Old 10-02-06, 10:10 PM   #16 (permalink)
Hello Moto
pnoye2's Avatar
Originally Posted by whyteLegend
THANKS pnoye2, I cleaned the EGR valve and pipe (clugged very bad nothing was getting through it) with a few bottles of carb cleaner, flat head screw driver & clothes hanger. Took it for free restest and PASSED ... went down 550 points on the NOx ... I also replaced the EGR gasket cost $7.50 retail at the dealer.
I'm glad you've got this addressed whyteLegend
pnoye2 is offline
Old 07-30-07, 09:22 PM   #17 (permalink)
Car 1: 1999 BMW ///M3
Car 2: 1989 Acura Legend LS
Hey I'm gonna ask a really stupid question so bear with me please. I didn't pass emmisions because my HC's are too high. They're at 169 and in the state of washington they're supposed to be 150. Besides putting in new spark plugs, new wires, new distributor cap; is there anything else that could be the problem?
Any help would be much appreciated.
regggindnas is offline
Old 07-31-07, 03:39 PM   #19 (permalink)
High HC could mean you need a new catalytic converter...
Ok I never thought of that...
Anything else?
Old 08-01-07, 02:39 AM   #20 (permalink)
VIRGIN
murderotica's Avatar
Uhh the cat is probably a winner. I had a high HC count as well (162 I believe; also in WA) and I tried everything short of replacing the cat to fix it but none of it lowered the HC count (the last time it was higher actually).
JDM swap | Custom CAI | Magnaflow High-Flow Cat | 2 1/4" Custom Exhaust | Classy Magnaflow Tip | Tokico HP Struts | Skunk2 Coilovers | Rota Wheels
oh snap, that means that i can just flip over every switch in my car and make it full jdm right? or maybe if i just flip my car onto its roof, then it'll be TRUE jdm
murderotica is offline
Old 12-05-07, 03:48 PM   #21 (permalink)
Originally Posted by slartibartfast View Post
High HC indicates a very rich mixture, which means either too much fuel for the available air or too little air for the fuel supplied. I have no idea what you were thinking when you wrote that. High O2 is the opposite condition of what would cause unburned HCs, i.e. lean condition and would appear in your NOx section.
Technically, It's "NOx" and it means "oxides of nitrogen", of which there are several species that result from combustion. NO, NO2, NO3, N2O2, N2O3, etc.
Not so. Highest NOx production happens at about 16:1. I offer "The Internal Combustion Engine in Theory and Practice, Vol #2" by Charles Taylor as my supporting material. He has a really nice graphic that shows the interrelation between fuel mixture and NOx production.
Otherwise, you wrote a comprehensive post. Why not spend a few minutes editing it for spelling, punctuation and capitalization for a really spiffy post.
[edited 30-Sep-06. Finally got my copy of Taylor's book back and checked the NOx graphic I mentioned.]
High HC's with high CO means rich mix.
High HC's with low CO means lean mix.
Two very different problems with the same high HC result.
There isn't one right answer.
Vacuum leaks cause extra O2 and a high O2 readings, which cause lean conditions and high HC's. The high HC's are unburned fuel and the unburned fuel is caused by either a lean missfire/incomplete burn or a rich condition.
CO tells you what your mix is, and HC's tells you how complete the burn is. A rich condition will also leave unburned fuel but will increase CO readings. My smog liscence has been expired for a few years but I was liscensed for 10 years and been repairing cars for 21 years. The only reason I let it expire is because I only wrench part time now, so it wasn't worth it to me to continue with re-training and re-testing.
The most common problems causing high NOx(oxides of nitrogen) are,
1. heavy carbon deposits on pistons, raising compression ratio/combustion temp.
2. Weak CAT
3. Inoperative EGR system. The sole purpose is to lower combustion temp. but the EGR is funtion checked on a smog check so that should be obvious if that is the problem.
Slightly elevated NOx can simply be a bad/weak CAT with no underlying problems and almost all engines even when running properly produce some NOx.
Carbon deposits may raise the level just enough to uncover a weak CAT because a good CAT will clean up alot of NOx. I've seen many cars fail for high NOx that passed after a Sea Foam treatment. If you O2 sensor is reading properly, that means the mix is correct. If cleaning the carbon doesn't change the NOx you need a CAT. This is all assuming your EGR system funtions properly, but like I said this is function checked on a smog test in California.
roostonu is offline
Emmisions Help Snowryder Engine & Performance Modifications 22 07-25-06 01:54 AM
emissions test failure....help please MERCCLK6 Second Generation Legend (1991-1995) 5 04-20-03 01:32 PM
