94 Acura Legend Coupe:Fuel Pump relay keeps blowing - The Acura Legend & Acura RL Forum
Old 02-15-11, 08:14 PM   #1 (permalink)
Unhappy 94 Acura Legend Coupe:Fuel Pump relay keeps blowing
I need some help!!! Please!
Anyway my 94 Legend Coupe has blown 2 fuel pump relays. It seems to blow when i hit a hard bump. When it blows, the car shuts down and will not start again until the new relay is in.
I have new relays that i got from the junkyard, but before i can put one in, I need to figure out how why the relay is blowing. Im guessing its a loose wire somewire grounding out and blowing it. Could it be the factory alarm or the aftermarket alarm that was once installed but no longer active?
Any ideas anyone?
BlackLGNDCoupe is offline   Reply With Quote
Old 02-16-11, 07:45 PM   #2 (permalink)
Can a bad fuel pump cause the fuel pump relay to blow?
Old 02-18-11, 10:55 PM   #3 (permalink)
All of these smart guys on here with answers, but nobody got any ideas here? Damn!
Old 02-19-11, 05:47 PM   #4 (permalink)
EDM Honda Legend Coupe
Car 1: '95 EDM Legend Coupe
Wait a moment. We're speaking about the PGMFI Main Relay, right? This one controls all power going to the ECU and Fuel Pump. When you turn on the ignition switch to "ON" => position II. (don't turn to start) you should hear a click and a hum sound at the fuel filter. That means that the fuel pump gets energized. If you don't hear it you probably have a faulty Main Relay.
Example: If the starter cranks but won't start, then you may have a bad Main Relay!
No, usually this can't happen. Unless there's a ground wire connection somewhere in the wirings.
A "Keep Blowing Fuse" shows you, that you have anywhere in your wirings a bad short circuit or a bad ground connect. Before you take anything to a dealer be sure to check the continuity to ground on all wires. What you are doing is to test the wiring for any Ohm (Resistance) so you should read "0" for everything that you're testing that should be a connection. If you read something higher or even better if you meter says "OL" then there is an open or a break in the wire somewhere. If you meter has an audible chirp when there is a short that is even better cause then you do not have to keep your eyes on the meter. Just poke around and listen. In this case you need the Manual, chapter "Fuel Supply System" on page 6-85 up to 9-86 and the Trouble shooting Flowchart Diagrams.
The OEM Factory Alarm can't be the reason, but the Aftermarket one can. It depends how it has been connected. Some Aftermarket Alarm Systems have a Engine Immobilizer which will cut off the starter system inside the PGMFI Main Relay. Just a thought.
Question: Why don't you find out what is up with the CEL light first before proceeding with the Main Relay?
