#16 (permalink) |
Here they sell accord coils for only 107 dollar. Honda Accord 94-97 Dropzone Adjustable Coilovers -Honda Coil Over Kits So if yall are saying these work for the RL that would be a bargain. I'm wondering though when these are made for the weight of an accord, wouldn't it hurt too put them under a heavy RL?
#17 (permalink) | |
Will all ugly people please be quiet!? LS430 is coming |
#18 (permalink) |
Admit the obsession
Im not sure in any company even makes a 225/40/17. that is the size I want to put on my TL wheels but i cannot find them anywhere. As for wheel max, i ordered a wheel and tire package with them and had no problems
Finally back in an Ac. 91' pearl white legend coupe 6K HID's, intrax springs, weaponR intake, tint, excessively loud exhaust 17" TL wheels Just instaled PIAA fogs- the only coupe rockin fogs OEM GS style- pics comming soon! |
#19 (permalink) | |
Ultimate DIYer
Tires for PASSENGER CARs very cheap, bargains, have a look and save |
#20 (permalink) | |
Acura RL in the making... |
#21 (permalink) | |
#22 (permalink) |
235 is wider and more expensive, mainly for performance. If done right, the 235 wont stick out, but if it does, it should barely be noticeable. the RL's fenders are really spacious anyway so if the fitment on the wheels and tires is right then rubber sticking out shouldnt be an issue.
i want to put 245's on mine ![]()
#25 (permalink) | |
Cure Hunger:Soylent Green
The tire you've selected is too small, in fact they'll be really goofy and rubber bandy looking. If the looks won't put you off then consider the rotational size. The stock tire is 215/50-16 and I would suggest 225/50-17 which is much closer in rotational diameter to the stock size. The tires you selected are: .84in SHORTER in the sidewall height 2.18in SMALLER in circumference The 225/50-17 is: .20in LARGER in the sidewall height If you don't know anything about tires, even enough to know what the numbers mean, you shouldn't be second guessing the suggestions these people are offering. You also need to be sure that the tires you select have an adequate speed and load rating for safety so you don't end up with a blow-out. Saving money and dying is false economy at best. Don't save money on brakes next year either! GSM
"Bigamy is having one wife too many. Monogamy is the same" (Oscar Wilde) 3.5RL With/Without Nitrous Comparo VideoI'm only hard on you because you chose to believe the misinformed. |
#26 (permalink) |
Ultimate DIYer
When you consider a different tire size, you must keep the overall diameter of the tires the same or at least within 3%. Otherwise, it will give a negative affect on your vehicle's gear ratio. I would strongly recommend it within 1% difference though.
If your OEM tire size is 215/50/16, the 225/50/17 is 5.38% bigger in diameter, so it is not the right size. As I told you, 235/40/17 is a good choice in terms of wider, safer, cost-effective, and variety of stock availability. The diameter difference with OEM tire size is just 0.25% smaller. it means that your speedometer indicates 60.1 mph for the tire size, when 60.0 mph for the OEM size. An alternative size is 215/45/17 which is 0.61% bigger in diameter and 59.2 mph in speedometer if you wanna keep it the same width to OEM. If you wanna learn more about tires and wheel, just check the below. You will become a tire and wheel expert within an hour. 1010tires.com Tire & Wheel Tech |
#27 (permalink) |
+1 97_RLer
Great link. I'll have to add that one to my collection.
#28 (permalink) | |
#29 (permalink) | |
Ultimate DIYer
1. Kumho ECSTA 711 235/40 R17 90H BSW UTQG: 320AAA Price: $61.20 per tire 2. Nexen N 3000 235/40 ZR17 90W BSW UTQG: 340AA Price: $65.60 per tire 3. Nexen N 7000 235/40 ZR17 90W BSW UTQG: 360AA Price: $72.40 per tire 4. Hankook VENTUS H405 HR II 235/40 R17 90H , VSB UTQG: 340AA Price: $79.60 per tire 5. Hankook VENTUS SPORT K104 235/40 ZR17 94Y XL 4PR with rim protection UTQG: 280AAA Price: $91.40 per tire * The price information was cited from Tires for PASSENGER CARs very cheap, bargains, have a look and save |
#30 (permalink) |
I like Cum-Hoez.
