Not changing timing belt will damage your engine??? - The Acura Legend & Acura RL Forum
Closed Thread
Old 01-04-07, 06:30 PM   #1 (permalink)
Car 1: acura rl 96
If your timing belt breaks will it damage your engine? Some threads say yes and some say no.
lepfam5 is offline
Old 01-04-07, 07:43 PM   #2 (permalink)
DemonWolf
jimmer's Avatar
Car 1: mazda 2600i sort of
Car 2: Legend coming!
yes......it will damage the motor if the belt snaps
we run whats called a interference motor and when the belt snaps your valves can be snapped right into your pistons among other things that can happen
something along that line
jimmer is offline
Old 01-04-07, 08:02 PM   #3 (permalink)
Car 1: 96 Legend
Is it an interference motor really? Someone has checked? I doubt we have that much lift in them bumpsticks. Sure there are valve reliefs in the pistons, but that doesn't necessarily equal an interference motor.
Anyway, as the belt stretches, your timing gets off and you will lose power. This doesnt damage your motor but yes the belt breaking and there is a possibility of other things breaking.
3g Legend is offline
Old 01-04-07, 09:10 PM   #4 (permalink)
Car 1: 2001 audi a4 sold
Car 2: 1999 acura rl
good thing my daddy is a mechanic and whens time to change mine which is in 8k miles he do it for free all i gotta do is buy the parts
1999acurarl is offline
Old 01-04-07, 09:26 PM   #5 (permalink)
DemonWolf
jimmer's Avatar
know for a fact mine is a interference motor....RL should be the same as they havent changed the style of the motor THAT much
jimmer is offline
Old 01-10-07, 04:15 PM   #6 (permalink)
IM A LEGEND
LEGEND95GS's Avatar
Car 1: 1995 LEGEND GS 1994 LEGEND COUPE LS(TIMES 2) 1993 LEGEND COUPE LS (SIX SPEED) AND 2000 3.5 RL
Car 2: 05 g35 6spd
Car 3: 02 yukon denali
i say there is a 50/50 chance one of my rl's the valves bent and the other car everything was fine i just slapped a new belt one and drove.
LEGEND95GS is offline
Old 01-18-07, 08:53 AM   #7 (permalink)
Car 1: acura
let's put it like this:timing belt breaks=new engine.now you can believe what you want or whatever you hear but you will need a very expensive fix.
acuranut is offline
Old 01-18-07, 11:22 AM   #8 (permalink)
Car 1: 96 Legend
dood this isn't a 13:1 high compression motor. It's more like 2 3/4s of a Civic D series motors put together.
Old 01-19-07, 06:28 PM   #9 (permalink)
kyoso23's Avatar
Car 1: '94 Sirius Pearl GS
Car 2: '98 4Runner SR5 4x4
Car 3: '91 Integra LS/VTEC
Doesn't have to be high compression to be an "interference design". From aa1car.com:
On interference engines, a timing belt failure is really bad news because there is not enough clearance for the valves to clear the pistons if the belt snaps. A belt failure on an interference engine almost always results in one or more bent valves - or worse. That is why timing belts should be replaced at the recommended interval.
Regular belt replacement is especially important on Acura and Honda engines because almost every one of these engines is an interference design! The only exceptions are the 3.2L V6 in the 1998 and newer Acura SLX models, and the 3.2L V6 in 1994 and up Passports. With Toyota, there is less risk of additional engine damage because the only Toyota interference engines are the older 1.5L Tercel, 2.4L Pickup and 1.8L Camry and Corolla engines. Apparently, Toyota engineers were more generous with combustion chamber clearances than Honda engineers.
1994 GS
mang!
kyoso23 is offline
Old 01-19-07, 09:45 PM   #10 (permalink)
A murder of Scarecrows Champion, Just Not Cricket Champion
Kenso's Avatar
Car 1: ITR 00-106
Car 2: 95 FZJ 80
iTrader Score: 26 reviews
The C35 is definitely an interference motor. A recall an RL that was towed in to our dealership, wouldn't start. The owner had tried to do his own timing belt and got it wrong...bent the crap out of the valves.
ITR 00-106
95 FZJ-80
Kenso is offline
Old 01-22-07, 11:30 PM   #11 (permalink)
Car 1: 1997 Acura TL 3.2 Premium
Car 2: 2002 Acura 3.5 RL
Car 3: 1991 Honda Prelude
All Honda engines are interference motors
Ken1997tl is offline
Old 01-25-07, 09:00 AM   #12 (permalink)
Car 1: acura
it's inference not interference
acuranut is offline
Old 01-26-07, 06:35 PM   #13 (permalink)
Kenso's Avatar
Car 1: ITR 00-106
Car 2: 95 FZJ 80
It's interference, meaning if the belt breaks, the valves and pistons will interfere with one another.
B-series motors don't seem to be interference, I've replaced broken belts on several and never encountered one with bent valves.
ITR 00-106
95 FZJ-80
Kenso is offline
Old 01-30-07, 07:48 AM   #14 (permalink)
Car 1: acura
ok kenso check it out it 's inference not interference but you can call it what you want.
acuranut is offline
Old 01-31-07, 08:13 AM   #15 (permalink)
Its INTERference.
Do a google search on Inference and Interference. You lose.
Closed Thread
DIY Water Pump Replacement lycan First Generation Legend (1986-1990) 10 06-03-16 01:58 PM
Timing Belt Instructions 5spdLegend Second Generation Legend (1991-1995) 2 01-17-13 04:08 PM
1999 RL Timing Belt Related Problem? timthetoolman First Generation RL (1996-2004) 5 05-22-04 03:43 PM
Just had my timing belt changed and now possible over heating? HiTek21 Second Generation Legend (1991-1995) 2 04-02-04 01:52 AM
reprocussions of not changing the timing belt flashdragoon First Generation Legend (1986-1990) 12 03-24-02 08:39 PM
