» Sponsors
» Sponsors
Old 03-30-08, 07:21 PM   #1 (permalink)
legend89chopped's Avatar
Car 1: 89 Legend Convertible
Car 2: 93 Legend LS 6-Speed
Car 3: 89 Parts Coupe
Intake Manifold Modification: DYI
In prep to turbo the 2.7 litre, I found these butterflies in the intake manifold to be nothing but a turbulence inducing menace. So, I decided to take them out. It seemed pointless to just unscrew the flappers and leave the shafts there, so I went all-out.
After disassembly of the vacuum actuator and shafts, I fired up the welder with some aluminium wire and filled in the holes left behind by the shafts. I ground everything flat, and now I have no obstructions in the intake.
I'm no machinist, but I think I did a pretty good job.
Pic #1 is the before shot
Pic #2 is disassembled
Pic #3 is after welding and grinding
F.Y.I. these butterflies have something to do with EGR operation, but I'm not sure what. I'm using a full stand-alone engine management system, which is not going to use EGR, so this is what I did. I DONT KNOW WHAT WILL HAPPEN WITH FACTORY ELECTRONICS IF YOU DO THIS. It's possible that your engine could go too lean during EGR operation if this interfered with it, and you could end up melting something important.
Intake Manifold Modification: DYI-intake-mod-1.jpg   Intake Manifold Modification: DYI-intake-mod-2.jpg   Intake Manifold Modification: DYI-intake-mod-3.jpg
legend89chopped is offline
Old 03-30-08, 11:07 PM   #2 (permalink)
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
Car 3: '03 Infiniti I35
iTrader Score: 14 reviews
Good work man...
You could also eliminate that plate altogether as well as some old school old school members had done in the past....
Of course, if someone wanted flow, the 2.5 manifold is also a "possibility". Damn...I REALLY need to do that comparison already!!
Don't PM me. My box is permanently full.
sam o nela is offline
Old 03-30-08, 11:17 PM   #3 (permalink)
Muffo's Avatar
Car 1: 88 ADM coupe
Car 2: 88 JDM coupe
Car 3: 87 coupe
thats a dam nice job, i gotta learn to weld
Muffo is offline
Old 03-31-08, 10:51 AM   #4 (permalink)
I thought about removing it completely, but it seemed to be a good spot to drill some ports later for a dry shot of nitrous. Plus, since I'm boosting, I'm not worried about trying to eliminate space in the manifold, I just need to reduce turbulence.
Plus, this was way more fun than just removing the thing.
Old 03-31-08, 06:42 PM   #5 (permalink)
jago's Avatar
Car 1: 90' Rover 827SI
Car 2: 93' renault espace
not a bad job at all.
according to the manual, they are actually for increasing the low end torque,
1988 Rover 827Si Auto (honda c27a2) -timming advanced (DIY), 2.0" exhaust(diy), CAI(diy), EBC Green stuff front pads, Lowered 1" on Pi springs, 16" speedline alloys, Pace racing seats front and rear recaro seats, carbonfibre covered dashboard insert,
nitrous (204hp @ 6134 and 187lbs @ 5596 - 23sept 2008) 270hp with nitrous (not power run yet)
http://www.rollingroadtune.co.uk
jago is offline
Old 03-31-08, 08:19 PM   #6 (permalink)
Yeah, they open up at lower engine speeds to take advantage of the high-rise style manifold. They have to be shut when EGR starts pumping in exhaust gas for some reason. Oh well, screw EGR, I don't need to save gas anyway. This motor will never see lean a/f mix again anyway.
Old 04-05-08, 05:17 AM   #7 (permalink)
Rebirthing a Legend
Redhawk9274's Avatar
Car 1: 1989 Acura Legend With 1988 motor and 1990 Transmisison
Car 2: 1994 Cummins T/D
Car 3: Audi A6
I did the same thing. I lost low end torque. 3800 and up is noticeably more powerful. It would be a bad idea to remove the plate completely. This and a cold air is the best combo i have come across.
Redhawk9274 is offline
Old 01-01-10, 06:48 PM   #8 (permalink)
acuralegend_racer's Avatar
Car 1: 87 Lgd 2Dr AT (RIP)
Car 2: 89 Lgd 2Dr MT (WIP)
i know this thread is old but... if your setting up a stand alone ecu then wouldnt these butterflies be in the way and cause problems because they will no longer function without the stock ecu? or can they be program to work with the stand alone ecu?
OBX headers, HF cat, 2.5 exhaust, 2" dual muffler, weapon R CAI, groundkit wires, reduced weight, 5 spoke 17" Black w/polish lip rims, S/D rotors, glow guages, GT steering wheel, AEM pedals, kaminari kit, clear corners, jdm fog lights.
http://www.cardomain.com/ride/2943300
acuralegend_racer is offline
Old 01-02-10, 01:47 PM   #9 (permalink)
5 Speed Operator
24 Hours Rally Champion, Boat Rider Champion
1990Legend_LS_5spd's Avatar
Car 1: 1990 White LS 5spd Sedan
Car 2: 1990 White L Auto
Car 3: 99 Subaru Legacy
Send a message via AIM to 1990Legend_LS_5spd Send a message via MSN to 1990Legend_LS_5spd Send a message via Yahoo to 1990Legend_LS_5spd
programmed to work or just run off a mirco switch at a certain throttle position..
Originally Posted by Jrod@Buschur@ evowned.com
DSM's..... turning the everyday Joe into a tool throwing, foul mouthed, alcoholic since 1989.
1990 Legend LS Sedan 5 spd
1989 Legend LS Sedan Auto(For Parts, Bad Trans)
G1 FAQ
If Your Legend Stalls or Doesnt Start, CLICK HERE
1990Legend_LS_5spd is offline
Old 01-02-10, 03:40 PM   #10 (permalink)
i dont understand, please explain in detail.
Old 02-10-10, 04:19 AM   #11 (permalink)
ATXlegend49's Avatar
Car 1: 1993 Acura Legend Sedan
Car 2: 1992 Toyota sr5 4wd
how would i go about just polishing my intake manifold? i want it to look spankin new
dual 3" curved tipped borla muffler, weapon-R SRI, drilled rotors, red calipers, black mesh grille, blacked out rear blinkers and spoiler lights, clear corners and bumper lights
ATXlegend49 is offline
Old 02-11-10, 07:30 PM   #12 (permalink)
Super Moderator
C27A1Legend'88's Avatar
Car 1: 1988 Acura Legend Coupe L
You mean just the outside. It is aluminum I think. I know about a good site that shows how to polish aluminum.
1988 Acura Legend Coupe L 5-MT
Truly Legendary...
C27A1Legend'88 is offline
Old 02-12-10, 02:00 PM   #13 (permalink)
yes just the outside. i saw one the other day that look maaaaaagnificent and i was pretty jealous. really its aluminum??
Old 02-16-10, 10:59 PM   #14 (permalink)
Super Moderator
Yes the whole engine is aluminum. So the intake is probably aluminum too. It would just make sense. Do you want me to post the site that shows how to polish aluminum?
Truly Legendary...
