Old 07-05-08, 03:08 AM   #1 (permalink)
car2n's Avatar
Car 1: 1988 acura legend
c27a1 sleeving?
In my quest to find horse power for my G1 drag project (before getting NSX) i did a lot of research on how to increase power internaly, due to the lack of space in G1 i had to go on this dirction first...in case your are one day intersted on do all motor there is a company in california that does C30 cylinder block sleeving i talked to them about doing a c27a1 because of the similar block caracterstics and they said that they can do it for $1500.00 the name of this company is RS machines may be you can check their web site the type of sleeving i am talking about is to increase bore size and sleeve wall thickness, this is done in the c30 to increase to c32...
http://www.acura-legend.com/vbulleti...end-sx-124851/
LegeNd-SX
In memory of my son Isai "car2n"
car2n is offline
Old 07-10-08, 07:27 PM   #2 (permalink)
legend89chopped's Avatar
Car 1: 89 Legend Convertible
Car 2: 93 Legend LS 6-Speed
Car 3: 89 Parts Coupe
The 2.7 is already sleeved, and is a hell of a strong block.
I'll put it like this:
My engine had 140K miles on it when I bought the car.
I abused it every time I drove it, but kept fresh oil in it.
At 320K I rebuilt the heads, and left the block alone. At the same time, I installed the engine management kit which allowed free-tuning, and adjustable rev limit. I set it to 7500 RPM.
Between 320K and 350K miles, I did nothing but open road tuning. Basically, running the SH!# out of it, and making adjustments to timing and fuel to see what feels better. I tapped the rev limit of 7500 RPM every time I drove it, and it lasted over 30K miles on that old worn out block. I basically was trying to blow it up, to see where the weak points were.
The weak points I found were in the pistons. The piston skirts had just worn away too much from all the hard driving (and mileage!) to keep taking it. It's currently torn down, and I kid you not, the hash marks from the factory hone are still visible on the cylinder walls! Most of the wear is only on the piston skirts.
My overall point being that the block is a strong one. If you only invest in stronger pistons, rods, a very good crank balance job, and some head work, that'll take you a long way with that engine. I'm not planning re-sleeving, but just a slight bore to straighten the cylinders out, and honing.
So unless you're talking about trying to get more than 350hp or so, I don't think re-sleeving is worth it.
NALMFTW
Dang Bro!! Looks SICK!! I wish I had the guts to cut my junk like that..
...foreskin?
legend89chopped is offline
Old 07-10-08, 08:35 PM   #3 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
Damn, well said legend89chopped. Your nuts for trying to blow up the motor lol.
l4zy415 is offline
Old 07-11-08, 07:51 PM   #4 (permalink)
jago's Avatar
Car 1: 90' Rover 827SI
Car 2: 93' renault espace
i have to say i've found the motor to be very strong, i've had the nitrous comming in at 1500-2000rpm with no i'll effects (except clutch and tyres)
1990 Rover 827Si (honda c27a1) -timming advanced (DIY), Decat(diy), 2.5" exhaust(diy), direct cold air feed(diy), EBC yellow stuff front pads, Lowered 1" on Pi springs, 16" speedline alloys, Recaro 1/2 leather seats front and rear, carbonfibre covered dashboard,
nitrous (223hp @ 5673 and 215lbs @ 4829 - 22oct 2007)
jago is offline
