Go Back   The Acura Legend & Acura RL Forum > The Marketplace > Group Buys
Group Buys This forum section is for Group Buys & for paying Acura-legend.com Sponsors to post sales to the Legend Community.
LinkBack Thread Tools Display Modes
Old 07-07-05, 03:14 AM   #1 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
Lightbulb Group Buy: Wilwood Brake Kit
If we can get seven orders (each part front or rear counts as a single
order), then we get 25% off the price. If we can get five orders,
then we get 20% off the price. Plus, we get a free 6-pack of break fluid.
The rotors come with your choice of BLACK or SILVER zinc plating.
I believe the calipers come in RED, BLACK or SILVER.
Shipping and handling is free.
I'm buying a front and rear kit, so that's two orders right there.
This was taken directly from the precisionbrakes.com PDF file
(note that the prices do NOT reflect the discount):
323 millimeters = 12.7165354 inches
330 millimeters = 12.992126 inches
22 millimeters = 0.866141732 inches
28 millimeters = 1.1023622 inches
30 millimeters = 1.18110236 inches
Part # 14-HA-0007
Description - PBC Front Kit - Acura Legend Sedan (Except GS), 91-95 - 323mm x 30mm, 1-pc. - Plain Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $999
Part # 14-HA-0007-S
Description - PBC Front Kit - Acura Legend Sedan (Except GS), 91-95 - 323mm x 30mm, 1-pc. - Slotted only Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $1,119
Part # 14-HA-0008
Description - PBC Front Kit - Acura Legend Coupe, 91-92 - 323mm x 30mm, 1-pc. - Plain Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $999
Part # 14-HA-0008-S
Description - PBC Front Kit - Acura Legend Coupe, 91-92 - 323mm x 30mm, 1-pc. - Slotted only Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $1,119
Part # 14-HA-0009
Description - PBC Front Kit - Acura Legend Coupe & Sedan (all), 91-95 - 330mm x 28mm, 1-pc. - Plain Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $1,099
Part # 14-HA-0009-D
Description - PBC Front Kit - Acura Legend Coupe & Sedan (all), 91-95 - 330mm x 28mm, 1-pc. - Cross drilled Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $1,164
Part # 14-HA-0009-S
Description - PBC Front Kit - Acura Legend Coupe & Sedan (all), 91-95 - 330mm x 28mm, 1-pc. - Slotted only Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions 1,164
Part # 14-HA-0009-X
Description - PBC Front Kit - Acura Legend Coupe & Sedan (all), 91-95 - 330mm x 28mm, 1-pc. - Drilled & Slotted Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $1,284
Part # 14-HA-0010
Description - PBC Front Kit - Acura Legend Coupe & Sedan (all), 91-95 - 330mm x 28mm, 2-pc. - Plain Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $1,299
Part # 14-HA-0010-D
Description - PBC Front Kit - Acura Legend Coupe & Sedan (all), 91-95 - 330mm x 28mm, 2-pc. - Cross drilled Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $1,299
Part # 14-HA-0010-S
Description - PBC Front Kit - Acura Legend Coupe & Sedan (all), 91-95 - 330mm x 28mm, 2-pc. - Slotted only Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $1,299
Part # 14-HA-0010-X
Description - PBC Front Kit - Acura Legend Coupe & Sedan (all), 91-95 - 330mm x 28mm, 2-pc. - Drilled & Slotted Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions $1,299
Part # 14-HA-0011
Description - PBC Rear Kit - Acura Legend Coupe & Sedan, 91-95 - 330mm x 22mm, 2-pc. - Plain Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions - Internal drum style park brake $1,499
Part # 14-HA-0011-D
Description - PBC Rear Kit - Acura Legend Coupe & Sedan, 91-95 - 330mm x 22mm, 2-pc. - Cross drilled Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions - Internal drum style park brake $1,599
Part # 14-HA-0011-S
Description - PBC Rear Kit - Acura Legend Coupe & Sedan, 91-95 - 330mm x 22mm, 2-pc. - Slotted only Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions - Internal drum style park brake $1,499
Part # 14-HA-0011-X
Description - PBC Rear Kit - Acura Legend Coupe & Sedan, 91-95 - 330mm x 22mm, 2-pc. - Drilled & Slotted Rotors, Wilwood 4 Piston - Dynalite Calipers, Brackets, Pads, SS Flex Hoses, Hardware, Instructions - Internal drum style park brake $1,619
The kit (in red) looks like:
1. khoerling (14-HA-0010-X)
2. khoerling (14-HA-0011-S)
3. You!
4. You!
5. You!
6. You!
7. You!
mrkeith is offline
Old 07-07-05, 03:39 AM   #2 (permalink)
'hood Garage
hotlavaflow's Avatar
Car 2: KA24DE-T S13
I wish I had money like that.
DO NOT FEED THE ANIMALS
hotlavaflow is offline
Old 07-07-05, 10:36 AM   #3 (permalink)
Car 1: .
Excelent! Can we get some details like:
Plating on disk?
Manufacturer of Pads?
Manufacturer of SS lines?
What is the Size of the OEM Disk? I am assuming this is a larger disk because of the new brackets.
That price is awsome!
Later!
Lee
sleeprlegendcp is offline
Old 07-07-05, 11:06 AM   #4 (permalink)
K L E A N M O D™
Thai.95LCoupe's Avatar
Car 1: 1995 KA8 *R.I.P*
Car 2: 1997 S14 *SOLD*
Car 3: Millenia S & S14
The wilwood calipers are sooo small looking. I'm going for the GT F50 4-pot caliper.
-1995 KA8 MODIFIED-R.I.P
-1997 S14a-SOLD
-2000 Millenia S
-1995.8 S14a
-Holy Rollerz CCC Member-
-Inspiration™-
Thai.95LCoupe is offline
Old 07-07-05, 11:07 AM   #5 (permalink)
Canis Lupus
Car 3: 1989 240SX 5 speed
Send a message via AIM to Blood Riot
Wow....$2,783...and thats not even the labor to put them on and S&H...wow...um...damn I wish I had that ammount laying around...
Blood Riot is offline
Old 07-07-05, 11:22 AM   #6 (permalink)
Car 1: G2 legend, 240sx
Send a message via AIM to sr240dett3 Send a message via Yahoo to sr240dett3
Do you really need that much stopping power?
It’s a luxury style car... Not a sports car
Well then again I haven had my car very long
And haven’t driven it more then a half a dozen of times (BHG)
But once the head gasket job is done,
Ill makes sure to take note on how good
The stopping power of the factory braking system
Maybe some upgrades rotors, and some nice axxis pads? Will do for me
sr240dett3 is offline
Old 07-07-05, 01:50 PM   #7 (permalink)
Car 1: 1991 Cobalt Blue KA8
Car 2: 1998 Kouki (sold)
Send a message via AIM to Gerald
Say what?!?!?!?
http://img.photobucket.com/albums/v502/acura_lover_85/Best-Night-Pic23again.jpg
Help Me Find White/Black KA8
Gerald is offline
Old 07-07-05, 02:01 PM   #8 (permalink)
K L E A N M O D™
Originally Posted by Blue_Raspberry
Say what?!?!?!?
-1997 S14a-SOLD
-2000 Millenia S
-1995.8 S14a
-Inspiration™-
Old 07-07-05, 02:03 PM   #9 (permalink)
That's not cool man. Damn you and this waiting stuff!!!!
Oh, the console just adds a completely different look to the interior. Thanks man
Gerald is offline
Old 07-07-05, 02:08 PM   #10 (permalink)
LS92Sedan's Avatar
Car 1: 94 L Sedan Caterbury Green
Car 2: 94 L Sedan (white)
Car 3: (RIP) 92 L Sedan
I wish I had $ for a willwood kit, they are VERY nice, but I am going a cheaper route, Type 2 front calipers and rotors, with a set of brembo cross drilled front and rear, some axxis carbon metallics, and some stainless lines, once you guys get this all figured out and get one of these kits installed I would be real interested in seeing how it performs, keep us updated
LS92Sedan is offline
Old 07-07-05, 02:12 PM   #11 (permalink)
K L E A N M O D™
That was the best one I ever came across you scored on that one.
-1997 S14a-SOLD
-2000 Millenia S
-1995.8 S14a
-Inspiration™-
Old 07-07-05, 04:44 PM   #12 (permalink)
werd.....
RangerJoe's Avatar
Car 1: 92 LS coupe 5spd
you could install them yourself in a couple hours, you only need a 14mm socket, a 17mm socket, and a screwdriver to pull the old rotors off. (maybe a 12mm for the brake line removal)
shipping and handling is free.
http://g2legend.com
RangerJoe is offline
Old 07-07-05, 05:10 PM   #13 (permalink)
Gride_Cruiser's Avatar
Car 1: 1991 KA8
Wilwood is definitely good stuff.
Gride_Cruiser is offline
Old 07-07-05, 11:07 PM   #14 (permalink)
Car 1: .
Originally Posted by hondaman23
But the Type2/LS calipers can do a very suffcient job. The limiting factors are the rotors and pads. Buy some Ferodos & slotted rotors and you will never look back. They dust, yes. But they stop and modulate extremely well. I took the coupe out at VIR on those brakes and the only thing that I lacked was tires. For a 3600 lbs car, I was more than happy and I drive Civics with huge brakes!
Now, this thread did not come about due to performance totally. I don't know of anyone on this forum that really uses their car to the max. Dragstrips don't use brakes and ScotcH is the only one that ran a track other than me (it seems) and he did not complain of brake problems. This is a shout out to those who would like to have a premium set of brake calipers that stop well and LOOK beatuiful. Some of you have the jack to put into a set of brakes that are some of the best in the world, but you would never use them. My point, mainly for looks, but still great brakes.
These are not for the monitarily challenged, but with what khoerling has going, you will not find a better deal on new Wilwood stuff.
Honestly I would use every bit of this kit. I don't even own a G2 rignt now and I am very interested in this kit, but I do have most G2 mods . I do track my cars and drive them hard daily. The mixture of the larger rotor diameter, more clamping force, and just the fact that you have brand new hardware will greatly up our braking force.
Later!
Lee
Old 07-07-05, 11:30 PM   #15 (permalink)
Dood-Wala
nasriaz's Avatar
Car 1: 1993 Legend LS Coupe.
Car 2: 2005 Acura TL
Send a message via AIM to nasriaz
SWEEEET!!! I'm so tempted. If I get my 05 Maxima sold sometime soon I may be interested.
nasriaz is offline
Display Modes
Brake problem dheerajacura Second Generation Legend (1991-1995) 19 03-03-05 06:22 PM
Trim Kit Group Buy going on.. Ballistic Second Generation Legend (1991-1995) 4 08-26-04 05:07 PM
Brembo, Bradie Rotors Axxis/PBR Brake Pads Group Buy Part II BrakeCialist168 Group Buys 40 07-22-04 12:59 PM
Velox Group Buy upto58% off - Progear/Vx available mYbabYLeGend OEM Parts 0 04-26-03 12:08 PM
Body Kit Group Buy LegendMS Second Generation Legend (1991-1995) 27 04-03-02 08:45 AM
