Help with new noise! - The Acura Legend & Acura RL Forum
Old 01-08-09, 08:15 PM   #1 (permalink)
I am wondering if anyone has any ideas about a new noise that has developed on a 1996 RL with 155,XXX miles.
The car has just developed a whining noise that increases with engine speed. At first I thought it was the transmission but I found that the noise is present when the rpm's are increased and the car is either neutral or park. Would this tend to eliminate the transmission as a problem?
The car still drives fine and the transmission seems to be shifting smoothly. I just completed a 700 mile trip in the car last weekend and did not notice any unusual noises.
Any ideas would be appreciated.
Thanks
rich1777 is offline   Reply With Quote
Old 01-08-09, 09:06 PM   #2 (permalink)
Car 1: 1998 Acura 3.5 RL
I've seen three cases on RL's where this seeming transmission noise turned out to only be a bad wheel bearing. Apparently the RL's have wheel bearings that fail quite loudly.
EDIT: Of course if the noise is there when the car is not moving its not the wheel bearings ;-)
Roger Murdoch is offline   Reply With Quote
Old 01-08-09, 11:23 PM   #3 (permalink)
Car 1: 1998 grey sedan
Wink car is stationary??
If the noise is still there when the car is not moving but the engine is running it won't be wheel bearings.I have heard of noise coming from worn a/c compressor,alternator or power steering belts and/or bearings in the same.If the noise varies with R.P.M. I would look into this area.See if you can find where the noise is coming from under the bonnet (er sorry, hood for you yanks).
aussie '98 legend man
aussie '98 legend man is offline   Reply With Quote
