Old 09-18-07, 09:59 AM   #1 (permalink)
Car 1: 1989 Legend 5 speed
Tire Pressure
One quick question. can someone please tell me what that correct tire pressure is for 235/40/17 ? Thank u
swinsoneric is offline
Old 09-18-07, 10:19 AM   #2 (permalink)
kclegend77's Avatar
Car 1: 1990 Acura Legend L
Car 2: 1984 Jeep Cherokee
Car 3: 90 chevy 2500forsale
the side of the tire should tell you the maximum amount of pressure you want to use in them. check there first.
kclegend77 is offline
Old 09-18-07, 10:38 AM   #3 (permalink)
yes on the side of the tire it says max 44psi. What is the correct pressure i sould use. i dont want to put the max (44psi)
Old 09-18-07, 11:03 AM   #4 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
the correct tire pressure is written on a sticker on the door of the car.
tires should be able to hold more pressure then the car's spec.
~Alex
Alperovich is offline
Old 09-18-07, 12:43 PM   #5 (permalink)
i guess alperovich didnt understand the question
Old 09-18-07, 03:11 PM   #6 (permalink)
I would start with the recommended pressure specified either in the manual or on the door sticker....regardless of what tire size is on the car.
'87 L-Coupe 5-Speed
Stock; NO Mods
392K Miles - original engine and drivetrain.
paulo57509 is offline
Old 09-19-07, 02:48 AM   #7 (permalink)
RedCoupe89's Avatar
Car 1: 89 Acura Legend Coupe
Send a message via AIM to RedCoupe89
good rule of thumb is go 7 psi below the tires maximum psi
Custom Intake
12" Subs, Crossfire amps for subs and deck, cap.
APC strut bar
17 inch rims (soon intrax/tokickos)
Hi flow cat (soon custom exhaust)
Hi amp altenator, optima battery
Slotted/drilled rotors, hawk hps brake pads, dot 4 fluid
22% Window tint all the way around
RedCoupe89 is offline
Old 09-19-07, 03:24 AM   #8 (permalink)
tubadude's Avatar
Car 1: 1990 Legend Sedan L
Car 2: 95 Land Rover Disco
i dont think seeing the tire pressure on the door or manual since its not the stock sized tires.
i would go with 35 to 40 if the tire says max is 44.
Tubabusters to the rescue!
tubadude is offline
Old 09-19-07, 03:54 AM   #9 (permalink)
Ken
aka desired_speeds
Ken's Avatar
Car 2: 91 Legend L - parts
Car 3: 96 Honda Saber 32v
Send a message via AIM to Ken
prolly 37 or so...
. k e n
Ken is offline
Old 09-19-07, 04:14 AM   #10 (permalink)
VIRGIN
murderotica's Avatar
I'd say no less than 40.
JDM swap | Custom CAI | Magnaflow High-Flow Cat | 2 1/4" Custom Exhaust | Classy Magnaflow Tip | Tokico HP Struts | Skunk2 Coilovers | Rota Wheels
oh snap, that means that i can just flip over every switch in my car and make it full jdm right? or maybe if i just flip my car onto its roof, then it'll be TRUE jdm
murderotica is offline
Old 09-19-07, 08:51 AM   #11 (permalink)
i have 36 in there now.....i guess that's good.
Old 09-19-07, 10:40 AM   #12 (permalink)
Mr. X (aka #5)
IkeRay's Avatar
Car 1: 1989 White Coupe (dead) my baby!
Car 2: 1987 Brown Coupe L
Car 3: 1994 Accord Sedan EX
tires dont have to have equal pressure because they dont have equal weight on them. i usually do the rear tires 2-3 PSI lower than the front tires. but dont always go 7 lower than the max, i have tires rated at 54 psi, and there is no way im putting 40+ psi in them. because theres less tire doesnt that mean you should have a lower psi rated than stock? or should it just be the same because its lbs of pressure per square inch and the amount of tire shouldnt make a difference since its still holding the same weight?
personally, i would put 35-36 front, 33-34 rear.
IkeRay is offline
Old 09-19-07, 01:12 PM   #13 (permalink)
Wowoweeee
pnoye2's Avatar
I too would go by the manufacturers recommendation... just keep in mind though, tire pressure are adjusted depending on road condition(s) <= this info should also be covered on the manual.
291K+ miles; original power/drive trains
pnoye2 is online now
Old 09-19-07, 01:24 PM   #14 (permalink)
legendtype2's Avatar
Car 1: 2006 Mercedes C230
Car 2: 1991 L coupe
Had 38-40 psi before but ride was harsh. Now at 36 psi ride is alot softer on my butt
91 KA8
Legend Gallery
legendtype2 is offline
Old 09-19-07, 04:34 PM   #15 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
no i didn't misunderstand the question. you misunderstood the answer.
tire psi is written on the door of the car. Tire size doesn't matter. always want to have the pressure at oem spec unless otherwise needed (raising pressure, like for racing or better mpg or less pressure for offroading)
~Alex
What should my tire pressure be? Pinyix Second Generation Legend (1991-1995) 15 04-20-07 11:12 AM
tire pressure acuralegend94 Second Generation Legend (1991-1995) 9 08-11-06 11:37 PM
Tire Pressure ARVIN First Generation RL (1996-2004) 2 08-17-04 04:58 AM
Tire Pressure LEGEND718 Second Generation Legend (1991-1995) 7 10-26-02 12:30 AM
Tire Pressure LEGEND718 Second Generation Legend (1991-1995) 0 10-25-02 10:50 AM
