Old 10-05-07, 07:31 PM   #1 (permalink)
His name is Robert Palson
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
CAI vs Short Ram...an un-scientific approach...
Cold Air Intake and Short Ram Intake....
Which is better? Cold air or more air? The answer is "both." You want to have more filter area, but you also want to be bringing in cool air from outside of the engine bay. How much cooler? Well, see for yourself.
In all of the following pictures, the fender well where the air filter is housed is represented by the Temp Gauge on the left while the engine bay's temperature is represented on the right.
I warmed up the car to normal operating temperature (allowed the fans to come on twice) and then drove around for a while before officially starting to record the temperatures. Outside ambient temperature during the test was about 60 degrees F (it was much more chilly today than it's been for a while).
First: Allowed to idle for 5 minutes
The underhood temperature fluctuated between 130 and 135 which coincided with the fans coming on. It was definitely interesting to watch
Second: Cruise for 7-10 minutes at 45 mph
Both temperatures dropped significantly. The fender temp went as low as 65. But they both leveled off around these temps (67 and 89) before I finally took the pic.
Third: Cruise at lower, neighborhood speeds. 30 mph for about 10 minutes.
Engine bay temp rose back up though it was still quite cooler than at idle. The fender temp rose, at most, a mere 5 degrees.
UPDATE
Took a trip to Simi Valley today. 70-80 mph the whole way (30 minutes on the highway) at 75 degrees ambient temperature.
Cruise at Highway Speeds for 30 minutes
The temp leveled off and stayed at this temp even as the outside temperature rose from the beach to the valley. It also stayed fairly steady while the engine was under load while going up a steep 3-mile grade...
Heat Soak Max
After a 30 minute highway run and sitting outside in 75 degree weather, this was the max temp reached in the fender well and under the hood...
Night time cruise home on Highway (30 minutes, same route)
Temperature was about 60 degrees at 70-80 mph the whole way.
Now for my setup:
C25a Manual Tranny with Homemade CAI:
Cold Air Intake is built from 4 90 degree elbows of PVC
Now for some Mythbusting:
It has been debated on many a car forum whether PVC is suitable for intake construction. It's a well known fact that when heated, PVC can melt, deform, and (worst of all) start to release fumes that can be toxic to both engine and occupant. Some say it WILL AND DOES happen, while others argue that the engine bay just doesn't get hot enough.
Well I decided to go straight to the horse's mouth. I asked a contractor what the temp rating of this PVC was. He was stumped. He called the manufacturer and we were informed that this particular PVC is rated up to 180 degrees for safe use. At 210+ degrees it will start to release the fumes. As the temps continue to rise, it will start to lose its shape and eventually start to melt.
One thing that I found interesting was that the company also produces ABS and stated that although it has a higher temperature rating, once it DOES begin to melt is releases fumes that are FAR MORE TOXIC than those released by PVC. Hmmmm.....
So if your car ever catches fire, head for the hills...or at least inform the fire department of the health hazard.
Anyhow, this material will only be temporary for me as I have something better waiting in the wings. But I digress...
I have another part to this un-scientific experiment that I will have to add to this thread at a later time. In short, I will be adding cold air to the stock air box in an attempt to stop biting my nails thinking about hydrolock come the first heavy rain storm.
For now, though, it looks like CAI > SRI (but I didn't have to tell you that now did I?)
sam o nela is offline
Old 10-05-07, 07:46 PM   #2 (permalink)
Me & Nomuken(Monkey)
Beeze's Avatar
Car 1: 1989 Acura Legend L Sedan
Send a message via AIM to Beeze Send a message via Yahoo to Beeze
Thumbs up
Very Nice write up Gabe,
this is similar to the CAI I am in the planning stages of...except mine involves a short ram straight to a 90 degree coupler by the batt connecting to a 90 degree pipe to the fender well...again thanx for this experiment very informational...
HOME DEPOT Tuning!
Beeze is offline
Old 10-05-07, 08:53 PM   #3 (permalink)
Well Wisher
GrtOutdoorsAZ's Avatar
Car 1: '94 GS sedan 6MT
Car 2: '91 L sedan 4AT
yea that was awesome to see the actual temps...thanks for the write-up
very curious to see what I'm reading out here in sunny AZ...I bet my under hood is like 150 when it's 100 outside! where's a Rangerjoe CAI when you need one! guess I dont have to worry about hydrolock too much!
'94 GS 6MT
Exterior: jdm headlights <> paint job <> retro '91-'93 OEM fogs & bumper <> 17" Konigs
Performance: tuned Apexi SAFCII <> Sr5Guy chipped ECU <> Blackend engine damper <> MLS strut bar <> sr79labrat pulleys <> OBX headers <> Custom Y-pipe, Magnaflow Cat & Resonator, Stromung B-pipe & Muffler (All 2.5") <> TB Bypass <> RJ CAI w/ AEM bypass valve <> cross drilled/slotted rotors <> RJ short shifter <> ground wires
Interior: Kenwood DDX6019 w/ NAV & Ipod, 2-tone leather
GrtOutdoorsAZ is offline
Old 10-06-07, 02:17 AM   #4 (permalink)
Eh...What up Doc
Xcaliber003's Avatar
Car 1: 1989 Acura Legend LS 4Dr
Nice writeup. IMHO it should be a sticky.
........In short, I will be adding cold air to the stock air box in an attempt to stop biting my nails thinking about hydrolock come the first heavy rain storm.
That's what I have on mine. I bought an OEM K&N filter and decided I still wanted some of the benefits of CAI.
BTW I know this is way off topic but do you have a write up or parts list for an auto trans to man trans swap?
"love em all,trust a few,and fear none". . .Mos Def
Originally Posted by Dv8 View Post
As Ive said in the past:
Dont talk about it, do it and do it right. Then post the outcome.
~Dv8
I treat my women that way too...Haha.. ~Dv8
Xcaliber003 is online now
Old 10-06-07, 03:13 AM   #5 (permalink)
Ken
aka desired_speeds
Ken's Avatar
Car 1: 93 Honda Legend (LS)
Car 2: 87 Honda Legend 2.5L
Car 3: 96 Honda Inspire 32V
Send a message via AIM to Ken
lol and I just put my stock resonator and last section of the stock intake back on like 5 mins ago. oh well, ive been through 4 intake setups before.
. k e n
Ken is offline
Old 10-06-07, 03:59 AM   #6 (permalink)
Car 1: 1988 legend
lookin cool
Hey nice, I vote keep the PVC, those elbows are pleasing, kinda doubt it will deform due to heat. When bending PVC electrical conduit one has to heat the crap out of it.
Do you worry about rain with cai? It pisses here in the winter.
Does it prolong engine warm up in cold weather? My car does 80miles/week of short trips in the burbs, I'd rather it warm up sooner rather than later.
What filter to use? I thought K&Ns are the way to go, better filtration and flow than paper.
I was once told the best is a conical filter crammed into the stock box, I fail to see how that would be better than a drop in K&N.
Any thought on the above?
cheers, Jay
Jay P is offline
Old 10-06-07, 05:33 AM   #7 (permalink)
absconds using pump gas
music2bmurderedby's Avatar
Car 1: 91' legend ls sedan
Car 2: 2000 odyssey van
Car 3: 96' rl
yes my front bumper is in need of paint --- but besides that ... k&n drop in in the stock airbox with cold air coming straight into it via the front of vehicle (rammed air so to speak), & a friend of mine with an injen air intake would always beat me by about 1/4 to 1/2 a car b4 i did this ... i shit you not it is now the other way around. he paid $180.00 to get under the hood air, i paid $40.00 for the k&n & less than 10 for the aluminum 3" dryer hookup pipe & used a plastic piece from my yard blower that i will never use anyway. cheap or whatever you may call it, the power increase IS noticable & proven & it DOES give off a nice growl under the hood
music2bmurderedby is offline
Old 10-06-07, 06:09 AM   #8 (permalink)
Ken
aka desired_speeds
Ken's Avatar
Its actually less filtration and better flow. Can't have the good without the bad ya kno?
. k e n
Ken is offline
Old 10-06-07, 10:49 AM   #9 (permalink)
awelliott's Avatar
Car 1: 1987 Legend L Coupe
Car 2: 03 Honda Odyssey EX
Car 3: 93 Dodge Dakota LS
Nice writeup. Couple of questions: first, exactly where does your CAI end? Second, what are you using for filtration? Thanks...
awelliott is offline
Old 10-06-07, 11:55 AM   #10 (permalink)
sam o nela's Avatar
Hmmm...I believe there is an informal tranny swap post by Legend_Master in the FAQ....if not I will add it right now....but I'm pretty sure its there...
cheers, Jay
~I do worry about rain because there are some places in my area that are notorious for flooding come the first heavy rain. I know for a fact that my CAI will only be protected for so long by the splash shield and I've seen way too many horror stories on car forums...I know I could get a bypass valve, but I'd rather be safe than sorry...my next experiment will test the air temp difference between the CAI and cold air routed into the stock air box.
~I think that ambient temperature would affect your warm up time more than the CAI. I've had this intake on for over a week now and yesterday was the first day I noticed a longer time to warm up...but it was 60 degrees out when for the past few months it's been in the mid 70s every single day...
~Yeah I am using a regular paper air filter for a 91 Prelude...I trust the paper much more and I knew this setup would only be temporary. And regarding the Conical shoved into the stock airbox. Nikhai has this setup on his coupe and it does work, the only problem is though that I believe the stock filter or the drop in has more filtration area...either way I've just never been a fan of oiled-gauze filters...like Ken said, its a trade off...more flow with less filtration
Yes this is the California CAI that Erik (body9599) did way back when...this is kind of what I am planning to do, but minus the hose in the fender well...if one ever has to go through a deep enough puddle, that hose might become a straw
My setup ends as most peoples'...in the fender well with the resonator removed (been removed for quite a while actually hahaha) and protected from the elements by the splash shield. Also I am using this paper filter....
Stock Filter for a 91 Honda Prelude
Its a great paper filter...like I said I'm not much into oiled-gauze and I've had this filter on the intake for my wife's Infiniti for a long time now and its still going strong...plus I have no gripes about paying $6.99 every other oil change to change it out rather than having to clean and re-oil....
Thanks for all the great comments guys!
Old 10-06-07, 12:44 PM   #11 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
Car 1: 1988 Acura Legend 4 Door
great write up gabe i mean teacher lol my filter is foam, is that a good thing to use. plus its pretty easy to clean it up.
My Legend Is Rising Back From Hell!!!! BEWARE.
18" Limited 341 Chrome Rims
Candy Red Paint
Weapon R - Secret Weapon Intake
LED Bright White Dash Lights/Floor
Kenwood KDC-X590 Excelon Mp3 Deck
Ford Taurus Coin/Cup Holder
2 12" Kickers
1200 Watt Sony XM-2200GTX 2-Channel Xplode Amp
2 Rockford fosgate Capacitor
Power Acoustic Capacitor
Clear Rear Turn Signal
More to come...............
l4zy415 is offline
Old 10-06-07, 12:59 PM   #13 (permalink)
l4zy415's Avatar
Hate to tell you this man, but I have read in the past that foam is probably the worst in terms of filtration....
damn well thats a kick on the nuts
Candy Red Paint
2 12" Kickers
l4zy415 is offline
Old 10-06-07, 01:24 PM   #14 (permalink)
Beeze's Avatar
Question
What is the diameter of those PVC elbows, what size are those couplers, and where did you get them?
HOME DEPOT Tuning!
Beeze is offline
