Old 04-10-08, 01:29 AM   #16 (permalink)
NASCAR IZ THAR FASTEREST!
bandoni™'s Avatar
Car 1: 90 honda accord ex5speed
Car 2: 89 legend sedan auto
Send a message via MSN to bandoni™
Originally Posted by NuclearSymphony View Post
Another power-related thought, which I'm sure has already occurred to you, is traction. Any plans for some sort of LSD? Or stronger half-shafts? 500hp is approaching that of FWD drag cars
this plus what kind of clutch do you think will handle that kind of power?
sig by doubleglow the sigwhisperer
ƃuıʇsod ǝɹoɟǝq ɥɔɹɐǝs plnoɥs sɹǝsn ʍǝu
join the acura legend flickr group
visit my flickr page
bandoni™ is offline
Old 04-11-08, 06:04 PM   #17 (permalink)
legend89chopped's Avatar
Car 2: 1964 Chevy Impala
Car 3: 1997 Chevy Silverado
Still working on that. Had a lot of thoughts, like using NSX shafts and swapping out the joints somehow, or maybe shafts from a new TL. If the joints aren't swapable, then changing out the hub assemblies...
This gives me a headache, I'll just figure out the turbo setup for now, yeah?
legend89chopped is offline
Old 04-11-08, 06:07 PM   #18 (permalink)
I got that crappy EClutchmaster one coming for now, but I know a machine shop who can modify stock clutches to handle whatever you want. Expensive.
Old 04-11-08, 06:21 PM   #19 (permalink)
jago's Avatar
Car 1: 90' Rover 827SI
Car 2: 93' renault espace
it will be intresting to see if the centre matches up with the box.
what one did you go for?
1990 Rover 827Si (honda c27a1) -timming advanced (DIY), Decat(diy), 2.5" exhaust(diy), direct cold air feed(diy), EBC yellow stuff front pads, Lowered 1" on Pi springs, 16" speedline alloys, Recaro 1/2 leather seats front and rear, carbonfibre covered dashboard,
nitrous (223hp @ 5673 and 215lbs @ 4829 - 22oct 2007)
jago is offline
Old 04-11-08, 10:02 PM   #20 (permalink)
Muffo's Avatar
Car 1: 88 Honda Legend white
Car 2: 87 Honda Legend part
Car 3: Kingswood ute
Im going to see how far i can push the stock set up before it blows up then il worry about it because we cant get manuals over here
Muffo is offline
Old 04-12-08, 03:42 AM   #21 (permalink)
jago's Avatar
surely you could have a manual sent over? i would send one if you want, i have 2 spares
jago is offline
Old 04-12-08, 09:44 AM   #22 (permalink)
The "Stage 2" rated at 390hp. Hope they get it right. If not, I can be VERY influential when it comes to e-bay purchases. They won't want to piss me off.
Old 04-12-08, 11:06 AM   #23 (permalink)
jago's Avatar
thats what i ordered. if you have a vernier handy the spline should be 25mm or 63/64ths (well mine should be)
jago is offline
Old 04-12-08, 12:44 PM   #24 (permalink)
I've actually got an input shaft for my tranny on hand, and I'll just see if it slides in before I remove my trans.
Old 04-13-08, 03:52 AM   #25 (permalink)
Muffo's Avatar
If i cant find one out of a rover, which there werent very many made here i will have to look at importing 1 so i may just take you up on that offer but i still have a long way to go before i need the manual.
Im thinking of putting the c20at into some sort of go cart after i finish the 2.7 turbo, i recon it would be a cheap fun project
Muffo is offline
Old 04-13-08, 04:33 AM   #26 (permalink)
jago's Avatar
yeah that could be good.
i have a whole manual car sat here, so you could have box/gear linkage/flywheel etc.... not that i'm trying to sell it lol, just that i have all you need.
jago is offline
Old 04-14-08, 07:20 PM   #27 (permalink)
Here's what I did this past Sunday.
Removed the old heads...
Installed the new heads...
Oil pan gasket, with the new modified oil pan...
New timing belt, water pump, and seals...
Lots still to do.
Old 04-15-08, 02:50 AM   #29 (permalink)
Muffo's Avatar
Il try to find a rover here first cos postage from over there will be a killer but i may have to take you up on that in the future
Muffo is offline
Old 04-15-08, 05:54 AM   #30 (permalink)
Beautiful man!!!
Hey outta curiosity, how do those 2.7 heads line up with the NSX block?
Not well. I'm still working on THAT thread.
