Go Back   The Acura Legend & Acura RL Forum > The Marketplace > Group Buys
Group Buys This forum section is for Group Buys & for paying Acura-legend.com Sponsors to post sales to the Legend Community.
LinkBack Thread Tools Display Modes
Old 01-25-08, 10:12 AM   #256 (permalink)
mods: yes PLEASE!!!!
bboarder711's Avatar
Car 1: 1995 SE white/silver
Car 2: Flexdex Pro 36
Car 3: Nikon D70
OOOOO funny story
I get a phone call this morning from my mom. She wants to use a classier car then her 01 Pathfinder to go get here hair and nails done and then take it to this party this weekend. So the cars been in storage at home with a repaired BHG and newly installed Damper. Well im woken up to my mom complaining about this thuding type of sound under the dash in right about the center of things. So I tell her what it is and just to be care full while on the throttle.
I thought i should share. Im waiting for another phone call when she realises how much faster the car indeed is
My Mission:
-To create the hottest OEM "looking" legend.
http://www.legendaryphotos.net <-- Recently updated!!!
A-L.com T-shits for sale! <-- Click
Originally Posted by drtom182 View Post
just recieved mine today! great quality!!! i recommend to everyone thats a legend enthusiast!
fits too!
thanks again!!
bboarder711 is offline
Old 02-14-08, 03:11 AM   #257 (permalink)
Car 1: 1996 SC400
Car 2: 1994 C32A TypeII 6sp
Car 3: 2005 Kawasaki 600
I want a red one. How soon can i get one and how much are they normally. Let me know and I'll grab one.
Nos94coupe is offline
Old 02-14-08, 03:17 AM   #258 (permalink)
Car 1: 1996 SC400
If its not still going on can I still get one???
Old 02-14-08, 11:53 AM   #259 (permalink)
Blackend Motorsports
Blackend's Avatar
Car 1: Blackend Motorsports
Car 2: 1995 LS Coupe
See HERE but I need to change that post since we did away with the colors when we revised the damper. They now only come in carbon fiber...
Will have pics up soon as I have one in my hand.
NALM NAZI
We Brought Them
We Broke Them
We WILL Rebuild Them Better!
Blackend is offline
Old 02-14-08, 12:15 PM   #260 (permalink)
Car 1: 1996 SC400
Thats all good Im gonna have a lot of carbon anyways. How much, I need 1 now. Let me know. I'd rather not wait.
Old 02-14-08, 12:19 PM   #261 (permalink)
Blackend's Avatar
Read this thread:
FS: Blackend Motorsports G2 Engine Damper Kits
It has all the details of how to purchase as well as pricing.
NALM NAZI
We Brought Them
We Broke Them
Blackend is offline
Old 02-15-08, 12:01 AM   #262 (permalink)
Car 1: 1996 SC400
Thanks dog.
Old 02-17-08, 07:12 PM   #263 (permalink)
Just Another Guy
Edify's Avatar
Car 1: '05 C6 Z51
Car 2: '91 Legend Coupe L
Car 3: 96 Tahoe/2005 Civic
I'm been having a tick that increases with engine rpm. I've actually thought it was a lifter, but now I'm starting to think its the damper. I had a louder tick and I tightened it and reinstalled and now its softer but rises with rpm. Any suggestions on how to fix this? Should I take it off and tighten it more? I have already flipped the damper (ie: adjuster toward firewall).
Also can I tighten/adjust it without taking it off? Also unlike a previous tick that went away if I had someone put pressure on the damper, this one stays.
-Ed
Edit: I took it off, tightened it. The distance between the bottom of the "preload adjusting plunger" and the top of the "Jan nut for preload adjusting plunger" is about 3/8 inch. Is that fully tightened? Also since I did that the distance between the "Jam nut for engine side heim joint" and the "engine side heim joint" is much less. Probably only 2 or 3 threads. Is that alright?
The clicking is a little bit quieter, and I mostly only hear it now between 1500rpm and 2000rpm.
Custom CAI - sr5guy stage II chip - EGR Block - TB Bypass - Blackend's Damper - Custom 2" Y Pipe - Magnaflow Cat - 2.5" B Pipe - Type II IM - Labrat Crank Pulley - NA1 NSX Rims - ME 6000k HID. 14.99 @ 94.12 before manifold, pulley, & rims.
Though I've fallen to the Dark Side!
Edify is offline
Old 02-18-08, 08:45 AM   #264 (permalink)
Blackend's Avatar
I have about 1/8 of an inch between the preload nuts so you should be fine there - you are able to almost get those two nuts to touch if you tighten it all the way so you still have some room if you're looking for more preload. I don't think that's where the noise is coming from though. I would check the firewall bolts and make sure they're not loose - in fact, check all the mounting bolts and make sure they're tight. If that doesn't fix the problem, lengthen the damper by half turns until the noise goes away. What I think the major problem is in the design is that the heim joints are floating, and that little bit of play that helps it articulate during flex, is causing vibrations through repeated use. If you try all this and it's still making noise - PM me.
NALM NAZI
We Brought Them
We Broke Them
Blackend is offline
Old 02-18-08, 12:03 PM   #265 (permalink)
Just Another Guy
Edify's Avatar
Car 1: '05 C6 Z51
I'll try that! Damper has worked wonderfully otherwise. Thanks a bunch.
Edify is offline
Old 02-18-08, 12:06 PM   #266 (permalink)
Blackend's Avatar
No problem. We've actually just revised the damper, and had a new one custom made that addresses a lot of these little annoyances - not that it helps you currently, but we are working to improve our designs based on feedback like this so please keep it coming!
NALM NAZI
We Brought Them
We Broke Them
Blackend is offline
Old 05-18-08, 04:33 PM   #267 (permalink)
So smooth, so TAN, mmmmm
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
Just installed mine FINALLY!
HOLY SHIT!
This car is becoming a beast!
Don't know if I like the 80A Shore hardness rear mount yet, that plus two brand new motor mounts it seems pretty stiff. 60A shore is less stiff correct?
DUAL REMUS IS PHOTOSHOP!
http://www.acura-legend.com/vbulletin/883766-post7.html
91 with type II engine, SR5GUY stage 3, hi flow cat, 6 speed tranny, 04 TL knob, EDM headlights, EDM spoiler, carbon fiber interior trim, type II cluster, OBX headers, 2 1/2" Catback to Remus Rev 3, CAI.
blkonblkcpe is offline
Old 07-10-08, 12:16 PM   #268 (permalink)
Member Elite
Blingting's Avatar
BUMP!
Thanks again Brian, you really went the extra mile for me installing that damper late the other night.
This thing does exactly what its supposed to do. Night and day difference.
Blingting is offline
Display Modes
Remus Universal Exhaust Group Buy- Ends (October 12th 2007) Thai.95LCoupe Group Buys 51 10-19-07 01:15 PM
G2 Acura Legend Engine Damper Group Buy Blackend Group Buys 389 09-29-07 12:48 PM
Interest In A 2nd Engine Damper Group Buy? Blackend Engine & Performance Modifications 76 09-04-07 02:43 PM
GB: Leatherseats.com 2007 Group buy!!! leatherseats.com Group Buys 135 06-29-07 06:19 AM
Anybody buy an engine from Speed Line Group??? BlackAc92 Second Generation Legend (1991-1995) 6 02-21-07 06:08 PM
