Ground wire kit...
Have anyone done this yet to a RL!?? I plan to do this on the weekend. I have heard they add around 5-10hps lol I think it would be great since the RL is hard to find any performance mod, so try to squeeze out any avalible hp
Acura RL in the making... |
I want to ride low..
You're welcome.
Ground kits dont add 5-10hp. It adds maybe 1. It just reduces static power by properly grounding your components and smooths out the stray power.
1994 Acura Legend LS Coupe Sherwood Green. -Alpine 9883 -Alpine Type-R -Alpine PDX -17x8 Flik FTD -225/45/17 Nitto NeoGen Tires -Vogtland Springs. TSX Projector Retrofit 219K+ running strong |
Cure Hunger:Soylent Green
Sigh, I'd hoped somebody would have answered this, so I skipped it. Sorry.
Those grounding kits really can add lots of power to cars with shitty grounds and/or dodgy electrics. I doubt you'll run into either of those issues on your car. I cannot say how important a good ground is, so no matter what else I say, "hell yeah put it on."
"Bigamy is having one wife too many. Monogamy is the same" (Oscar Wilde) 3.5RL With/Without Nitrous Comparo VideoI'm only hard on you because you chose to believe the misinformed. |
FRISCO LEGEND BABY!!!!
I made my own ground kit for my Legend. Dressed up the motor kinda nice lol. I', using 2 gauge wires.
My Legend Is Rising Back From Hell!!!! BEWARE. ![]() 18" Limited 341 Chrome Rims Matador Red Paint Weapon R - Secret Weapon Intake LED Bright White Dash Lights/Floor Kenwood KDC-X590 Excelon Mp3 Deck Ford Taurus Coin/Cup Holder 2 12" Kickers 1200 Watt Sony XM-2200GTX 2-Channel Xplod Amp 2 Rockford Fosgate Capacitors Power Acoustic Capacitor Clear Rear Turn Signal Reverse Glow Gauges Soon To Come: Rebuild Motor and 5-MT Swap |
You are welcome
[url]http://www.myspace.com/jinxednco Car List 81 CJ7 restoring 93 Ac Legend Sedan (starting fresh headed for VIP) 93 Ac Legend Sedan (Undecided) 70 Olds Cutlass Supreme w/ the 455&turbo400trans 91 Nissan 240sx 5spd. (wifeys Whip) she wants to learn to drift? [color="Blue"][u]92 Ac Legend Coupe (Daily Driver)TypeII Intake+Injectors and rail+Throttle Body, EGR Blocked off, Venom 400, Rebuilt at 130,000 due 2 BHG, custom grille, Weapon R Intake and CAB, Factory option upgraded wheels,[/COLOR] |
I've got a grounding kit on both my Legend Coupe and my NSX. I really think the Coupe runs smoother...now that I've driven it a bit.
On the NSX, I added a kit because the technical guys at AEM said it would smooth out the readings I was getting with my serial gauge. They were right. My A/F readings used to jump all over the place...now the are much steadier. Can you feel a difference in power? Maybe psychologically - that's about it. It certainly can't hurt anything, though. my 2 cents
1993 Legend 6-speed coupe, 4cruizin is my hero 1992 NSX all Comptech 362 RWHP short gears, etc. 2004 Mini Cooper - MC40 John Cooper Works 1975 914 Porsche 6,500 actual miles |
nice 2 gauge wire lol. I'm planning to use 8 gauge wire for my 96 RL, if i do everything right there won't be any sparks lol...BTW i'm getting 20mpg in my 96 RL with 145,999k miles on it!!! crazy huh.....
Well Wisher
20mpg? have you replaced the fuel filter ever?
I just got a cheap ground wire kit off eBay and used legendtuner.org for reference on the grounding points. They also have those ones that bolt onto a hub that's usually placed near the battery. just dont spend too much on the whole setup - like others have said, it's mostly to dress the engine up. I noticed some improvement in a few categories, but nothing phenomenal.
'94 GS 6MT Exterior: JDM headlights & rain visors <> paint job <> retro '91-'93 OEM fogs & bumper <> 17" Konigs Performance: tuned Apexi SAFCII <> Sr5Guy chipped ECU <> Blackend engine damper <> MLS strut bar <> sr79labrat pulleys <> OBX headers <> Custom Y-pipe, Magnaflow Cat & Resonator, Stromung B-pipe & Muffler (All 2.5") <> TB Bypass <> RJ CAI w/ AEM bypass valve <> cross drilled/slotted rotors <> RJ short shifter <> ground wires Interior: Kenwood DDX6019 w/ NAV & Ipod, 2-tone leather |
I didn't replace the fuel filter or anything at all lol just don't step hard on the gas pedal...BTW I notice that Legendtuner.org has only one ground wire connect to the battery negative terminal..from what I heard you should connect all the ground wires to the negative terminal. Is there any difference?
#15 (permalink) | |
I always step hard on the gas pedal maybe that is my problem......
