87 octane vs. 89 octane vs. 93 octane... What's the difference? - The Acura Legend & Acura RL Forum
Old 03-10-06, 08:26 AM   #1 (permalink)
bamachem's Avatar
Car 1: 95 GS Auto Blk/Tan
Car 2: 00 Land Cruiser
i posted this in another topic, but thought some of you may find some value in this. (oh, and as far as my credibility is concerned - i'm a chemical engineer by degree...)
they will burn the same. no difference in carbon buildup within the samebrands. however, compare shell or chevron to an off brand and you can and will have more buildup w/ the off brand b/c they tend to have less detergents and poorer quality detergents in them.
now as far as power goes, you probably won't feel the difference. if the engine was meant to run at it's optimum on 93 octane and you put 87 in it, then it will simply retard the timing enough to prevent detonation. in doing so, you loose some power, but typically less than 3 or 4%. that's about 10-12hp and for the everyday driver, you'll never feel the difference. however, you will more than likely have a decrease in your efficiency (MPG's) if you drop from a recommended 93 down to 87 due to the engine retarding the timing. this is more noticeable on automatics than on manual transmission equipped vehicles due to the downshifting at cruising speeds from the loss of the top end power.
for fun, let's walk through a quick & dirty calculation with some assumptions:
15 gallon use of fuel. 93 octane is $2.50 and 87 is $2.30 per gallon. you normally get 27MPG with 93, but only 25MPG with 87. which grade is more economical to use?
for 93 octane:
15 gallons * 27 MPG = 405 miles, 15 gallons * $2.50 = $37.50 to fill up
405 miles / $37.50 = 10.8 miles per dollar -OR- 9.26 cents per mile
now for 87 octane:
15 gallons * 25 MPG = 375 miles, 15 gallons * $2.30 = $34.50 to fill up
375 miles / $34.50 = 10.87 miles per dollar -OR- 9.2 cents per mile
as you can see, if you gain a simple 2 MPG by using 93 octane, then it's a wash in cost even though it's $0.20 per gallon more to purchase. if you get MORE than 2 MPG better efficiency by using the higher octane fuel (or you can get it for LESS THAN $0.20 per gallon more than the 87 octane fuel), then you are acutally MORE EFFICIENT and CHEAPER to use the higher grade and higher cost fuel. this is totally independent of gas prices overall, and totally dependent on the difference in cost between the two grades and the difference in your MPG's between the two.
the reason that they require 93 is due to the high compression ratio of the engine. higher ratios means that during the compression cycle, the piston moves in the upward direction so far that the air inside is compressed. compression causes heat, and that heat can cause premature detonation of the fuel without the spark plug ever firing. this is detonation. the engine has a knock sensor and will detect pre-detonation conditions and will adjust engine timing accordingly to compensate.
also, if you have an older engine, you're more likely to get pinging (detonation). why is that? it's because older engines typically have some carbon buildup on the valves and on the piston head. those carbon deposits can get heated to very high temperatures while the engine is running and will actually glow (think of charcoal in a grill). those glowing embers will then ignite the fuel and cause detonation. using something like BG44K or Seafoam on a regular basis will remove the carbon deposits and therefore will reduce your chances of pinging.
why does 93 not ping when 87 octane will? it's in the octane rating. 93 is "harder to ignite" than 87. it doesn't burn any cleaner, or have more energy than 87 octane does. however, it requires more energy to initiate combustion, and therefore is less prone to detonation during the compression cycle or due to hot embers in the combustion chamber. also, like metioned before, 93 octane allows the engine to run at peak performance by allowing the timing to be as far advanced as possible.
on the contrary, for an engine designed to run on 87 and then you put 93 in it, you are simply wasting your money. the engine will still run the same and you won't notice a bit of difference in power or performance. absolutely ZERO difference. as long as it is well maintained w/ low amounts of carbon deposits that would normally cause detonation and lead to a retarted timing, then using 93 octane won't do anything but make you poorer.
oh, and one last thing... "the Saudis" don't get that extra $0.20 per gallon for the premium fuel. that goes to the refinery who cracked and distilled and blended the fuel and to the pockets of the station owner - all in the US. we don't get one drop of fuel in the US that is "made" outside of our borders.
as far as Mid-Grades go. it's really a waste. most older stations only have two tanks anyway - used to be for leaded and unleaded and now for low and high octane. when you buy mid, you are getting 89 octane, but that's also what you get when you pump the low-grade gas. look at the rating - it's a MINIMUM octane rating system. the two in-ground tanks are for 89 and 93. this is also very typical for lots of newer stations as well.
ok class. back to work...
bamachem is offline   Reply With Quote
Old 03-10-06, 08:51 AM   #2 (permalink)
Fish Hunter 2 Champion
SaGe69's Avatar
Car 1: 1992 Legend LS Sedan
bamachem,
Good post man! Very informative. Just a question however. Many of us have performance chips (ECU upgrades) that recommend that we use 92+ octane fuel once the chip is installed. My question is, what would the effects be on the engine if I continue to run regular (87 octane) fuel on an engine that has been chipped? Is there a bad outcome in the long run?
Its a shame that there is only one company that makes 94+ octane in Canada (Sunoco), everyone else tops out at 92 octane.
SaGe69
SaGe69 is offline   Reply With Quote
Old 03-10-06, 09:31 AM   #3 (permalink)
Destory The Peace Champion, Empty Santas Sack Champion, Attack from the Influenza Chickens Champion, Last Man Standing: Keg Stand Champion, Kill Kitties Champion
Car 1: 1992 Coupe LS {sold}
Car 2: 1992 Lexus LS 400
Send a message via AIM to Pito11213
Well around here in the city you get 93 octane and 94 with sunoco as you mentioned. I noticed a difference when going from 93 to 89 (had no choice cause prices were going crazy) now I am back to 93 and must say I wont go back. The difference is just too noticeable.
Pito11213 is offline   Reply With Quote
Old 03-10-06, 10:24 AM   #4 (permalink)
Fre OG
Shaylord's Avatar
Car 1: 1994 LS Coupe Dark green
Send a message via AIM to Shaylord
Legend VS. CL/TL
Originally Posted by 91LSMAN
Just drive in circles around them until their tranny dies.
Originally Posted by AcuraFan19
That could happen... however, your head gasket may blow before his tranny goes.
Proud member of the 200,000 Mile Club.
94 LS Coupe 6 Speed (208k)
92 L Sedan Auto (76k) ATM replaced with 06 RL Rental
92 LS Sedan Auto (156k) parts
92 LS Sedan Auto (177k) project/restoring to factory
00 RL (87k) Traded in for 06 RL
95 NSX-T 5 Speed (75k)
Shaylord is offline   Reply With Quote
Old 03-10-06, 12:47 PM   #5 (permalink)
champion91cpe's Avatar
Car 1: 91 Champion White L Coupe
LMFAO!!!!!!! Yea the only place i can get 93 octane is down the street at a Farmcrest gas station because I live at a higher elevation. The highest it goes up around here is 91 octane. I fill my legend and my porsche 944 up with 93 octane everytime because no matter how much it costs; it pays off in the long-run....if i run it on 87 or even 91 i get about 2-3mpg less......tits
http://x402.putfile.com/5/12114194881.jpg
1986 Porsche 944 Turbo
1991 Champion White Acura Legend L Coupe
champion91cpe is offline   Reply With Quote
Old 03-10-06, 04:04 PM   #6 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
Car 3: 95 LS 6 spd coupe
iTrader Score: 7 reviews
93 is higher octane then 89 which is higher then 87
Old 03-10-06, 04:05 PM   #7 (permalink)
bamachem's Avatar
thanks.
just added another comment in BOLD RED that i didn't cover before, but it really supports what i was trying to get to...
Old 03-10-06, 04:19 PM   #8 (permalink)
Fre OG
Shaylord's Avatar
i find it cost me less to use preium gas than the cheaper stuff when i was driving 45 mins each way a week
Also i think of it like this
back when gas was around 87 is 1.20 and 94 is 1.40
thats 1/6th or (0.166666...) increase of price for the best from the worst
now that gas is 2.20 for 87 and 2.40 for 94
that is a 1/11th or (0.09090...)
I just think the differnce in price right now it is worth it to pay a little more for more than be4 i dont know if anyone else follows what i mean thats just how i think about it
Legend VS. CL/TL
Old 03-10-06, 09:04 PM   #9 (permalink)
swift's Avatar
Car 1: 92' C35 KA8 5spd
Car 2: 92' Ka8 5spd turbo
AS tested by me and taught to me:
Shell v-power supposedly has more detergents to better clean your engine(also during burning to break up carbon..) so if they claim they have more detergents(ie: alcohol) that would be more than the recommended safe use of 10% in a street car. Use anymore and you will deterioate parts and burn out your fuel pump. So i tested my 93 and it came out to around 10%. So if anything they may be using better or the same detergents but not any MORE like they say. Now i use 93 because i have higher compression(not much) and i have advanced my timing and when it is like a few cents more than 91...why not??
Also if you choose to run 87 because of gas prices...you will get worse MPG in our cars because the timing will be retarded etc....so therefore if anything you just equalized it out to running a more expensive 91-93 which will maintain your gas mileage or increase it by 1 perhaps.
Ps---Spend the $75 if you have it to send your injectors to be cleaned like Kenso said...that may help with gas mileage a little. With 138k...mine need it and i proved it.
215whp+
Lucas Octane Booster txlegend Second Generation Legend (1991-1995) 10 08-09-05 01:28 PM
High Octane! acucharmann Second Generation Legend (1991-1995) 1 06-29-04 10:24 AM
87, 89, 91 octane gas.. Which one?! GSteg Engine & Performance Modifications 43 01-22-04 03:30 AM
What Octane rating is Premium Unleaded in your neck of the woods? asianlegend The Lounge 7 08-01-02 11:25 AM
What octane fuel are these engines tuned for? colinc First Generation Legend (1986-1990) 4 03-21-02 06:43 PM
