» Sponsors
» Sponsors
LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 09-18-03, 09:45 PM   #31 (permalink)
blk88Legend's Avatar
Car 1: 1988 Black Acura Legend L
Send a message via MSN to blk88Legend
NEW ALTERNATOR
I just got my legend fixed because battery and alb lights , when when I backed into the garage the radio died,, and then the car slowly died,,
right after a brand new alternator...
explain that one pls
ps: new battery in there too
Originally posted by Rockford Legend
"pyros88legendcoupe".......You are correct, the ALB light and battery light being on indicates alternator failing, i was on my way home from a Maryland Terps Football game when my car died on I-495 west, actually I stoped cause it was nightime and i had no lights, had to leave on the side of the road with windows down. Luckily upon return the next morning nothing was stolen..I believe my system that was installed contributed to the resulting failure.
USED TO OWN:
88 Acura Legend L
5 speed 3.0 v6
Tan Leather Interior
Fully Loaded
Sunroof
NOW I OWN:
2006 Honda Ridgeline EXL
2001 Honda Prelude SE
http://members.shaw.ca/incogneeto/misc/autoxcar.jpg
blk88Legend is offline
Old 09-19-03, 01:52 AM   #32 (permalink)
!NeMeS*S!
Car 1: 88' Legend L
just give up and get a new legend. I hear when that happens, it means too much gas has gone into the engine, and at the next startup, it might explode. Good Luck.
"Nemesis bringer of disaster/With more moves than a Tai Chi master"
mr_nemesis2003 is offline
Old 09-19-03, 01:57 AM   #33 (permalink)
EXPLODE!
What the heck are you talking about explode!?!?
if your trying to be funny its not working man.,.
I thought this was a question and answer forum
thanx but no thanx bud
Blk88legend
USED TO OWN:
88 Acura Legend L
5 speed 3.0 v6
Fully Loaded
Sunroof
NOW I OWN:
Old 09-19-03, 07:04 PM   #34 (permalink)
!NeMeS*S!
Car 1: 88' Legend L
chances are you have a bad ground, or maybe some wirring, thats what i think. What other reason would there be if you can't turn on your radio. Maybe a fuse, a batter post could have touched the vehicle. Well, these are my suggestions. Hope im right, if i am , i'm invincible.
to nemesis
Old 09-19-03, 07:14 PM   #35 (permalink)
SUCESS
WEll the dealership towed it back and told me the new alternator fried,, so they replaced it..
free of charge..
Now everything works good and no more idiot lights either
another satisfied customer..
anyone wanna buy it?
blk88legend
Ps: thanx for the reply mr nemesis2003
USED TO OWN:
88 Acura Legend L
5 speed 3.0 v6
Fully Loaded
Sunroof
NOW I OWN:
Old 09-19-03, 07:16 PM   #36 (permalink)
!NeMeS*S!
Car 1: 88' Legend L
NP. I was pretty close though, i figured it had to be something electrical. Im victorious.
nemesis
Old 11-04-03, 03:44 AM   #37 (permalink)
Car 1: 90 LS White Coupe
Send a message via AIM to DarkSledge Send a message via Yahoo to DarkSledge
quote
[4. Tighten the kickdown cable (auto trans) to have the trans hold out gears and not cancel as much power.]
Where do I find that and how do I do that?
Ryan
DarkSledge is offline
Old 01-16-04, 12:36 PM   #38 (permalink)
Car 1: 1992 Acura Legend sadan
How can I get more horse-power out of my 92 legend sadan and keep the same stock look.
Carlton James is offline
Old 01-29-04, 03:30 PM   #39 (permalink)
Car 1: 87 legend L
the fuel pump on sedans is located in the trunk, close to the back seats.
RHYNOPWR is offline
Old 02-23-04, 09:49 PM   #40 (permalink)
Thank you- the bit about the magnetic drain plug, the exhaust not doing s**t, and the Honda radiator fluid reference I found very helpful.
4796 is offline
Old 03-18-04, 05:08 PM   #41 (permalink)
Car 1: 86 Silver sedan
Everything has a downside:
-Tuning a car any more than bolt ons will have tons of issues. See: http://www.honda-tech.com/zerothread?id=683477
-Intake and exaust make the car better in the upper end and less in the low end. If they don't then they make the car too loud for normal people.
-CAIs are too loud and odd sounding for normal people, like your grandparents. It's a luxury car right? It's also a liability to them if you suck up water and destroy your engine.
-Dropping makes the ride worse, no matter how good your suspention. You can have an adjustable roll center and fully controlable suspention components but the springs and dampners have to be stiff to keep a lower car off the ground.
-Only a few people like body kits and Altezza lights, and even less have your favorite as their favorite.
-Lightened flywheels make your car harder to drive. It has less inertia so the clutch control has to be near perfect.
-Stronger clutches require more control as well.
-Sway bars(roll bars) make the ride jarring over uneaven left to right surfaces.
-Strut tower bars make the car too twitchy for many people, and can cause the car to loose it's safer understeer balance.
-Big rims make the car twitchy at the limits, reduce snow traction, and wet traction. The overall car gets worse.
-Big rims also raise the unsprung weight, making the car uncomfortable.
-Wide tires reduce gas mileage and stability in low traction conditions.
-Gimmick spark plugs (Splitfire, Bosch Platinum4+, etc.) only last longer at the stock power. Replacing worn spark plugs raise power anyway.
-Hyper-Ground and MSD are cost prohibitive, and may not really raise the hp b/c you replace the above when you install it.
-NOS kills your engine like steroids and is horrible for the environment. The remaining NOx destroys your cat. I've heard that they don't mess up your cat and I can prove to you with logic it's a lie: Your putting more Nitrogen and Oxygen in the chamber so you can burn more fuel. There WILL be extra NOx from ambient Nitrogen combining with the oxygen instead of carbon combining. In any case, more fuel burned means more bad gasses, period.
-Turbos require a lot of engineering knowledge, destroy the engine the same as NOS, and are very cost prohibitive to the manufacturer. The same T3 has been used in almost every factory turbo, with only slight modifications.
-Blocking the reduces emissions considerably and the manufacturer would be fined for this.
-Neon breaks very easily.
-Alarms, shaved locks, shaved doors, etc. are really useless and make getting in a car with a full load of groceries that much harder.
-Stripped interiors are just ugly.
-Carbon fiber is very, VERY cost prohibitive.
-In Dash receivers are cost prohibitive, the manufacturer can make much more money by making their own stereo.
-Subs use power and all the controlls to keep the power up are cost prohibitive and bulky.
-Everything that gives you performance reduces gas mileage and/or costs a lot and/or is hard to maintain.
-Everything, and I mean EVERYTHING, has a downside. Just ask me and I'll probably have a downside to it (not to be all pessimistic and all).
There is a reason for the factory not putting on that nice looking strut tower bar for you! If it was an overall good idea then they would have it on all their vehicles. They don't want to make a slow car. They want to make it an efficient car, comfortable car, reasonably priced car, easy-to-drive car, etc.
EDIT:
OH yea!! I forgot!!
-Big brake kits are cost prohibitive and usually too big for the factory wheel size.
-Drilled and/or slotted rotors can break when in cold, wet climates.
-Steel brake lines are cost prohibitive.
and LBNL:
-Racing pads are a nightmare b/c they have to be at a proper operating temperature to work well. When cold they are MUCH worse than stock.
I'm not saying don't do it, by all means. I am happily modding my car, and I hope the rest of you are too. This is just so you know what your getting yourself into... Newtonian Physics aply to tuners just as much as Murphey's Law.
BWEHOHAHEHOHE... Sorry... Got carried away...
Raybestos pads and a TurboViper CAI
R.I.P. Valentina (1989 Probe GT: The back The front) The boost components aren't salvageable.
squalus is offline
Old 05-29-04, 12:50 PM   #42 (permalink)
Dynamic Turbo Senior Tech
lacaci's Avatar
Car 1: 94 RWD Honda Civic - V6 Turbo Nitrous
Send a message via MSN to lacaci Send a message via Yahoo to lacaci
What a bunch of crap..
I can't believe I just read through all these pages and havent been able to find EVEN ONE PERFORMANCE TIP... what a joke... could you tell me how to advance/retard the timing on the old legends? or what plugs to use to run a 175HP NOS wet shot? or how to make a tool to remove/install the valve springs on legen heands? or how to make the 2.7 rumble like a cammed V8? or how to install a supercharger by reversing the intake? or how to put high compression pistons on a 2.7 without custom ordering them? Or how to fix the front motor mount and make it solid? or how to swap the legend onto any other honda chassis?
Please, don't call it performance tips...call it "how to change your oil" tips"
lacaci is offline
Old 06-03-04, 12:04 PM   #43 (permalink)
C25A1guy's Avatar
Car 1: 2002 Acura RSX
Car 2: 2006 Honda Ridgeline
Please realize that you have a Legend, not a Civic. If you wanted aftermarket support, you should have just gotten a civic or teg instead. As far as internals, NOBODY, and I do mean NOBODYmakes it for the Legend, ESPICALLY A G1. If you don't like it, then get the hell out.
Dean @ Honsport
Honsport - Truth in Engineering
Contact us anytime at sales@honsport.com
You can call us Mon-Fri, 10am to 5pm PST @ (626)203-8732
C25A1guy is offline
Old 06-03-04, 12:43 PM   #44 (permalink)
Fut
Car 1: Blk/Blk '94 GS 6 Speed [+] '90 LS 5 Speed Sedan
Send a message via AIM to Fut
Your knowledege of motors seems to be much more advance than our simple Legend minds can handle. I'm quite sure your wisdom would be welcome elsewhere, it's not here. Please leave. And one'mo thang, don't come back!!!
One...
Fut
Winter '09 G1 Legend Specific Strut Tower Bar Group Buy
10 Buyers Committed - Additional Buyers Welcomed - Stay Tuned For Production Updates
Fut is offline
Old 06-03-04, 02:41 PM   #45 (permalink)
Ken
desired_speeds
Ken's Avatar
Car 1: 94 Cashmere/tan L 6-speed
Car 2: 92 charcoal/blk auto
Car 3: 87 Base sedan
Send a message via AIM to Ken
some ppl have very big issues of not respecting others as a civilized person would, those ppl shouldn't be here on our friendly community, or even any other forum.
. k e n
Ken is offline
