Old 04-28-08, 08:29 PM   #61 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
GOOD GOD that things sounds mean even before the tuning!!
sam o nela is offline
Old 04-28-08, 08:49 PM   #62 (permalink)
legend89chopped's Avatar
Car 2: 1964 Chevy Impala
Car 3: 1997 Chevy Silverado
Or the TURBO for that matter! Had to say it, lol. Anyway, been tuning for an hour now and needed a break. The fuel is building up 'cus it's running VERY rich until the timing curve is worked out, then I'll do fuel, but at this rate that'll be tomorrow. The timing just up to 6000 rpm will take all night, but man I wan't to drive this thing around and raise some hell with basically open-headers right now!
legend89chopped is offline
Old 04-28-08, 08:58 PM   #63 (permalink)
TopGear Fanatic
NuclearSymphony's Avatar
Car 1: 1990 KA4 5M
Car 2: BMW M30 Project
Send a message via AIM to NuclearSymphony
The Nashville metropolitan area will never be the same Excellent work!
NuclearSymphony is offline
Old 04-29-08, 02:15 PM   #64 (permalink)
Legend Whore
aznman007's Avatar
Car 1: 1990 Acura Legend L, and 1990 5-spd LS Sedan
Originally Posted by legend89chopped View Post
Here's the website of our shop...
Honda and Acura Used Cars from Accurate Cars of Nashville
And as for the videos, I had the camera rolling for the start attempts. I didn't think they were worth seeing - a no-crank and a no-start - nothing fun. I'll post the first startup and idle, but I can't rev it til I do the timing calibration, just to be safe. The idle should be quite nice, tho, with the big injectors, and only the headers hooked up. And a roll-out video will be made, of course, as well as a first drive video. Next couple days hopefully.
OH YOU GUYS! haha I got my timing belt and stuff done there a few years ago. the convertible used to be a different color I believe. I remember it had a tan tarp at one point, correct me if this is a different car I'm talking about...
aznman007 is offline
Old 04-29-08, 04:47 PM   #65 (permalink)
Same car. Got rid of the canvas top, it was falling apart. It's come a long way since then.
Old 04-29-08, 05:44 PM   #66 (permalink)
jago's Avatar
Car 1: 90' Rover 827SI
Car 2: 93' renault espace
well done, did you use the ign map on the other thread? if so how close was it ?
1990 Rover 827Si (honda c27a1) -timming advanced (DIY), Decat(diy), 2.5" exhaust(diy), direct cold air feed(diy), EBC yellow stuff front pads, Lowered 1" on Pi springs, 16" speedline alloys, Recaro 1/2 leather seats front and rear, carbonfibre covered dashboard,
nitrous (223hp @ 5673 and 215lbs @ 4829 - 22oct 2007)
jago is offline
Old 04-29-08, 06:57 PM   #67 (permalink)
Never even got to the timing curve last night, but I will tonight. I'm starting from scratch. I'm basically gonna hold it at each RPM range, advance the timing until it begins to knock, then back off a couple of degrees. It's the best I can do until I get to a dyno. I got pretty tied up last night setting the cooling fan control range, and hooking up the fans, new battery terminals (had a lot of resistance in the ground terminal, and it was affecting my data logging), wired up the factory tach (which was useless because it's now seeing the MSD signal, so the tach reads about 2 or 3 times what it should, funny I didn't think about that). I should be ready to start tuning tonight.
Old 04-30-08, 02:22 AM   #68 (permalink)
jago's Avatar
well done, i've left the orignal wiring in on mine, is the tach not ment to go before the msd unit. i'e on the signal input to it. or does your msd have a tach out?
i best get moving on mine, still 1/2 way through putting the pcb in the orignal ecu case.
jago is offline
Old 04-30-08, 10:41 AM   #69 (permalink)
The MSD does not have a tach lead for the gauge, and the original one from the coil is seeing 2 or 3 signals instead of one. MSD makes an adapter that will 'filter out' the extra signals to correct this problem, but my SDS computer has a tach output, so I'm just using it.
If you look at the wiring diagram for the ignition circuit, you'll see the tach lead from the factory coil is just connected to the igniter input to the coil, with a resistor in between.(This connection is actually inside the coil, not spliced outside) So the tach signal wire sees the same signal the igniter puts out(1 signal per cylinder fire), or that the MSD box is putting out(2 or 3 signals per cylinder fire). I think the adapter wires in between the coil and the tach wire, but I really don't know for sure 'cus I haven't bought one.
Old 04-30-08, 02:15 PM   #70 (permalink)
Car 1: 95 achieva
Car 2: 87 legend(junkyard)
i hear ya man i tried hooking up an msd coil when i had my legend and i was defeated. i could not figure it out for the life of me
legend_fan27 is offline
Old 04-30-08, 06:06 PM   #71 (permalink)
OOPS! I was wrong! The MSD box DOES have a tach output, but I didn't see it before, because the hole for that wire was blocked off. I also did some further reading and found out that you should NOT connect anything extra to a coil that is powered by MSD, such as a tach. I'm only allowed one stupid thing a day, so I can't mess up again tonight when I try this new-found tach lead. Also, the MSD tach adapter I spoke of before should not be used with this SDS system. The manual says it causes interference, so I'm not even gonna try that.
Old 04-30-08, 10:04 PM   #72 (permalink)
Progress was made tonight. The tach lead from the MSD box works fine with the factory tach. I did the timing calibration with the crank sensor, set idle timing, and it runs much more smoothly, but another couple of problems have emerged. I have a coolant leak from the water pipe under the intake manifold. I cursed before when I saw that the head gasket set I bought didn't come with the large o-rings which seal this area, and I just matched them up with some a/c o-rings. Apparently this was a bad idea. Oh well, gives me something to do tomorrow night, I guess.
Old 05-01-08, 10:33 PM   #74 (permalink)
Good news! The leaks are fixed, SDS is completely installed (except for looming the wires and putting in more gauges), and it runs decently (driveable anyway).
Check out my CF gauge pod, Cardboard Fibre that is.
Dont make fun, had to put it in something.
The turbo housing isn't here yet, but I'm ready to tune. Best to tune it without boost first anyway, 'cus all I have to do is change the MAP values after the turbo install, and I can leave the timing values the same, because there's a separate timing-retard graph for boost, too! It just gets better and better the more I learn about this system. Haven't completely worked out the timing yet, but it already revs much quicker than stock.
Old 05-02-08, 12:03 AM   #75 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
I just want to lick your Legend so bad man, seriously lol.
My Legend Is Rising Back From Hell!!!! BEWARE.
18" Limited 341 Chrome Rims
Matador Red Paint
Weapon R - Secret Weapon Intake
LED Bright White Dash Lights/Floor
Kenwood KDC-X590 Excelon Mp3 Deck
Ford Taurus Coin/Cup Holder
2 12" Kickers
1200 Watt Sony XM-2200GTX 2-Channel Xplod Amp
2 Rockford Fosgate Capacitors
Power Acoustic Capacitor
Clear Rear Turn Signal
Reverse Glow Gauges
l4zy415 is offline
