ABS help PLZ - The Acura Legend & Acura RL Forum
Old 01-01-13, 03:08 PM   #1 (permalink)
Car 1: 93 Acura legend
ABS help PLZ
Hi I have a 93 Acura legend that I'm having abs troubles with the peddle will just slowly sink to the floor then after a bit i will have to pump it real quick to keep the brakes the abs light on the dash is on I have from several people that you can pull the abs codes by jumping a lil blue wire clip on the passenger side behind the kick panel but when I do that nothing happens I was told to count the blinks but it doent blink it just stays on
bigdaddy wall is offline   Reply With Quote
Old 01-01-13, 04:14 PM   #2 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
Car 3: 93LS 6spd gray cpe
Welcome to the forum.
Sounds more like a leaking brake hose or master cylinder issue.
Here is a link to a similar post (scroll to the 8th post.) I would
have it towed to a shop, rather than drive it.
Braking issue (soft,pedal to the floor)
Old 01-01-13, 05:46 PM   #3 (permalink)
Car 1: 2006 BMW M6
Car 2: 93 LEGEND COUPE 6SPD
yup its your brake booster so while at it replace master cylinder too.......they're like a timing belt and water pump combo.
P-Legend is offline   Reply With Quote
Old 01-01-13, 05:46 PM   #4 (permalink)
Concur with Boru, a soft brake pedal going to the floor is related to the Normal Brakes (NB) system, not the ABS. The ABS is a complete different system, but it relates to the NB in our cars in mysterious ways.
My experience with such symptom has been a failing Master Cylinder (MC) unable to generate pressure due to deteriorated seals in the piston. If you are loosing brake fluid at the MC reservoir then you should try to track where is it going. If you see a trail of dirt or fluid under the MC, on the face of the Brake Booster (BB), BEWARE! It could mean fluid is being forced inside the BB and with the age of a Legend, it is very likely the brake fluid will also fail the BB. A failed caliper is another possibility, this can be checked by looking inside the tires, a wet rim is a good sign of a failed one. If you park the vehicle in the same spot every day, check for a brake fluid dirt spot for the leak will be in a brake line nearby.
Whatever you do, don't ever try to outsmart a Brake problem, and the soft brake pedal is a brake problem. It can be a very expensive and tragic proposition. Take it to a reputable mechanic, or get a knowledgeable person to properly diagnose it and fix it ASAP.
Guario is offline   Reply With Quote
Old 01-02-13, 08:54 AM   #5 (permalink)
CT-Legend's Avatar
Car 1: 04 TSX Satin Silver
Car 2: 93LS TII Sirius Cpe
iTrader Score: 9 reviews
If your pedal slowly sinks to the floor, the MC is suspect. These boosters typically are pretty reliable, and need not be replaced unless they have failed. Boosters do not fail as often as MCs do. A very quick and simple booster test is given in the FSM. You do not replace a booster and MC as a pair, unless you want to throw a lot of parts and money at a problem. With Legends, that will empty your pockets very quickly.
CT-Legend is offline   Reply With Quote
Old 01-06-13, 11:49 PM   #6 (permalink)
Thanks everyone I'm thinking it the booster after doing a lil investigation their is no fluid leak any where the level stay constant in the reservoir but would this cause the abs light to be on as well
Old 01-07-13, 12:29 AM   #7 (permalink)
Another 3.5er
Car 1: Gold '95 G2 Acura Legend L Sedan
Send a message via Yahoo to JonsLegend
Booster
a 3.5 hybrid 6 speed by the end of this week...
[SIGPIC][/SIGPIC]
JonsLegend is offline   Reply With Quote
Old 01-07-13, 08:32 AM   #8 (permalink)
An ABS Light in the panel "should not" be related to the normal brakes system. You need to get the codes for the ABS. At AcuraLegendWiki you can get the Service Manual and they have several articles that explain how to get them with details. Now, with the ABS codes the rabbit hole goes very deep.
