Old 06-14-08, 08:00 PM   #211 (permalink)
Muffo's Avatar
Car 1: 88 Honda Legend white
Car 2: 87 Honda Legend part
Car 3: Kingswood ute
Thanks for the tip. Just another idea i am thinking about is not using the 2.0 motor now and putting both the intake and exaust manifolds onto the 2.7. I think i can easily remove the top mount intercooler in the process. Then il track down another motor or use my spare one to build with forged internals
Muffo is offline
Old 06-15-08, 02:28 PM   #212 (permalink)
jago's Avatar
Car 1: 90' Rover 827SI
Car 2: 93' renault espace
you could just use the exhaust side and fit a front mount to use the orignal 2.7 inlet manifold
1990 Rover 827Si (honda c27a1) -timming advanced (DIY), Decat(diy), 2.5" exhaust(diy), direct cold air feed(diy), EBC yellow stuff front pads, Lowered 1" on Pi springs, 16" speedline alloys, Recaro 1/2 leather seats front and rear, carbonfibre covered dashboard,
nitrous (223hp @ 5673 and 215lbs @ 4829 - 22oct 2007)
jago is offline
Old 06-16-08, 08:18 AM   #213 (permalink)
Muffo's Avatar
the turbo mounts on the manifold right where the N/A tb sits. otherwise i would because its half the work
Muffo is offline
Old 06-16-08, 12:56 PM   #214 (permalink)
jago's Avatar
what about turning the manifold round and moving the alternator?
jago is offline
Old 06-19-08, 08:20 AM   #215 (permalink)
Muffo's Avatar
Just off the top of my head i dont think there would be the room for ti between the motor and the strut tower
Muffo is offline
Old 06-22-08, 04:37 PM   #216 (permalink)
jago's Avatar
that could be a bit more of an issue, i'm not a fan of cutting the car up to get a mod in.
jago is offline
Old 06-23-08, 03:08 AM   #217 (permalink)
Muffo's Avatar
Neither am i in most cases. I think the best bet is to use the turbo intake manifold and ditch the factory intercooler it will just mean a bit longer intake pipe. I may even be able to mount the N/A TB on it.
Muffo is offline
Old 06-23-08, 05:36 PM   #218 (permalink)
jago's Avatar
sounds like a good plan,
jago is offline
Old 07-14-08, 05:08 AM   #219 (permalink)
Muffo's Avatar
OK when i get around to istalling my ecu. I cant decide what motor to go with. seen as i only want the 2.0l for a short time do u think it would work to just plug all the vacuum lines instead of plating or welding all the parts s if this will work i will have it running in no time and then can consentrate building the 2.7 with all the good parts
Muffo is offline
Old 07-14-08, 05:26 PM   #220 (permalink)
jago's Avatar
yeah as a temp measure u can just plug any unused lines etc...
jago is offline
Old 07-15-08, 01:49 AM   #221 (permalink)
Muffo's Avatar
I will weld everything up on the 2.7 when i put forged internals in but i want to just get it running with the 2.0 even if its not running that well
Muffo is offline
Old 07-15-08, 02:56 AM   #222 (permalink)
Muffo's Avatar
Once i get the msd i will bolt the motor in and wire it up, plug the vacuum not used then iltry and get it running N/A. Would any one have stock timing chart for the c20a ot the c20at. I think i will chuck a wrx turbo on it for a while because you can buy them for next to nothing. this shold get me mobile so i can build the new motor
Muffo is offline
Old 07-15-08, 03:53 PM   #223 (permalink)
LSPREDATOR
LSPREDATOR's Avatar
Car 1: 1988 Acura Legend LS
ACURA LEGEND RACER IS RIGHT. ITMAY BE BETTER TO CONTACT THE GUY OUT IN AZ. I WILL BE SENDING MY CAR TO THEM SHORTLY FOR THE TURBO KIT TO BE INSTALLED. ONE OF THE GUYS SAID ON A STOKE MOTOR THEY GOT 300 HP. I SENDING IT THERE WITH AN LSD IN THE TRANS, METAL HEAD GASKETS, LIGHTER FLYWHEEL, AND CUSTOM HEAD STUDS,13 INCH ROTORS WITH 6 PIOSTON CALS. THE CAR THEY DID A WHILE AGO WAS ONLY RUNING 6 TO 8 POUND OF BOOST.THEY DO ALL THE TUNNING, ECU,TURBO KITAND DYNO THE CAR SO YOU NOW WHAT YOUR WORKING WITH.YOU CAN DO ANYTHING IF YOU HAVE THE MONEY,BUT THE TIME AND HEADACHE MY NOT BE WORTH IT.
LSPREDATOR is offline
Old 07-15-08, 09:01 PM   #225 (permalink)
Muffo's Avatar
Last time i checked they had discontinued it and the only power figure i have seen was only just over 200hp
Muffo is offline
