Old 04-08-03, 03:00 PM   #1 (permalink)
Trouble starting car
lately, any time that I try to start my car after a good while of it being idle (usually several hours), it has trouble starting. When I turn the key I usually just hear a click, kind of like the sound of a relay being activated, but no engine turn. I check the CPU and it gives me no code. The battery seems fine because all the electronic components work properly.
For a while I thought that it might be the ignition coil, be cause once I looked at it and it seemed to be coated with build up and corrotion. I cleaned it up with my key and it started right away. However, the next time this happened, I tried the same procedure and nothing happened. Lately, if Istep on the gas a few times and then leave my foot on the gas as I turn the key, it usually starts, but once in a while it still gives me trouble.
Does this sound familiar to anybody?
Any advice?
Thanks in advance
What Me Worry?
AcuRandom is offline
Old 04-08-03, 03:05 PM   #2 (permalink)
The problem is most likely in the starting system, not the ignition system.
First thig to do is to make sure your battery connections are clean and tight. Cleaning the connections will requre removing the cables from the battery.
'87 L-Coupe 5-Speed
Stock; NO Mods
393K Miles - original engine and drivetrain.
paulo57509 is offline
Old 04-08-03, 05:42 PM   #3 (permalink)
Legendary Dai Lo
C25A1guy's Avatar
Car 1: 2002 Acura RSX
Car 2: 2006 Honda Ridgeline
I have the same problem. It's probably gonna be a dirty starter switch (in ur key cylender when you start the car). I have yet to get off my lazy butt and clean it.
Thanks To my sponsors and affaliets: M1 Autobody, ICB Motorsports, Honsport, Sierra Acura of Alhambra, Import Parts, Hondata, E Auto Parts, New Century Auto, APR Performance, Toyo Tires, Buddy Club, Torco Oils
C25A1guy is offline
Old 04-09-03, 03:37 AM   #4 (permalink)
Car 1: 88 legend coupe L - JDM eng
Main relay look at my thread here should take care of all your needs i hope
Fuel Pump Replacement : DIY
88 Legend coupe L Auto
c27a1 JDM Engine non-cat version 9.4 c/r
currently :dead auto
86 Legend 4d auto
c25a1
currently:stock and running, soon to recieve my 88s JDM motor and manual tranny
pyros88legendcoupe is offline
Old 04-10-03, 02:48 PM   #5 (permalink)
Thanks Pyros,
From readingyour post, I am now starting to suspect the fuel pump, or the wires leading to it.
Any ideas how much they cost to replace?
What Me Worry?
Old 04-10-03, 03:14 PM   #6 (permalink)
Car 1: 2000 gold 3.5RL and 2001 silver MDX with navi.
THE FUEL PUMP WILL COST AROUND $300 AT THE ACURA DEALERS AND ABOUT $50-$75 AT THE RECYCLERS AND TO INSTALL YOU MUST GAIN ACCESS FROM THE TRUNK.IT'S NOT TO HARD TO DO JUST TIME CONSUMING.
jno2968326 is offline
Old 05-13-03, 03:01 PM   #7 (permalink)
I kept letting this slide 'cause I could ussually start the car after about two to five tries. Finally, the other day when I got out of work, I got into the car, turned the key about a million times and no luck. After a while of twiddling with it I found that the wire going from the ignition coil to the distributor was bad. Replaced it and evrything Seemed fine. Drove home, drove to work the next morning, and drove back home and the car seemed fine. Then I went t othe gym and when I was going home, the car would not start anymore. I tired everything that the manual could tell me, but I could not get it to start. After leaving the car in the parking lot over night and having no luck on the next day, I finally gave in and called a tow truck and took it to a mechanic. The mechaninc found that the starter was bad, replaced it and all seems fine now.
The one thing that the repair manual did not tell me about. When it came to the section of the starter, all it said was "The stater is beyond the comprehension of the home mechanic, we recomend that you take your car to a mechanic or autorized dealer if you suspect the starter to be defective". Oh well.
Thanks for the help buds. Hope this helps some one else.
What Me Worry?
Old 05-14-03, 01:36 AM   #8 (permalink)
GO*_R!*E
Car 1: 1990 Acura Legend L Sedan 90 Honda Accord Lx 93 Ford Explorer XLT 96 Honda Accord EX Coupe
Send a message via AIM to marcdz1
I know you resolved your problem allready but for future references anyone who has a problem with the car not starting you should always give your starter a tap with a metal rod. its accessible just open your hood and next to the transmission dip stick is the starter hit it and your car should start. you can do away with this until you replace your starter.
90 Acura Legend L
Tripple Chrome
17 inch Alba Helix Wheels,17 Nitto tires 215/40zr-872,neon blue gauges,NEW Audiobahn Lcd screen/w Dvd player,Alpine Cd Digital Text & Audio,Radio Deck,2-5/9 pioneer speakers,2-12" NEW Audiobahn subwoofers,Custom Amp,New NGK Spark Plugs,Bosch spark plugs wires,K&N Air Filter,Fog lights,Nose braw,grill guard,pedals
http://www.imagestation.com/picture/...e/f80fe0d1.jpg
marcdz1 is offline
Old 05-14-03, 07:52 AM   #9 (permalink)
Car 1: 95 SE, 89 Coupe, Lexus 430 Conv.
Engine won't crank = battery, batt. connections, starter solenoid internal contacts, starter motor, wiring & relay between ignition switch, including ign. switch.
White 89 Coupe & White/Silver 95 SE
johnny3 is offline
