Won't start Need help....... - The Acura Legend & Acura RL Forum
Old 08-07-04, 04:07 AM   #1 (permalink)
Car 1: 1990 LS Sedan
I have a 1990 LS sedan and every now and then,my car won't turn over.It will turn over but won't start.I have noticed that when it's really hot and humid out,like 90 degrees and high humidity,it won't start.But as soon as the sun goes down or at night,it will start like normal as if there was never a problem.I tried taking it to a shop,but it never does it when I take it there and they tell me they can tell me whats wrong because its not doing it at that time.It has me baffled.I also don't think the hot temperature outside is the main cause because it has had the same starting problem in the winter when its freezing out. Any help will be appreciated.
WilliamG is offline   Reply With Quote
Old 08-07-04, 05:20 AM   #2 (permalink)
Car 1: 1990 L Sedan, White with Maroon
Send a message via AIM to luckybob
Replace or repair the main relay. If you search for this topic you will see that it has been discussed many many many times here and is a very common problem on older Hondas.
luckybob is offline   Reply With Quote
Old 08-07-04, 08:50 AM   #3 (permalink)
You say it also happens in the winter also. Try another thing. Open your gas tank and let the system depressurize. Try to turn the car over a couple of times. Put the gas cover back on.. then try to start as normal. You may have a little vapor lock also.
ND1980LS is offline   Reply With Quote
Old 08-07-04, 11:38 AM   #4 (permalink)
Akurit's Avatar
Car 1: Acura Legend 1990LS
Car 2: Hnda Prelude 2001SE
Car 3: Acura TL 2004 STD
Send a message via AIM to Akurit
I have the same problem. So why would heat cause this problem though and how does it affect the main relay.
Acura Legend 1990 LS
-18' Roh Rims
-12' Caption Sub/ 500W Clarion Amp
- Clarion 2-Way 6x9s
- Shaved Trim
- Milano Red Paint Job
- Cosmo Racing Short Ram Intake
- Cat backStainless steel exhaust w Deep Sound DTM.
- Tinted Windows 5% and 25%.
- Mesh Grill
Akurit is offline   Reply With Quote
Old 08-07-04, 12:41 PM   #5 (permalink)
Car 1: 90 Legend Coupe
The problem is the solder on the circuit board within the main relay board. With summer heat you have expansion and with winter cold you have contraction so over time, the solder joints develop dry rot (I think that is what they call it). When it gets really hot, these dry rot spots on the board prevents the circuit from forming so you can't start the car. If you open your windows and wait a while for the interior to cool, then these solder joints shrink and circuit is now ok again.
The solution is to remove the main relay and resolder the bad solder joints on the board. Other solution is to buy a new main relay , however it'll cost you. If you are handy, you can easily resolder.
Do a search on this board....lots of how to fix with instructions.
Good luck.
Sam
90CoupefromCanada is offline   Reply With Quote
Old 08-07-04, 12:47 PM   #6 (permalink)
Akurit's Avatar
Awesome thanks Im going to try that
-18' Roh Rims
- Shaved Trim
- Mesh Grill
Old 08-07-04, 11:17 PM   #7 (permalink)
Thanks for everyone's help.I am going to re-solder the joints and see if that helps,if not,I will just buy a new relay.They are only $40 I see.
Old 08-08-04, 08:45 AM   #8 (permalink)
Ok after reading up on the not starting topics on this forum,I read that when turning the key to the number 2 position on the ignition,I should hear the fuel pump.I noticed today that when I tried to start my car when it was hot outside,and the car wouldn't start,I didn't hear the fuel pump. After a few more times of turning the key to the 2 position and then trying to start the car,it finally started on the try that I DID hear the fuel pump.So now my question is,do I need a new fuel pump or is the main relay causing the fuel pump trouble? And if my fuel pump is bad,wouldn't the car hesitate or stall at times because the fuel pump is not putting out? My car's performance is very good and never stalls or hesitates.Any suggestions??????
Old 08-08-04, 12:57 PM   #9 (permalink)
Car 1: 90 legend LS coupe
Dude, fix or replace the main relay and be done.
Bobster is offline   Reply With Quote
Old 08-08-04, 02:54 PM   #10 (permalink)
Akurit's Avatar
I agree i just went out today got some soder and ill start on fixing it tommorrow. ill let you know how it turns out. btw on the same note i called acura and its like 78$ CDN for new main relay so i was like ill just fix it myself.
I finally did it got some help from my sis and soldered it.
Not sure if it works yet but the car starts. But the real test will be on a real hot day. So we will have to see.
-18' Roh Rims
- Shaved Trim
- Mesh Grill
Old 08-24-04, 11:44 AM   #11 (permalink)
Snow Why*e
Car 1: 1990 Coupe
how did you take out the main relay?
please respond as soon as possible. I need to check to see if my main relay is the reason why my car wont start.
thanks.
SilentBob is offline   Reply With Quote
Old 08-24-04, 02:43 PM   #12 (permalink)
thanks.
There are threads on this....it's under the bottom dash in front of your left leg.
My manual's in my car....which is at the shop..or I'd be more specific.
87 Legend Won't Start chenfred First Generation Legend (1986-1990) 15 11-27-07 03:08 PM
Help => Car near stalls when idling in Drive after a warm start 88legendMaroon First Generation Legend (1986-1990) 17 09-30-03 10:08 PM
Car Stalls and wont start every once in a while...and RPM's Jittery in Idle atst2000 First Generation Legend (1986-1990) 5 05-09-03 08:29 AM
Help!!! Car won't start! supplant Second Generation Legend (1991-1995) 16 02-07-03 07:32 PM
Installing Remote Starter - PAIN pYmpdaddi DIYs 34 03-17-02 11:37 PM
