Well Wisher
DIY: G2 Manual Transmission service with pictures *5 & 6 speed*
that's just a drain and fill...and unfortunately the pics are no longer up. check out the online service manual: Acura Legend Online Service Manual (Page: 0317) the drain and fill plug are near your front right tire hope that helps! I noticed smoother shifting after replacing the fluid in my 6MT GS
'94 GS 6MT Exterior: JDM headlights & rain visors <> paint job <> retro '91-'93 OEM fogs & bumper <> 17" Konigs Performance: tuned Apexi SAFCII <> Sr5Guy chipped ECU <> Blackend engine damper <> MLS strut bar <> sr79labrat pulleys <> OBX headers <> Custom Y-pipe, Magnaflow Cat & Resonator, Stromung B-pipe & Muffler (All 2.5") <> TB Bypass <> RJ CAI w/ AEM bypass valve <> cross drilled/slotted rotors <> RJ short shifter <> ground wires Interior: Kenwood DDX6019 w/ NAV & Ipod, 2-tone leather |
more power? yes please!
I smoothed out the shifts in my manual trans with some penzoil syncromesh (sp?) It really helped cut down on how much I snag second gear.
The Sherwood Family 95L (back b4 june?) 3.5 A/T 4dr 168K • 94LS Daily project car 2dr 6spd 180K • Little Bro 93LS A/T 4dr |
WINGS + PISTONS
Thanks guys, I love the Halo guy jkurl haha... I am beginning to think my 220k miles Legend is behind on maintenance. Fuel filter looks original, ac filter is original, dont know too much more about it yet... plugs were bad, but the car is still awesome, no issues at all, I got it inspected at the Acura dealership and no problems at all.
Starting to do maintenance on the car, already did the plugs (NGK Iridium IX), new front pads and rotors. New rear rotors and pads next week, new ac filter soon, new fuel filter (after I get the stupid bolt off). |
#5 (permalink) | |
Nice ride you got... by the way.
Mellow Legend Gallery Link Stromung Exhaust Feb 2008 special!!! Buy Count Final: Muffler = 27 |
#7 (permalink) | |
genuine honda ATF only! accept no substitute, sold at any honda acura stealership.
#10 (permalink) | |
trans and dif are both similar in that there is a low plug to drain then a fill plug halfway up the side of the case or so that you pump your fluid in right till it spills back out then put the plug in, done. Good quality 80-90w gear oil for the differential, syncromesh or good 30w for manual trans. EDIT Correction 30w not for differential but for manual trans. 10-30w actually.
The Sherwood Family 95L (back b4 june?) 3.5 A/T 4dr 168K • 94LS Daily project car 2dr 6spd 180K • Little Bro 93LS A/T 4dr Last edited by jkurl : 04-10-08 at 01:21 AM. Reason: !BAD INFO CORRECTION! |
does amsoil make a honda formula atf? how many miles have you had with what type of amsoil in your tranny, very curious. Amsoil seems like good stuff pricey but good, I never realized they might have a good atf with enough silicone in it, so the question is do they?
#12 (permalink) | |
Its a Legend baby
#13 (permalink) | |
'01 3.5l rl engine- 6 speed swap done!, type2- cams, valve springs/retainers, and intake manifold. ground control, koni, addco-front & rear, mls copy, 18" volk III rm racing intake, gasket match ported exhaust manifold, light weight pulleys, telion chip, tranny cooler and a bunch of door dings ~from haters |
#15 (permalink) |
Wrong... 10W-30!! See the manual below. I believe the Synchromesh stuff are around 30 weight.
