LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 03-01-03, 04:50 PM   #1 (permalink)
d!smembeŽmen+
Car 1: white 1989 L sedan
Send a message via AIM to legendHI
mod secrets and first gen tips...
by C25A1guy. Now that he's got a new project, he's letting a go a bunch of mod secrets and first gen tips he's learned through his experience of owning a g1 sedan for a number of years. thanks C25A1guy!! He asked me to post this stuff:
" . . .Sure. These will be off the top of my head. Oh, and post these for me, I've been extreamly busy lately.
1. Stock wheels make for great drag wheels. When you get new rims, save your stockies and put on a set of 195/50-55 R15 size tires.
2. Magnetic drain plugs are a god send for old engines.
3. USE 5W-30!!!!!!!!!!!!!!!!
4. Tighten the kickdown cable (auto trans) to have the trans hold out gears and not cancel as much power.
5. Old trans should stay away from Mobil 1 ATF (I think it's one of the things that went into the demise of this trans)
6. Exhaust don't do sh*t. If you want more power, figure out some way to get more air and fuel into the cumbustion chamber, and modify exhaust size accordingly.
7. If you wanna do anything major, BATTERY RELOCATION IS A MUST!
8. It will probably be a lot easier and cheaper to put in a Vortec supercharger then a turbo. Find somebody to do it
9. for the manual trannies, CENTERFORCE CLUTCH!!!! Next step down (but not by far) would be Exedy.
10. See if you can get your hands on another core engine and work on that.
11. WEIGHT REDUCTION! Take everything off when you run it if possible. Hood, lights, bumper, A/c system, disconnect the p.s. belt, tail lamps (if they'll let ya), all of your interior (including dash).
12. It's easier to duct the cold air from behind the battery then from around the front and down. You keep some of your air velocity that way because it's a shorter path and you still get cold air.
12. Get Level 10 trans with a torque converter that will lock at 3000-3450 RPM and get a B&M ATF cooler while you're at it.
13. When the thermoswitch goes, UPGRADE to the mugen or spoon thermoswitch.
14. Our cooling systems use a 14 psi cap. see if you can find another raditor cap of same fitment, BUT at 14.5 or 15, even 16 psi if you can find it. Cooler the car runs = MORE POWER and LONGEVITY.
15. DON'T SKIMP OR GO CHEAP ON MAINTNANCE!
16. STOP WASTING YOUR CASH AT THE DEALER! GOTO A TRUSTWORTHY INDEPENDENT SHOP, BUT MAKE SURE THEY USE O.E. PARTS. Only thing about the dealer I would go for is once a year, go in to do a diagnostic service. Sh*t, our cars are 13-16 year old cars. Is it relly worth the $75/hr labor charge?
There will be more to come later.
P.S. Once a Legend, always a Legend. I will be back, bigger, and badder then ever. . . . "
<font size="1">
1989 L white sedan
mods & upgrades:
'90 Legend LS coupe rims w/Yokohama 550H tires, Eibach/Bilstein full suspension, shaved trunk emblems, Sylvania Cool Blue bulbs, Diamond Blue driving lights, custom intake, NGK-VX plugs, "Nascar" premium silicon wires, Raybestos QS ceramic pads, titainium tint, two-toned Wet Okole custom fit, DEI alarm/immob./keyless entry, JVC tape/CD changer-controller w/ JVC 12-disc changer, two PolkAudio 10s (sealed), Kicker IX404, Kicker IQ900, Infinity Reference mids/x-overs, MB Quart tweeters, 8" rat shacks in rear deck</font size>
legendHI is offline
Old 03-01-03, 09:37 PM   #2 (permalink)
Legendary Da* Lo
C25A1guy's Avatar
Car 1: 2002 Acura RSX
Car 2: 2006 Honda Ridgeline
Thanks bro.
Thanks To my sponsors and affaliets: M1 Autobody, ICB Motorsports, Honsport, Sierra Acura of Alhambra, Import Parts, Hondata, E Auto Parts, New Century Auto, APR Performance, Toyo Tires, Buddy Club, Torco Oils
C25A1guy is offline
Old 03-01-03, 11:18 PM   #3 (permalink)
B**keye Member
Car 1: 1988 Acura Legend L Sedan 5 speed 95k miles
Send a message via AIM to Dan88Legend
http://dansacura.20m.com/engine1.JPG
http://www.dansacura.20m.com/lowered.html
This legend is dead.
My new toy:
'99 Pearl White Toyota Solara
5 speed V6
K&N drop in filter
I want: TRD supercharger & Short shifter
Dan88Legend is offline
Old 03-02-03, 01:05 AM   #4 (permalink)
work*ng a* *he *ar wash
Car 1: 1990 Ls auto sedan
Send a message via AIM to Atticus
does anyone have a picture or a diagram showing where the kickdown cable is located?
i know im a noob
Atticus is offline
Old 03-04-03, 10:23 PM   #5 (permalink)
Car 1: 88 legend coupe L - JDM eng
heres a couple extra off the top of my head.
-If your hood struts stop working. make a kink in them at full extension.
- are cars are designed for 87 octane. DO NOT use anything else you are throwing away money and power by going for higher octane. ( unless you have had your head shaved then go for 89)
-if your door handles don't work, take off your door and adjust the 10mm bolt in the door it slides left and right so you can adjust how much you pull the handle to release the lock.
- Cant get the door off. look for all the bolts then lift it straight up hard.
-Tranny computer is under the passenger seat in the coupes. It is visable from the rear. there is 1 red light with alot of codes. Look here if your S3 or S4 starts to blink.
-Use nothing but Honda Products. except oil. Honda ATF is a MUST, and Honda Anti-freeze dosnt contain a certain silicate (sp?) that prestone and all the others do. even if they say ok for alluminime engines. It will prevent corrosion and keep your seals alive.( Use Honda anti-freeze in every alluminim engine you own)
- Legend Fuel pumps are located under a panel in the trunk or under the seat in the sedan( i think ?). you can change it yourself with 3 tools( ratchet 10mm/17mm, plyers) and 45 mins.
- Replace your waterpump and timeing belt every 90k miles.
-almost all of the gaskets in legend engines ( all hondas) are rubber and ussually o-rings. and can be reused many times if nesessary. always clean both sealing metal surfaces and soak the gasket in oil. I reccomend you replace important small orings. The Valve cover gaskets on the other hand you reuse many times.)
-if you have a antenna lube it all the time. ( once a week)
- your low fuel light work. no? mine neither, actually ive never seen a working one if you want you can open up your dash quite easy my removeing all the screws and you can replace the LED ( cheap and easy and there might me a spare in there i forgot )
- wheel hub nuts are 36mm ( please correct me if this is wrong im 99% sure, got this feeling its 34?)
-your ALB and battery light both on. your alternator could be going. i have heard that this combo means dieing alternator. not 100% sure on this one.
-ALB light come on check the brake fluid ( both of them) same for brake light.
-Never ever EVER use armorall on our precious leather.
- if your car's air smells like sh*t, clean your fan unit its most likely covered with mildew or something like that. spray some bacteria killer in there.
-if your Heater Fan,Recurculation Fan, or your "In car Temp Sensor" ( the one inside the center console) make any noise take them apart and clean them.
- For auto's, both the Shift Solenoid set and the Lock-up Solenoid set should read 16-20 ohms from the each lead to ground. ( there are 2 leads per plug and 2 plugs). replace if they are off.
Make sure your brake shims are on right because legend brakes like to scream if you dont set them up right or if you use cheap ****ty pads.
If your car wont start , here is a troubleshooting thread of mine
Fuel Pump Replacement : DIY
i hope this helps someone, and please let me know if anything here is wrong.
88 Legend coupe L Auto
c27a1 JDM Engine non-cat version 9.4 c/r
currently :dead auto
86 Legend 4d auto
c25a1
currently:stock and running, soon to recieve my 88s JDM motor and manual tranny
pyros88legendcoupe is offline
Old 03-06-03, 09:35 PM   #6 (permalink)
Car 1: 1988 Legend Coupe
"pyros88legendcoupe".......You are correct, the ALB light and battery light being on indicates alternator failing, i was on my way home from a Maryland Terps Football game when my car died on I-495 west, actually I stoped cause it was nightime and i had no lights, had to leave on the side of the road with windows down. Luckily upon return the next morning nothing was stolen..I believe my system that was installed contributed to the resulting failure.
1988 Metalic Blue Coupe
2.7L V-6
*Awia Head Unit
*Pioneer 61/2" 2 way Speakers
*Rockford Fosgate 400s Amp. w/Remote Bass Control
*Rockford Fosgate .5 Farad Capacitor
*Rockford Fosgate 12" HE2 800 watt Max
Rockford Legend is offline
Old 03-06-03, 10:15 PM   #7 (permalink)
B**keye Member
good info everyone. keep postin
My new toy:
5 speed V6
K&N drop in filter
Old 03-06-03, 10:16 PM   #8 (permalink)
yeah, systems can really kill the battery. Ive read of huge water cooled alternators. thats what you need. if you can find one that you could make fit. thanks for clearing that one up rockford
86 Legend 4d auto
c25a1
Old 03-12-03, 01:23 PM   #9 (permalink)
Qualified Driver
90Legendman(LS)'s Avatar
Car 1: 90LS Sedan
Car 2: 07 Suzuki GSXR 600
So the fuel pump is not located in the gas tank ??
90 LS Sedan
90Legendman(LS) is offline
Old 03-13-03, 03:21 AM   #10 (permalink)
yeah it is, but you can take a cover off ( 4 10mm bolts) and you can see the fuel pump in the top of the tank, then you take off the 5 bolts and pull the thing out. its a big unit.
86 Legend 4d auto
c25a1
Old 03-13-03, 11:31 AM   #11 (permalink)
Qualified Driver
Car 1: 90LS Sedan
One more question for ya. Why does the water pump need changing every 90K ??
90 LS Sedan
Old 03-13-03, 01:11 PM   #12 (permalink)
mods: re*en*ly washed
Car 1: 1993 L coupe
For additional performance tips, be sure to check out Alexei Voloshin's Honda/Acura Legend Center.
katonk is offline
Old 03-14-03, 03:35 PM   #13 (permalink)
because the seals start to leak over time, and if you don't use honda coolant. your seals will get eaten and corrode from some silicate that honda stuff dosnt have. something like that. and if you blow a water pump ( i have) you will blow a head gasket and if you do that you should pretty much put in a new JDM engine because its alot of money to fix it like over a Grand.
86 Legend 4d auto
c25a1
Old 03-14-03, 04:19 PM   #14 (permalink)
Qualified Driver
Car 1: 90LS Sedan
OK gotcha, Thanks for the info !!!
90 LS Sedan
Old 03-19-03, 07:50 PM   #15 (permalink)
Send a message via Yahoo to 94LegendLS
anybody seen a handy list like this for second gen's?
94LegendLS is offline
