Old 05-14-08, 05:20 PM   #1 (permalink)
legend89chopped's Avatar
Car 2: 1964 Chevy Impala
Car 3: 1997 Chevy Silverado
MSD-6A Performance Ignition D.I.Y.
This is for an Acura Legend 2.7 Litre. I have done this modification to my '89 Coupe, but I'm not using the factory Igniter Unit. However, this is how it should install on a factory ignition system. This D.I.Y. utilizes the factory Acura ignition coil, which actually produces MORE voltage for spark than the Blaster/Blaster 2 coils will from MSD.
I have provided two pictures. The first is the MSD manual wiring diagram. The second pic is from a 1990 Sedan wiring diagram, which should be the same for all the 2.7 Litres, as far as ignition wiring is concerned anyway. Both pics include photoshopped notes. You should be able to wire it up just by seeing the pics.
NOTE: In the pics, RED X = Cut connection or not used
THICK BLACK LINES = Ground Connections
There are 2 blue wires and 2 black wires coming from the coil:
BLUE WIRES: One of the blue wires is the lead for the factory tach, which should not be used after the install. Instead, use the tach lead on the MSD box to signal the tach/cruise/a/t module. The other blue wire is the signal wire from the igniter to the coil. This wire should be cut, with the coil side going to MSD ORANGE WIRE and the igniter side going to the MSD WHITE WIRE.
BLACK WIRES: The black wire from the igniter to the coil should be cut. The igniter just needs a ground here, so ground it somewhere near the MSD box, but do not spice it in with the other black wires in the ignition wiring. The coil side of this wire should go to the MSD BLACK WIRE.
NOTE: The second black wire coming from the coil, which runs to the radio noise condenser, is actually spliced into the first black wire, just inside the coil. Technically, you can leave this wire alone, as seen in the picture. HOWEVER, the radio noise condenser MAY INTERFERE with the operation of the MSD system. I'm not sure, because I didn't take the risk. Instead I took this wire and spliced it in with the MSD BLACK wire along with the other black wire from the coil. (NOT shown in the pic, but this I recommend.)
If you cannot figure out the rest of the wiring, you don't belong under the hood. All other wiring should be done in accordance with the MSD manual. Make sure to use sufficient gauge wire, and the correct fuses for current draw.
Oh, oh yeah, STEP 1: Disconnect battery.....
If power is hooked up, and you're messing around with loose ignition wires, and you ground, then un-ground the white or orange wire (by hitting up against anything metal, for example), you could activate the coil, and you could end up with enough voltage running through you to stop your heart. This would not be good. Let's have some sense when working with electricity, OK?
legend89chopped is offline
Old 05-15-08, 06:18 AM   #3 (permalink)
Muffo's Avatar
Car 1: 88 Honda Legend white
Car 2: 87 Honda Legend part
Car 3: Kingswood ute
Thats really great info. what did this set you back? I have found a secondhad 6AL that is spose to be only used once for 200 Aus dollars that im seriously thinking about. do you think it would be worth it.
Muffo is offline
Old 05-15-08, 12:02 PM   #4 (permalink)
I'll be honest, I got mine used from e-bay, but from a trusted seller. I think I paid $125 US (bout $135 AUS) for mine, but it wasn't a 6AL, just 6A.
I only got it for the SDS system, because I didn't want to wire it up to the factory igniter unit. SDS programs their stuff to work with aftermarket spark boxes, and they named MSD specifically, so I got one.
Old 05-15-08, 02:49 PM   #5 (permalink)
For some reason, I can't post in the D.I.Y. section. Could I get this moved in?
