Steering wheel tilt problem? - The Acura Legend & Acura RL Forum
Old 12-24-06, 03:49 AM   #1 (permalink)
S Y T F U
Car 1: 1996 Integra SE
Car 2: 1993 Accord LX
Car 3: 1998 3.5RL
I'm having a problem with my power tilting steering wheel control. I can move the wheel towards and away from me with the button/switch on the side of the steering column, but when I try to move it up or down, it doesn't work.
I'm not sure what is wrong with it. Could it be the switch/button itself?
DC4KiD is offline   Reply With Quote
Old 12-24-06, 04:30 PM   #2 (permalink)
Car 1: 96 Legend
I think there are 2 different motors to control each movement. One motor must be having issues.
3g Legend is offline   Reply With Quote
Old 12-24-06, 10:46 PM   #3 (permalink)
Super Moderator
J Witherspoon's Avatar
Car 1: 2004 Acura 3.5RL
Car 2: 2005 Chevy Tahoe z71
Send a message via AIM to J Witherspoon
http://www.acuraworld.com/forums/showthread.php?t=67132
J Witherspoon is offline   Reply With Quote
Old 06-16-07, 08:44 PM   #4 (permalink)
Car 1: bmw
Car 2: acura
Car 3: rl
Cool tilt steering 1996 rl
I tested my motors with my battery and they work , but when I put them back they dont work. I dont hear any noise when I try the switch. Please help my wheel is stuck in a horrible position . It might be a relay I think but I cant find it
albert2003 is offline   Reply With Quote
Old 06-17-07, 01:22 AM   #5 (permalink)
Super Moderator
please see post #3, click the link and read the thread if you haven't.
If your motors are good, then one of the gears is fucked.
Old 06-17-07, 03:56 PM   #6 (permalink)
Car 1: bmw
Car 2: acura
Car 3: rl
Unhappy tilt steering 1996 rl
i changed the gears . I also plugged the moter in to the original plug and no movement. i tested it again with a 12 volt battery and it works . So I cant figure it out . The fuse is good , So maybe it could be a relay ?
1996 acura rl
Old 06-19-07, 02:20 PM   #7 (permalink)
Ultimate DIYer
97_RLer's Avatar
Car 1: 97 RL Premium w/ NAVI
I have had the same problem with you. In my case the up/down motor won't working. I took the motor out and test it with 12V battery but it was fine. Then, I looked up the gear assembly which is made of teflon (soft plastic) and I found the teflon gear assembly was broken. The teflon gear is so easy to be broken like as window regulator problems (I would say more than 90% of them is the teflon assembly). The motor would try to rotate but it stuck on the broken teflon gear.
You need to replace it but it should be expensive. I just glued it with epoxy and it worked fine. After that I'm not using auto steering position function just in case.
97_RLer is offline   Reply With Quote
Old 09-30-10, 05:02 PM   #8 (permalink)
Car 1: 02 Honda Legend
Car 2: 07 Dodge Magnum SRT8
tilt problem
Found this old post. I have 2002 RL with the same problem. In/out is OK but up/down doesn't work. I have confirmed the problem is the broken gear. Do we really have to replace the entire column to fix this??
oiler1fan is offline   Reply With Quote
my steering wheel feels funny? Dreams94coup Second Generation Legend (1991-1995) 4 12-04-05 12:42 AM
Tilt wheel on the base models? 92Legendsedan Second Generation Legend (1991-1995) 18 03-22-05 09:58 AM
power tilt wheel problem jgator286 Second Generation Legend (1991-1995) 2 11-06-04 07:53 AM
Steering Wheel Problem calegend27 Audio, Video, & Electronics 0 02-11-03 03:05 AM
Steering wheel electrical travelinman Second Generation Legend (1991-1995) 0 04-15-02 01:24 AM
