Old 06-30-08, 12:44 PM   #1 (permalink)
Car 1: 93 Honda Accord EX
Car 2: 95 Acura Legend L
95 Legend no dashlights when turning key??
ok so my 95 legend does nothing when I turn the key to the II position. I'm supposed to see all lights (check engine, oil, abs, srs, battery)but nothing happens. However, If I slightly turn the key back an inch they will come on. This is weird. Also, the car will start and run fine with the automatic start (but when I put the key in and turn it it will turn off) so its not the engine. Should I replace the ignition switch?
AKing is offline
Old 06-30-08, 03:29 PM   #2 (permalink)
L4K3R5 F4N
Car 1: 91 auto LS sedan, 94 6 spd LS coupe
My first guess would be the ignition switch, especially with the dash lights not coming on as you stated. This is a classic symptom of a faulty ignition switch in older Hondas.
Train is offline
Old 06-30-08, 04:41 PM   #3 (permalink)
VIP Well Wisher
GrtOutdoorsAZ's Avatar
Car 1: '94 GS sedan 6MT
Car 2: '91 L sedan 4AT
def sounds like the ignition switch - I've replaced it on my '91 and '94...both times the symptoms were EXACTLY like you describe...eventually your symptoms will get worse
for '91-'93: the p/n is 35130-SP0-305
for '94-'95: the p/n is 35130-SP0-A11
$48 + shipping on acuraoemparts.com
'94 GS 6MT
Exterior: JDM headlights & rain visors <> paint job <> retro '91-'93 OEM fogs & bumper <> 17" Konigs
Performance: tuned Apexi SAFCII <> Sr5Guy chipped ECU <> Blackend engine damper <> MLS strut bar <> sr79labrat pulleys <> OBX headers <> Custom Y-pipe, Magnaflow Cat & Resonator, Stromung B-pipe & Muffler (All 2.5") <> TB Bypass <> RJ CAI w/ AEM bypass valve <> cross drilled/slotted rotors <> RJ short shifter <> ground wires
Interior: Kenwood DDX6019 w/ NAV & Ipod, 2-tone leather
GrtOutdoorsAZ is offline
Old 06-30-08, 06:20 PM   #4 (permalink)
Thanks. Is it a pretty straight forward install? I have to figure out how to take off my lower dash panel. I think I stripped out one of the bolts that is down there.
Thanks for the info tho!
AKing is offline
Old 06-30-08, 07:08 PM   #5 (permalink)
Chicken & Dumplins
whyteLegend's Avatar
Don't mean to hi jack but I have the that problem also. I actually was coming here to look for one... Does ypur car start thwn shut off immediately?
Question... Does the new ignition comes with a key? My ca
Click for Deep Discounts
http://4450488.shopwize.com
http://www.acura-legend.com/vbulleti...htside-124468/
http://www.acura-legend.com/vbulleti...ad.php?t=95844
whyteLegend is offline
Old 06-30-08, 07:34 PM   #6 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
The ignition switch is only the wire harness with the electrical switch that attaches to the rear of the key cylinder (so no new key, etc. required).
ari_one is offline
Old 06-30-08, 08:01 PM   #7 (permalink)
Yes, my car starts up fine but shuts right off. I know there's nothing wrong with the engine b/c it starts and runs fine with the automatic start. I just pulled the lower dash panel and looked under there. All you have to do is unplug the negative battery terminal, remove the lower dash panel, there are 2 screws to remove your ignition and then follow the wire harness down to the fuse box where the connector is and pull that. I am going to order mine tonight. No new keys needed.
AKing is offline
Old 06-30-08, 08:04 PM   #8 (permalink)
Does anyone know what caused the ignition switch to go bad? Can the one I have be repaired? Do they just randomly stop like that? Luckily it went out while I was at home.
AKing is offline
Old 06-30-08, 08:25 PM   #9 (permalink)
VIP Well Wisher
Don't mean to hi jack but I have the that problem also. I actually was coming here to look for one... Does your car start thwn shut off immediately?
on both of my G2's...the car would start right up (that beautiful Honda startup) and catch right away. but the SECOND you let go of the key, it'll cut right off. Abruptly too...not like you're running out of gas but instantly
yea it's not an awful install but one of those PITA repairs b/c of the routing of the ignition switch and b/c you're upside down looking up at your lower panel. but yea, handful of screws, two plugs and voila!
for anyone else reading who's in the same boat...if you're in dire straights and you gotta drive, I've heard that you can HOLD the key in the START position after it starts up and you can drive. another trick is to move the key from the II position to the ALMOST the start position...then let go of the key so it settles back in the II position. If you're lucky....you'll see dash lights! if you see dash lights, she'll start right up (if the ignition switch is your only problem that is). When I was stuck and had to get going...I just kept doing this till finally I saw dash lights.
I think they just fail over time...when I removed mine, the silver solder that was near the top of the ignition switch FELL RIGHT OFF! I've also heard that you can smack the lower dash and sometimes that will fix the intermittent ignition switch problem - so I think that the solder fails and you get wires touching or shorting = no start
good luck guys!
'94 GS 6MT
Old 06-30-08, 09:46 PM   #10 (permalink)
Chicken & Dumplins
That's exactly what happen to me .. I remote start mine and drove it home with the e-brake .. Thanks everyone..
Old 06-30-08, 10:25 PM   #11 (permalink)
You guys are lucky to have found ways around this. My car will not start at all. Yes I can get dashlights between I & II position but as soon as it settles in the locking position at II they go out. I used to be able to play with it until they stay on but I guess not mine is completely shot. I just ordered a new ignition switch so hopefully that helps I'll drive my accord for now. =)
AKing is offline
Old 07-01-08, 03:52 PM   #12 (permalink)
Chicken & Dumplins
Got mine at the dealer today and I am about to install it.
Looks simple but any heads-up would be appreciated.
Old 07-01-08, 05:16 PM   #13 (permalink)
Chicken & Dumplins
Finish problem solved ..
Reconnecting the alarm system took a little more time..
Old 07-02-08, 10:37 AM   #14 (permalink)
Yea thats what I was worried about too, the alarm system. I think they have some the wiring for the alarm system connected to the ignition switch wiring. Do you have to split your ignition switch wires and connect your alarm wires?
AKing is offline
Old 07-03-08, 10:31 PM   #15 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
I thought Ari One nailed it. Are you still having problems? Post for
resolution.
Boru is offline
