| Group Buys This forum section is for Group Buys & for paying Acura-legend.com Sponsors to post sales to the Legend Community. |
LinkBack | Thread Tools | Display Modes |
Ksport Kontrol Group Buy Round 6!!! $760 Shipped!!!
Ksport Kontrol Group Buy Round 6!! $760 Shipped!!!!
I have received many PM's pertaining to interest in another Ksport GB so here it is. As of now Ksport is well stocked with the Legend Specific Suspension system so their should not be any problems in terms of a expected delivery date once we get the 5 buyers needed to have another succesful GB. There is plenty of information available on this forum that will help you learn about the suspension system as well as the pros and cons. Here is a brief description of what the set-up consists of.... Ksport Kontrol Pro Coilover suspension system!!After doing some home work I found a distributor that can deliver a set of Ksport Kontrol Coilovers for $760.00 shipped to your door! However we will need a minimum of 5 buyers, which really is not that many at all for a GB that can get you the Ksport system for almost $100 cheaper than the other guy. This kit retails for $1200.00! So get in on this GB and save a ton of money!! Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability. The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride. The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance. Many members here on the forum are using the Ksport Kontrol suspension system and they love it. I have herd great things about the suspension and as you will see from doing your own research here on the forum, they have gotten great reviews. Key Features: 36-way adjustable dampening Made from high quality 6061 Aluminum with T6 for increased hardness Compression/Rebound adjustable Adjustable spring perch for height adjustment Adjustable body allowing maximum suspension travel Monotube High Pressure Design reduces oil leakage Electroplated body for protection from corrosion and rust One Year Limited Warranty Here are some testomonies from previous buyers.. http://www.acura-legend.com/vbulleti...d.php?t=105033 http://www.acura-legend.com/vbulleti...ghlight=ksport I will request that we start sending payment when we have met the 5 buyer mark, so until then post up here and let me know if you are in on this GB. The GB end date is July 1st 08, so please get your chips together by then. in order to complete this GB we will need a minimum of 5 buyers. 1) Legendfire 2) Legend320 3) 4) 5) 6)
SIG BY ALPEROVICH MODS---ALL OF THEM!!!!!!!! Check out my gallery! http://www.acura-legend.com/vbulleti...ebirth-126357/ The project... http://www.acura-legend.com/vbulleti...thread-120596/ Ksport Kontrol Group Buy!! $760 Shipped http://www.acura-legend.com/vbulleti...ed-123764-new/ Last edited by emaculate91ls : 08-10-08 at 02:58 PM. |
I luv ur girl...
i wana be in on this so damn bad...if somehow i can get in i'll def run back and let u know...good luck on the gb tho..and hopefully u'll keep em goin until i can get in on one.
'94 Geo Metro-gone-(moment of silence please, 45mpg, died with a full tank) '91 Legend-(sittin outside bitches.) Aruca Mods:18x7.5 Bigg Bill Wheels Brembo Blank Rotors Akebono Pro-Act Ultra Premium Brake Pads |
The Infamous one
good luck on this one emaculate1 u always get the good group buys anyway... btw im broke yall if this happens again in october then maybe but for now consider me lower middle class broke
Fall '08 MLS Copy Strut Tower Bar Group Buy 4 Buyers Paid - 10 Needed Before Production Phase Begins---->http://www.acura-legend.com/vbulleti...up-buy-128195/ |
The Infamous one
if this goes well there will be another one right in the later future
Do you know what you are going to do yet?
SIG BY ALPEROVICH MODS---ALL OF THEM!!!!!!!! Check out my gallery! http://www.acura-legend.com/vbulleti...ebirth-126357/ The project... http://www.acura-legend.com/vbulleti...thread-120596/ Ksport Kontrol Group Buy!! $760 Shipped http://www.acura-legend.com/vbulleti...ed-123764-new/ |
I thought you just bought a coupe and why do you want to buy a legend specific catalyic converter from me?
#15 (permalink) | ||
I wouldn't say that this GB is a total failure yet, its just taken much longer than the last 5. Lets try to spark some more interest.
