight 5 pounds
Agency Listings UL file SA9717,
SAEJ1627, CE-Mark
Power 12 VDC-Internal rechargeable, sealed lead acid battery
12 VDC-External Battery using battery clamp/cigarette lighter plug
EXTENDED WARRANTY INFORMATION
With the following exceptions, the HLD-100 comes with the manufacturer's limited 1
year warranty. Refer to the Operator's Manual for additional details.
^ Probe assembly, on/off switch, sensor socket, and carrying case - 3 years
^ Printed Circuit Board - 5 years
For parts or service, call Denso Technical Assistance at 800-366-1123.
DENSO HALOGEN LEAK DETECTOR KIT:
ORDERING INFORMATION
Can be ordered through the American Honda Tool and Equipment Program at
800-346-6327. Ask for the HLD-100.
USAGE TIPS
Here are some useful hints when using the HLD-100. Refer to the Operator's Manual
for complete operating instructions.
^ When using the leak detector for the first time, allow the leak detector to warm up
for 2 minutes with the probe in a clean atmosphere; this lets the sensor
temperature stabilize.
^ Calibration check should be done in the "Search 2" mode. Once done, the other
check modes don't need calibrating.
^ If checking an evaporator through the drain hose, avoid drawing water into the
probe. This could shorten the life and function of the internal pump and sensor.
^ Avoid creasing the flexible probe extension when you bend it. This could restrict
air flow and give false readings.
^ Because the detector recalibrates itself for ambient gases, you may have to move
away from the leak momentarily to clear the sniffer, then reapproach the leak.
^ When removing the clear probe tip, be careful not to lose the flow ball.
Finding Leaks in the Evaporator Area
1. Start the engine, and turn on the A/C.
2. Set the Fresh/Recirc button to Fresh, then turn the blower motor to High for 15
seconds.
3. Turn oft the blower, and set the Fresh/Recirc button to the Recirculation
position. Wait 10 minutes to allow any leaking refrigerant to accumulate in the
vents.
4. Attach the flexible probe extension, and insert it in the center grille.
5. Turn the blower motor to Low for about half a second; this will force any
accumulated refrigerant out through the vent.
GENERAL TIPS WHEN CHECKING FOR LEAKS
^ Both R-12 and R-134a are heavier than air, so always check 360 degrees around all
fittings.
^ If the system is very low on refrigerant , charge it to its normal capacity. (Some
leaks are impossible to find unless the system is operating at normal pressures.)
^ Refrigerant leaks are also oil leaks. The easiest way to spot a leak is to look for
joints or components coated with oily dust. Check for damage and corrosion at the
same time.
^ When checking the service ports for leaks, be sure the cap seals are in place and
the caps are tight. The cap is used as the final seal in the system, not just to keep
dirt out of the schrader valve.
^ Check the whole system in a continuous path; don't stop the first time the detector
indicates a leak. Check all fittings, couplings, service ports, pressure switches,
welded areas, and areas around attachment points on lines and components.
^ When checking the crimped metal ends on a rubber hose, wiggle the hose around.
^ Move the probe slowly (one inch per second is the recommended rate), and keep it
within 1/4 inch of the components. Moving the probe even slower at closer
proximities increase the likelihood of finding the leak.
^ Check the low-pressure side when the system is not running. Check the
high-pressure side when the system is running and also right after turning it off.
(The air from the cooling fans may give you false alarms.) Since the compressor
the system is running and when it's off.
^ Verify apparent leaks by blowing the area with compressed air, then recheck for
leaks. In case of a very large leak, blowing out the area may help pinpoint the exact
source of the leak.
SERVICING THE HLD-100
Here are some servicing tips for the HLD-100. Refer to the Operator's Manual for
detailed service procedures.
^ Check and replace the probe filter if it is clogged. Be careful not to lose the flow
ball when doing this.
^ The reference calibration vial can be expected to last approximately 6 months.
Replace it when it is empty.
^ If the sensitivity adjustment dial does not calibrate the sensor, replace the sensor.
Old 05-30-05, 10:16 PM   #22 (permalink)
BULLETIN NO.
97-010
YEAR
ALL
MODEL
ALL
VIN APPLICATION
ALL
New Fuel Pressure Gauge and Replacement Parts
New Gauge
The fuel pressure gauge with 10" hose (T/N 07406-0040001) has been discontinued.
The gauge that replaces it (T/N 07406-004000A) has an easier-to-read face, a
protective boot around the gauge housing, and a 48" hose.
Replacement Parts
The replacement hose for the old gauge (24", T/N 07406-004020A) has also been
discontinued. If you need a replacement hose, order the new 48" hose (T/N
07406-004020B). The new hose comes with an adapter so you can use it with the old
fuel pressure gauge (T/N 07406-0040001).
Before connecting the hose to the vehicle, make sure the aluminum washer on the end
of the hose seals properly. If the aluminum washer doesn't seal, replace the washer.
Replacement washers come in a set of five (T/N 07406-0040300).
Old 05-30-05, 10:17 PM   #23 (permalink)
BULLETIN NO.
97-001
YEAR
1987-97
MODEL
ALL
VIN APPLICATION
ALL with SRS
Supplemental Restraint System Inspection
The maintenance schedules in the Owner's Manual and Service Manual require that the
Supplemental Restraint System (SRS) be inspected 10 years after the date of manufacture.
The manufacture date can be found on the certification label attached to the driver's
The inspection procedure is simple, and the owners can do it themselves. When a
customer inquires about an SRS inspection, make a photocopy of the customer letter on
the back of this bulletin and give it to the customer. Instruct the customer to place the
letter in the glove box for future owners. If the customer requests that you Inspect the
SRS, use this procedure.
INSPECTION PROCEDURE
Perform this inspection procedure on vehicles with SRS that were manufactured 10 years
ago.
1. Turn the ignition switch to the ON (II) position.
2. Check that the SRS light on the instrument panel comes on for approximately 6
seconds and then goes off. If the SRS light stays on or does not come on,
troubleshoot the system following the procedures in the appropriate service manual.
3. Visually inspect the SRS airbag(s) external vinyl cover(s) for damage or
deterioration. If the airbag cover(s) is damaged or deteriorated, the customer should
have the airbag(s) replaced.
4. Make a photocopy of the customer letter on the back of this bulletin, and give it to
the customer. Instruct the customer to place the letter in the glove box for future
owners.
Imageebruary 1997
Dear Acura Owner:
The maintenance schedule in the Owner's Manual requires that vehicles with a
Supplemental Restraint System (SRS) have the SRS inspected 10 years after the date of
manufacture. The manufacture date of your vehicle can be found on the certification label
attached to the driver's doorjamb. The inspection procedure is very simple; you can do it
yourself. If the system should have a problem, you should, for your own safety, have the
system repaired by an authorized Acura dealer. Cost for repairs to the SRS system on
vehicles out of warranty are the responsibility of the owner.
seconds and then goes off. If the SRS light stays on or does not come on, you need
to contact an authorized Acura dealer for repairs.
3. Visually inspect the external vinyl cover(s) over the SRS airbag(s) for damage or
deterioration. If the airbag cover(s) are damaged or deteriorated, you should have
the airbag(s) replaced by an authorized Acura dealer.
4. Place this letter in the glove box so that it will remain with the vehicle when it is sold.
Old 05-30-05, 10:17 PM   #24 (permalink)
Imageptember 3, 1996
BULLETIN NO.
96-039
YEAR
ALL
MODEL
ALL
Except NSX
VIN APPLICATION
ALL with
Power Steering
Power Steering Pressure Gauge
The new power steering (P/S) pressure gauge, T/N 07406-001000A, supersedes the
This new power steering pressure gauge has features that you will find helpful when
performing power steering pump pressure tests.
TOOL USAGE
1. Follow the appropriate service manual procedure for installing the P/S pressure
gauge.
NOTE :
There are no changes to the P/S pressure gauge installation procedure. Use
the same adapters as described in the service manual.
2. Fully open the pressure control valve.
3. Start the engine and let it idle.
5. Measure the steady-state fluid pressure with the engine idling.
NOTE :
Refer to the appropriate service manual for steady-state fluid pressure
specifications.
6. Gradually close the pressure control valve, and immediately read the pressure.
NOTICE
To avoid overheating and damaging the power steering pump, do not keep
the pressure control valve closed for more than 5 seconds.
7. Within 5 seconds, fully open the pressure control valve.
8. Check that the gauge reads the pressures specified in the appropriate service
manual. If the reading is low, the pump output is too low for full assist. Repair or
replace the pump.
Old 05-30-05, 10:18 PM   #25 (permalink)
To repair the paint finish, you should use these tools and supplies:
Tools and Safety Equipment
^ Mil gauge (film thickness gauge)
^ Variable speed electric polisher
^ Dual-action orbital polisher (electric or pneumatic)
^ Eye protection (face shield or safety goggles)
Supplies
^ 9" Foam polishing pads (do not use wool type)
^ Clean, 100% cotton terry cloth towels or soft flannel cloth
^ Wet/dry sandpaper (1500 - 2000 grit)
^ Soft sanding pad
^ 50/50 Solution of isopropyl alcohol and water
While we cannot recommend one manufacturer over another, any of the manufacturers
listed here can provide you with quality products through their nationwide distributor
network. Contact them for your paint repair supply needs, choose one, and then use the
system of only that one manufacturer. If you need to know how to use the products, ask
the manufacturer for training.
3M Automotive Trades Division
22100 Telegraph Road
P.O. Box 358
Southfield, MI 48037-0358
Phone Number: 800-521-8180 Ext. 6890
Megular's
17991 Mitchell South
Irvine, CA 92714
Phone Number: 800-347-5700
MOC Products
12306 Montague Street
Pacoima, CA 91331
Phone Number: 818-896-2258
The following procedures may not apply to all conditions or colors. Use the procedure
that best suits the condition and color of the vehicle you're repairing.
Repairing and Polishing the Painted Surface
The goal of a minor paint repair is to correct the damage to the upper layer of the painted
surface. This is done by removing a thin layer of paint (no more than 0.5 mil) and then
restoring the luster by polishing the repaired surface. A quick way to determine the depth
of a scratch in the paint is to run your fingernail across the scratch.
If your fingernail catches on the scratch, the area will need to be wet sanded and polished.
When doing scratch or swirl mark repairs, use only quality products from one
manufacturer. Each manufacturer has its own set of paint repair products that have
matching materials. Mixing materials from different manufacturers, or using inexpensive
products, compromises the repair quality.
An electric polisher with an adjustable rpm control set between 1,500 and 1,800 rpm is best
for polishing. When using a polisher, faster is not better. Too much polisher speed and
Removing Swirl Marks
Most swirl marks can be removed by using a foam polishing pad and polishing material.
Use the polisher at 1,500 - 1,800 rpm with a small amount of polishing material on the pad.
Always begin with the finest polishing material. II necessary, progress to the next coarser
material only when the fine materials are ineffective.
When polishing, work in small sections (approximately 24" x 24"). Avoid running the
polishing pad over edges or character lines where the paint is more susceptible to burning
through. Let the cleaner do the work. Do not apply too much force! Forcing the polishing
pad could cause deep cuts into the paint and might damage the surface so badly that it
would need to be repainted.
Polishing Dark Colors
This additional procedure, after the polishing process described above, is important to
reduce any chance of swirl marks, which show more on dark colors. When polishing is
completed, use the same type of foam polishing pad on a random orbital polisher. Apply
the finest polishing material to a 24" x 24" work area. Start the polisher, and make three to
four passes over the work area. Remove the glaze residue with a cotton terry cloth or soft
flannel cloth.
Wet Sanding
This process is used to repair scratches and acid rain damage deeper than 0.2 mil. The
object is to remove as littlepaint material as possible. When wet sanding, stop frequently
and dry the work area. This will allow you to see if the wet sanding has removed the
damage.
Start by soaking a 1500 or 2000 grit wet/dry sanding paper in water for 15 minutes. Rap the
soaked wet/dry sanding paper around a soft sanding pad. Sand the affected area in one
direction across the scratched surface to highlight the affected area. Flush the area with
clean water. To remove any sanding scratches left by the wet sanding process, use a foam
polishing pad and a polishing material. Refer to Removing Swirl Marks.
Final Inspection
When the polishing process is done, the paint surface may look perfect, but residue can
hide very fine scratches that will become apparent after a few washings. This is especially
true for darker colors.
Start the final inspection by spraying a 50/50 solution of isopropyl alcohol and water on
the work area and then wiping it dry.
NOTE:
Avoid spraying the solution on any unpainted plastic parts, such as taillights, turn
signal lenses, reflectors, etc. The solution can cause cracking.
Inspect the repaired area, and repeat the polishing process if necessary. Finish the
inspection by waxing the completed vehicle with a high-quality wax. Use the wax
recommended by the paint repair supplies manufacturer you have chosen.
Preventive Maintenance
Avoiding scratches and dents while the vehicle is in your dealership inventory requires
some preventive maintenance. To help reduce the occurrence of scratches and dents,
follow these recommendations.
^ Park vehicles far enough apart to prevent door dents and dings.
^ Leave the exterior shipping protection on the vehicle until it is ready to be sold.
^ Implement and use an inventory age control system.
^ Use deionized water to reduce water spotting.
^ Wash the vehicles with deionized water, soap, and a wash mitt at least once a week.
NOTE:
Using a wash mitt will remove any residual dirt from the paint surface. If a wash mitt
is not used, the residual dirt on the painted surface will scratch the paint when the
surface is dried with a chamois or towel.
^ Use a clean chamois or terry cloth towel to dry the vehicles.
Old 05-30-05, 10:19 PM   #26 (permalink)
Imagebruary 20, 1996
BULLETIN NO.
96-003
YEAR
ALL
MODEL
ALL
VIN APPLICATION
ALL
Belt Tension Gauge Calibration and Repair
Drive belt tension can be critical to the bearing life of the A/C compressor, alternator,
etc. Tension should be checked and adjusted when a new belt is installed, and when a
used belt is removed and reinstalled during a repair. For that reason, each Acura
dealership is being sent a Belt Tension Gauge Set (T/N O7TGG-001000A). This set
Belt tension gauge (T/N O7JGG-001010A)
Belt tension gauge extension cable
Belt tension gauge checker (T/N O7TGG-001010A)
Plastic pouch and instruction manual
Refer to the appropriate service manual for drive belt tension specifications and
procedures.
CALIBRATION
The calibration of the belt tension gauge should be checked regularly. Use the Belt
Tension Gauge Checker included in the Gauge Set. If needed, additional checkers may
be ordered through normal parts ordering channels. The part number is
O7TGG-001O10A.
PROCEDURE
1. Push the handle and slide the checker into the gauge. Position the checker as
shown.
2. Release the handle and read the tension value on the Kg scale.
3. Compare your reading to the value etched on the checker. Your gauge is in
calibration if it is within +/- 3 kg of the checker value.
If your belt tension gauge is out of calibration, you cannot recalibrate it yourself.
Contact America Kowa Seiki about sending it for recalibration.
REPLACEMENT PARTS
If your belt tension gauge is damaged, replacement parts are available from America
Kowa Seiki. They are:
Cable 95506-10040
Handle/Grip 95506-10021
Handle only 95506-20081
Grip only 95506-20310
REPAIR AND CALIBRATION INFORMATION
America Kowa Seiki
20013 S. Rancho Way
Rancho Dominguez, CA 90220
(800) 824-9655
To return your belt tension gauge for calibration:
Contact America Kowa Seiki for authorization and shipping instructions.
^ Pack the belt tension gauge in a suitable box. Use "bubble pack" to protect the
gauge.
^ Ship according to their instructions.
America Kowa Seiki will charge a fixed fee to inspect, clean and calibrate the belt
tension gauge, and return it via UPS ground. Any repair parts needed are extra. The
gauge will be returned within 15 days.
Old 05-30-05, 10:20 PM   #27 (permalink)
BULLETIN NO.
92-020
YEAR
ALL
MODEL
ALL
VIN APPLICATION
ALL
Front Seat Belt Replacement Warranty Policy
(Supersedes 92-020, dated March 16, 1992)
Warranty policy for front seat belt replacement is to replace either the belt/retractor
replacement of only the failed half of a belt, not the entire assembly (see PARTS
INFORMATION).
COMPONENT REPLACEMENT
Front seat belts are made by several suppliers, and some are sold as individual
components (two separate halves); they are not stocked as a complete set. Therefore,
whenever you replace a belt, make sure the new belt half is the same type and from
the same manufacturer as the original - otherwise, the belt may not buckle properly.
To determine the manufacturer and type (or "model") of the belt, look for the white
tag on the original belt in the car. The tag is on the retractor side of the belt (visible at
the lower attachment point), or on the belt if you pull the belt all the way out.
From the tag, mark down the manufacturer's name (either Nippon Seiko K.K. or
Takata), the belt "model" number, and the date of manufacture.
If the tag is missing or illegible, look on the buckle half of the belt for the name
Nippon Seiko K.K. or the stylized "T" mark for Takata.
NOTE: Some seat belts may have NSK Warner K.K. as the manufacturer's name. Use
Nippon Seiko K.K. belts as the replacement.
Take the information to your Parts Department to order the proper replacement belt.
NOTE: For more information on seat belts and seat belt related items read:
- 2-Point Automatic Seat Belt Troubleshooting (ServiceNews, July "90")
- Lap Belt Retracts Slowly (Service Bulletin 90-008, April "90")
- Twisted Belt Buckles (ServiceNews, March "91")
- Seat Belt Slow to Retract (Service Bulletin 91-050, Revised January "92")
- Understanding the Automatic Shoulder Belt System (Service News, January "92")
Image Image
information. Most repairs do not require seat belt component replacement.
PARTS INFORMATION
For front seat belt replacement ordering information and availability, contact your
parts center.
Warranty Coverage:
Seat belts that fail to function properly during normal use are covered under warranty
for the useful life of the car.
Warranty Does Not Cover:
- Malfunction due to abuse, alteration, accidental damage, or damage resulting from
a collision or misuse.
- Replacement of a properly functioning seat belt for cosmetic or comfort reasons.
Old 05-30-05, 10:22 PM   #28 (permalink)
BULLETIN NO.
95-011
YEAR
1986-91
1986-90
1991
MODEL
INTEGRA
LEGEND
NSX
VIN APPLICATION
See VEHICLES
AFFECTED
(Supersedes 95-011, dated May 22, 1995)
BACKGROUND
The plastic button on Takata front seat belt buckles may break. Pieces from the
broken button could fall into the seat belt buckle, causing it to not latch or not
unlatch.
VEHICLES AFFECTED
Integra:
1986-90 - All
1991
3-door - Thru VIN JHMDA9...MS026676
4-door - Thru VIN JHMDB1...MS009150
Legend:
1986-90 4-door - All
1987-90 Coupe - All
NSX:
1991 - Thru VIN JHMNA1. . .MT001507
TOOL INFORMATION
Buckle inspection mirror:
Call American Honda Special Tools
at (800) 346-6327
PARTS INFORMATION
Seat belt buckle assembly:
See Parts Information Bulletin B95-0011
Front seat belt buckle guide kit A:
Black - P/N 06850-SH2-305ZA
Brown - P/N 06850-SH2-305ZB
Ivory - P/N 06850-SH2-305ZC
Front seat belt buckle guide kit B:
Black - P/N 06850-SH1-305ZA
Brown - P/N 06850-SH1-305ZB
Ivory - P/N 06850-SH1-305ZC
Front seat belt buckle guide kit C:
Black - P/N 06850-SE3-305ZA
Brown - P/N 06850-SE3-305ZB
See Parts Information Bulletin B95-0010 for information on matching guide kits to
interior colors.
Guide Kit Application - Legend
Year and Model Kit
1986-87 4-door C
1988-90 4-door A
1987 2-door C
1988-90 2-door A
Guide Kit Application - Integra
Year and Model Kit
1986-87 All C
1988-89 All A
1990-91 All B
Guide Kit Application - NSX
Year Kit
1991 A
Buckle Replacement - All 3-point active
(non-motorized) seat belts
Failed P/N: Integra Legend - 04813-999-999
NSX - 04816-SL0-A02ZA
Defect code: 712
Contention code: J95
Buckle Replacement - All 2-point passive (motorized) seat belts
Failed P/N: 04849-999-999
Defect code: 712
Buckle Guide Installation - All Models
Failed part: P/N 06850-999-999
Defect code: 712
Imagewners of affected vehicles will be contacted by mail. The owner will be asked to take the
vehicle to a dealership for repair or updating. The text of the customer letter is at the end
of this service bulletin.
Flow Chart
Imag Image
1. Wet a cotton swab with a five percent soap and water solution. Clean the inside
edge of the release button.
2. Using the Buckle Inspection Mirror (see TOOL INFORMATION) and a bright light,
examine the release button for chips or cracks.
^ If either front buckle assembly has a chipped or cracked release button, go to
Seat Belt Buckle Replacement.
^ If the front buckle assemblies are in good condition, go to Seat Belt Buckle
Guide Installation.
Image. Remove both front seat belt buckle assemblies. Refer to section 20 of the
2. Install the new buckle assemblies. Refer to Parts Information Bulletin B95-0011 for
part numbers and applications.
3. Center-punch a completion mark below the first character of the engine compartment
VIN.
Imag Image
1. Select the proper buckle guide kit. Place the anchor plate inside the buckle guide.
Make sure the hooked end fits inside the buckle guide, and that the holes in the
anchor plate and the guide line up.
2. While holding the anchor plate in position with your finger, slide the buckle guide
onto the buckle.
3. Use a screwdriver with a magnetic tip to install a set screw in the buckle guide on the
same side that you installed the anchor plate. As you tighten the set screw, push
down on the buckle guide to make sure it is fully on the buckle.
NOTE :
Tighten the screw by hand or with a low-torque battery-operated screwdriver. A
pneumatic or high-torque screwdriver will strip the guide and anchor plate.
4. Repeat steps 1 through 3 on the other front seat belt buckle .
5. Center-punch a completion mark below the first character of the engine compartment
VIN.
Example of customer letter:
Important Safety Recall Notice
Dear Acura Owner:
This notice is sent to you in accordance with the defect provisions of the National Traffic
and Motor Vehicle Safety Act.
The Reason For This Notice
Honda has determined that front seat belt buckle release buttons have broken and others
may break in the future, in some 1986 - 91 Acura cars equipped with seat belts made by the
Takata Corporation. These seat belt buckle release buttons are made of red plastic, and are
marked "PRESS" If a button breaks, pieces may fall into the buckle assembly. If this
occurs, the buckle may not operate properly, thereby creating a safety risk.
To prevent this problem from occurring, Acura will replace all broken front seat belt
buckles , free of charge. In addition, Acura will modify all unbroken buckles manufactured
Why Seat Belts Are Important
If your seat belt buckle is broken or does not operate properly, you should have it
replaced as soon as possible. Seat belts are the most important part of your car's safety
equipment Acura urges you to wear your seat belt whenever you drive, and to make sure
that your passengers also wear theirs. If you do not wear your seat belt, your chances of
being killed or seriously Injured during a collision are much higher than If you are wearing
a seat belt. That Is why seat belt use Is required by law in almost every state.
What You Should Do
Call any authorized Acura dealer and make an appointment to have your car repaired. If
either release button shows any sign of breakage or cracking, or if either buckle fails to
operate properly, the dealer will replace the buckle, free of charge.
Even If both front seat belt release buttons appear to be In good condition, and both
buckles operate properly, your seat belt buckles will need to be modified to prevent future
button breakage. Modification of the seat belt buckles will be free of charge and parts are
now available.
Replacement or modification of the seat belt buckles will take less than half an hour;
however, the dealer may need to keep your car for a longer period because of their
workload. Please call for an appointment.
If You Have a Problem
If your Acura dealer Is unable to, or fails to, make the necessary repairs or replacements,
free of charge, please contact:
Acura Campaign Information Service Office
American Honda Motor Co., Inc.
1919 Torrance Boulevard
Torrance, CA 90501-2746
The toll-free number is (800) 999-1009.
You may also contact:
Administrator
National Highway Traffic Safety Administration
400 Seventh Street, S.W.
Washington, D.C. 20590
or call the toll-free Auto Safety Hotline at (800) 434-9393 (Washington D.C.-area residents
may call [202] 3660123).
Warranty Reminder
For safety, we urge you to regularly check the condition of your seat belts. If you notice
that a release button is broken or if you experience any problems with seat belt operation,
contact your dealer immediately. Remember, Acura has a lifetime seat belt warranty that
applies to every Acura automobile. It covers any seat belt component that fails to
function properly during normal use (see your warranty booklet for details).
Special Notice to Lessors
Under Federal law, the lessor of a vehicle who receives this letter must provide a copy of it
to the vehicle lessee(s). The lessor must also keep a record of the lessee(s) to whom this
letter is sent, the date sent, and the applicable Vehicle Identification Number ("IN). (For
the purposes of this notice, a lessor means a person or entity that In the last twelve
months prior to the date of this notification has been the owner, as referenced on the
vehicle's title, of any five or more leased vehicles. A leased vehicle Is a vehicle leased to
another person for a term of at least four months.)
Thank you for your cooperation. We are sorry for any inconvenience you might
experience.
Old 05-30-05, 10:23 PM   #29 (permalink)
BULLETIN NO.
95-008
YEAR
1986-93
1986-92
1992-94
1991-92
MODEL
INTEGRA
LEGEND
VIGOR
NSX
VIN APPLICATION
ALL
Converting R-12 A/C Systems to R-134a
BACKGROUND
Because of environmental concerns, production of R-12 refrigerant is being phased out.
Honda is making retrofit kits available to convert systems that currently use R-12
refrigerant to R-134a refrigerant use.
PREPARATION
Before retrofitting the A/C system to use R-134a, test its performance and inspect all
components.
^ If the system is not cooling correctly, determine the cause (restriction, refrigerant
leak, system contamination, etc.) and repair it before continuing.
^ If the system is not fully charged, determine if there are any leaks and repair them
before continuing.
^ If the compressor is making noise, repair or replace it before continuing. Refer to Parts
Information Bulletin B94-0028 for the proper components.
^ If the system has been open to the atmosphere, replace the receiver/dryer.
RETROFIT KIT INSTALLATION
1. Use the R-12 recovery/recycling station to remove the R-12 from the system.
NOTE:
Failure to remove all the R-12 from the system will cause contamination of the R-134a
recovery/recycling station.
2. Disconnect the R-12 recovery/recycling station.
3. 1992-94 Vigor only: Remove the Schrader valves from the charge valves. The retrofit
valves in the kit have their own Schrader valves.
4. Use a shop towel wetted with Honda brake cleaner to clean the threads on the
existing valves. Apply Locktite (included in the kit) to the threads of the existing
valves. Install the R-134a retrofit valves from the kit.
5. Connect the R-134a recovery/recycling station to the system. Evacuate the system.
6. Add 120 ml of PAG oil (included in the kit) to the system.
7. Determine the amount of R-134a refrigerant needed to charge the system by
subtracting 50 ml (1-2/3 oz) from the system's R-12 capacity.
8. Charge the system with the proper amount of R-134a refrigerant .
9. Start the engine and let it idle. Turn the A/C system on and off several times. Listen
for any abnormal noises.
10. Repeat step 9 with the engine running at 1,500 rpm and 3,000 rpm.
11. With the system on, check the cooling performance at the dashboard vents.
12. Check the high and low side pressures and compare them to the R-12 specifications.
They should be slightly higher.
13. Turn off the A/C system and the engine. Disconnect the recovery/recycling station.
Install the caps on the valves.
14. Place the R-134a caution label from the kit over the existing R-12 label. If the R-12
label is no longer there, place the R-134a label on the right damper housing.
PARTS INFORMATION
R-134a retrofit kit A:
1986 - 87 Integra - P/N 38020-SM4-A2AH
1988 - 93 Integra - P/N 38020-SM4-A1AH
1986 - 87 Legend - P/N 38020-SM4-A2AH
1988 - 92 Legend - P/N 38020-SM4-A1AH
1992 - 94 Vigor - P/N 38020-SM4-A3AH
1991 - 92 NSX - P/N 38020-SM4-A1AH
None; this retrofit is considered to be customer-pay.
Old 05-30-05, 10:24 PM   #30 (permalink)
ImageTE: May 23, 1995
BULLETIN NO. 90-019
YEAR: ALL
MODEL: ALL
VIN APPLICATION: ALL
Acura Service Publications and Supplies
(Supersedes 90-019, dated February 14, 1995)
This service bulletin lists all the service publications and supplies currently available.
They are distributed by Helm, Inc.
Service publications and supplies may be ordered by telephone, fax, mail, or
Ordering by Telephone - Call Helm at (800) 782-4356. Telephone orders are accepted
Monday through Friday only between the hours of 8:00 a.m. and 6:00 p.m., Eastern
time.
Ordering by Fax - Complete a Wholesale Publications and Service Supplies Order
Form (E2105) and fax it to Helm at (313) 865-5927. Orders can be faxed 24 hours a day.
Ordering by Mail - Complete a Wholesale Publications and Service Supplies Order
Form (E2105) and mail it to this address:
AHM Service Division Order Desk
Helm, Incorporated
14310 Hamilton Ave.
Highland Park, MI 48203
Ordering by ACURALINK - Service publications and service supplies may be ordered
via ACURALINK. Orders received at AHM are sent electronically overnight to Helm
for next day processing. (Rush orders should be sent via fax or telephone.)
Shipping - Unless a real emergency exists, check "Normal (Best Way)" in the shipping
instructions box. Special handling/shipping is expensive and can cost more than the
publication itself.
All publications and supplies ordered are billed to the dealership's account through
the Acura Dealer Parts Account System.
NOTE :
^ All 1996 model publications may not be available at the time of this printing.
When available, 1996 publications will be automatically shipped to your
dealership in your subscription quantities.
^ Some older service manuals, body repair manuals, electrical troubleshooting
manuals and owner's manuals are now out of print. They are available as
electrostatic copies of printed manuals. These reproductions may be of lower
quality than the original printed, bound book. Reproductions are loose-leaf,
three-hole punched and shrink-wrapped. To request an order form or other
information, please contact Helm.
Service Manuals
Body Repair Manuals
Electrical Troubleshooting Manuals
Owner's Manual Covers
Owner's Manuals
Out-of-Print Manuals (1)
(1) Contact Helm for price information
HELM INC. Order Forms; SERVICE BULLETINS; FLAT RATE MANUAL; PDI
INFORMATION.
CUSTOMER INFORMATION; TRANSPORTATION; CUSTOMER ASSISTANCE
INFORMATION; WARRANTY SUPPLIES and INFORMATION
WARRANTY SUPPLIES and INFORMATION (continued); ADVISOR
NEWSLETTER; SERVICENEWS; SPECIAL TOOLS; INSTALLATION
INSTRUCTIONS
INSTALLATION INSTRUCTIONS (continued); ALTERNATE TRANSPORTATION
SYSTEM PROGRAM INFORMATION; MISCELLANEOUS; SERVICE ENGINEERING
INFORMATION; SERVICE MARKETING INFORMATION
Where to find service bulletins? journalboy Second Generation Legend (1991-1995) 0 02-09-05 06:27 AM
6 Speed Fixer Upper hondaman23 Legends For Sale 7 12-28-04 02:56 PM
1991 - 1995 ACURA LEGEND REPAIR MANUAL 1600 Pages Danny Second Generation Legend (1991-1995) 6 01-15-04 01:43 AM
91 LS Factory Recalls, Service Bulletins Josh Second Generation Legend (1991-1995) 6 12-09-02 04:08 PM
Acura Service Bulletins simgarcha Second Generation Legend (1991-1995) 0 07-30-02 10:23 PM
