FS: 1989 Legend Coupe LS - The Acura Legend & Acura RL Forum
Go Back   The Acura Legend & Acura RL Forum > The Marketplace > Cars For Sale > Legends For Sale
Legends For Sale Post your Legend, RL, or other for sale in this category.
Old 04-29-10, 01:34 PM   #1 (permalink)
Car 1: 1989 LS Coupe
I've decided to sell my 1989 Legend LS Coupe. It currently has 144k miles on it, bought used in 2002 with 102k miles on it. Many of you may know me from the Gen1 section several years ago, newer members probably won't. You can search to find out about my history with this coupe. Anyway, it's time for me to move on and sell the coupe, and hopefully someone can benefit from all that I've put into it, and all the extra parts that I have accumulated over the years.
Here's the lowdown on the coupe:
Car / engine runs strong, but the transmission slips when cold, not so much when warm. I haven't gotten around to cleaning / flushing the transmission solenoids, so I have no clue if that would cure the slipping, but it does have one of the symptoms of clogged shift solenoids from time to time - namely the flaring of the engine speed during shifting. Assume that a new / rebuilt tranny or manual swap is needed - if not, bonus for you if you end up buying it.
Shift position console switch should be replaced before the colder months (replaced once before). Issue is that "D, S3, S4, and 2" does not light when it's cold out - causes erratic shifting since there is no communication between the TCU and the instrument cluster. Jiggling the shifter will work, but depending on how cold it is, lighting in the cluster may be not be immmediate. Do a search on the forum for more info as I've posted before. The old switch is provided, so regreasing with dielectric grease may fix the issue for minimal cost. Currently not an issue with the warmer weather.
Center console armrest hinge is almost completely broken - hanging on only by the back end. I planned to repair it with miniature plastic hinges and screws that I picked up at a hobby shop. Haven't gotten around to it, but will provide the parts for you to do so.
Typical rust by the gas cap door, and rear wheel wells. Dent in the hood from the previous owner colliding with a golf cart. Lower air dam torn from the same incident, but repaired so it isn't hanging. Paint is in decent condition, still shines.
Here's the good stuff:
ABS still works
A/C has had an R134 conversion, and blows cold
new Optima battery (July '09)
OEM carpeted floor mats in excellent condition (bought NEW in a eBay auction a couple of years ago)
Tokico HP (blue) shocks
new / rebuilt starter (April '10)
new OEM distributor assembly (Oct '08)
new OEM main relay (Jul '09)
new OEM starter relay (Jul '09)
replaced front (Oct '04 @ 116.5k miles) and back (Jul '05 @ 120k miles) seats skins with new from Leatherseats.com (group buy) - full leather seating surfaces in front, leather inserts in rear
added seat heater to front seats, switches integrated into center console in OEM location (Oct '04 @ 116.5k miles)
16" Acura CL rims with Good Year Eagle RS-A 205/55HR-16 tires. Tires purchased May '08. Good amount of tread left.
'90 tail lights with white turn signal portions
'90 LS center console wood trim, including climate control unit
JVC head unit with HD radio reception and CD
Infinity speakers - doors and rear deck
Crimestopper aftermarket alarm integrated with OEM alarm to allow for two layer security protection. OEM alarm armed by manually locking doors, aftermarket by remote. Both disarmed by remote. Remote trunk release.
Ford Taurus cupholder / change drawer modification (integrated into center console)
Filtrevedo retractable rear sunscreen
35% Llumar tint all around (except windshield)
Stromung Stainless Steel catback exhaust (group buy)
Hella Micro DE foglights mounted in OEM location with matching cutouts in lower bumper inserts and OEM foglight switch in dash
Technafit SS braided brake lines
9004 "free" headlight bulb modification (65w low beam/45w high beam)
9004 Sylvania Silverstars in inner high beams
OEM Acura Accessory Leather steering wheel cover
Here are the spare parts:
OEM rear seat back with seams that are still good (purchased from a forum member before I did the Leatherseats group buy)
OEM 15" rims with tires
(1) extra OEM '90 15" rim with tire
original OEM leather seat skins (kept after replacement) still in good condition, but torn seam on passenger seat, and rear seat headrest. Driver seat skin was sold off a while ago.
original black center console trim, including climate control unit
extra '90 woodgrain climate control unit
original Nippon Denso starter (use as a core, or rebuildable with parts from Larry B's starter contacts)
original '89 tail lights with amber turn signal portion
extra set '90 tail lights with white turn signal portion
flannel (indoor use) car cover
extra '90 instrument cluster
extra passenger side door / armrest pocket
extra driver side airbag
NEW OEM air filter
(3) OEM Oil FIlters
NEW aftermarket power antenna
CV joint boot kits
original front engine mount (still good, replaced at 113.5k miles)
NEW combination switch (sedan)
NEW OEM brake master cylinder
NEW / rebuilt alternator
NEW OEM speedometer cable
(3) new OEM tail light gaskets + (1) used in good condition
NEW Repco Metal Master front brake pads
NEW Satisfied Pro rear brake pads
extra driver side door handle
extra passenger side hood hinge
extra ignition switch harness (5,600 miles on it - new replacement on another coupe, and subsequently removed 5,600 miles later when the coupe was scrapped)
extra fuse box (5,600 miles on it - new replacement on another coupe, and subsequently removed 5,600 miles later when the coupe was scrapped)
extra main relay (5,600 miles on it - new replacement on another coupe, and subsequently removed 5,600 miles later when the coupe was scrapped)
extra lower bumper inserts
NEW OEM axle spindle nuts
NEW OEM miscellaneous suspension, exhaust, and brake hardware
extra OEM foglight switch
extra radiator fan control unit (still good)
extra starter relay (still good)
extra sunroof switch
extra memory seat switch
miscellaneous spare trim pieces
NEW OEM CVC valve
'89 Factory service manual
'90 Factory service manual
Haynes service manual
Chilton service manual
I'm asking $1,000 for the car with everything listed. Extra parts alone would total several hundred $ on eBay or the dealer for the new parts. PM me or reply if you are interested or if you have any questions.
Car is located in Nassau County on Long Island, NY.
** MORE PICS: Pictures by chuckee98 - Photobucket
chuckee98 is offline   Reply With Quote
Old 05-03-10, 02:30 AM   #2 (permalink)
Car 1: 87 ACURA LEGEND COUPE (BASE)
does that engine have the screw off oil filter or the one with the 3 bolt's like the 87 has...? and do you think it would be possible to swap out that engine and put it into and 87 legend coupe...?
AC-N-UP is offline   Reply With Quote
Old 05-03-10, 08:07 AM   #3 (permalink)
Screw on/screw off filter (3 OEM Honda filters provided). Not sure if it is a straight swap with an '87. There should be info in the forum of someone who has done a swap, or post the question, and someone can give insight.
Thanks for looking.
Old 05-03-10, 11:32 PM   #4 (permalink)
Car 1: 1989 Acura Legend L
I was wondering if you sold the car yet? I have an 89 myself and would love a part car or something to play with that's not my daily driver.
mxsloan is offline   Reply With Quote
Old 05-04-10, 07:03 AM   #5 (permalink)
Car is not sold yet.
Old 05-04-10, 11:29 PM   #6 (permalink)
Fut
Car 1: Blk/Blk '94 GS 6 Speed [+] '90 LS 5 Speed Sedan
iTrader Score: 33 reviews
Send a message via AIM to Fut
Oh shit! Too bad I'm broke
One...
Fut
G1 Lowering Control Arms Group Buy
6 Confirmed Buyers - 4 Additional Buyers Needed
Fut is offline   Reply With Quote
Old 05-05-10, 10:59 PM   #7 (permalink)
Super Moderator
C27A1Legend'88's Avatar
Car 1: 1988 Acura Legend Coupe L
That is a clean G1, but I have no more room for more cars. Somebody will buy it for sure.
1988 Acura Legend Coupe L 5-MT
Truly Legendary...
C27A1Legend'88 is offline   Reply With Quote
Old 05-06-10, 09:30 AM   #8 (permalink)
CEN2MENTAL95's Avatar
Car 1: 95 L Sedan
Car 2: 95 LS Coupe
Car 3: 01 Toyota 4 Runner
Send a message via AIM to CEN2MENTAL95
I am local and that car is clean (minus the rust)...if it didn't have a slipping tranny, it would've been sitting in my driveway!
CEN2MENTAL95 is offline   Reply With Quote
Old 05-06-10, 10:08 AM   #9 (permalink)
Car 1: 95 L Sedan
Car 2: 95 LS Coupe
chuck...get at me....I'd like to see this in person and test drive it...always wanted to drive a G1..... maybe it'll convince me to take the plunge anyway
Old 05-06-10, 01:18 PM   #10 (permalink)
PM sent.
Old 05-10-10, 04:39 PM   #11 (permalink)
Car 1: 95 L Sedan
Car 2: 95 LS Coupe
hey guys...if anyone is interested in this car and has plenty of G1 tranny knowledge (or a spare G1 autotragic tranny) then they should scoop this up. I was lucky enough to have the privilege of driving this beautiful coupe on saturday and it was a thorough pleasure
if the tranny didn't slip as bad as it did and I was more in tune with the G1, this car would be currently in my driveway.
Old 05-21-10, 04:36 PM   #12 (permalink)
SOLD! To a good home and long time forum member.
