ABS light on."repair cost info" - The Acura Legend & Acura RL Forum
Old 02-23-07, 05:52 PM   #1 (permalink)
Car 1: 1994 Acura Legend
My abs light is on and I am looking for people who have had this problem. I read the manual and I know it has probably gone to normal brakes. ( My question is about how much should the repair cost. Or is it something that I can do myself.) Thanks, D. Mann
djmann is offline   Reply With Quote
Old 02-23-07, 06:20 PM   #2 (permalink)
uPnoRthACme's Avatar
Car 1: 92 Ls sedan Blk/type F
iTrader Score: 10 reviews
Check your brake fluid level first. It could just be low.
N/A Type II King....9/30/05-2/13/08
94 Type II Auto Sedan: 14.50 @96.1 MPH
uPnoRthACme is offline   Reply With Quote
Old 02-23-07, 09:04 PM   #3 (permalink)
Glop 3:Final Battle Champion, Jewel Champion
Car 1: 91 legend
if that wont help get the code and see if which abs censor has to be changed. PAIN IN THE A$$ but with enough patiens and DW40 u can do it. I did mine took me about 1.5 hours
Ganjubas69 is offline   Reply With Quote
Old 02-23-07, 10:02 PM   #4 (permalink)
Factory Freak!
92drls's Avatar
Car 1: VGM KA8 5SP
Car 2: Downhill MTB
iTrader Score: 6 reviews
Low fluid or bad sensor...
92drls is offline   Reply With Quote
Old 05-30-07, 05:51 PM   #5 (permalink)
A 15yr O.G. Owner!
Acural53's Avatar
Car 1: 1993 Black Legend L Coupe w/mild mods
Car 2: 1993 Lexus ES300
Car 3: 2000 Lexus LS400
Well, my ABS unit actually went kaput @ 98K miles. Had that verified by my mechanic, whom I've used sine '89.
Had the unit disconnected. Amber light is on. Long as I don't slam on the brakes, I'm fine. Have new pads all the way around anyway.
My question: Can these units be rebuilt? Mine is NOT leaking or using up brake fluid.
Because I am hearing some real scary replacement prices of $1500.00 incl labor.
A USED one can still run around $650.00-700.00. Part alone.
Of course, even a mechanic you trust would love to sell you a new unit and make that $1.5K.
Love to hear what others here have done. I know I am not alone on the ABS unit failing. From what I've read, most just bypass it like I did because of the huge replacement cost.
AcuraL53
1993 L Coupe
2000 Lexus LS400
Big Boi (LS 400 Lexus) & Little Homey (Legend L Coupe)
Acural53 is offline   Reply With Quote
Old 05-31-07, 07:03 PM   #6 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
The ABS has its own diagnostic. Access the computer and retrieve the code. There are over a dozen reasons why the indicator lamp is activated. It could be something as easy as disengaging the parking brake to you need a new unit. If you cannot access the computer or don't want an independent to work on the car, Acura can perform an ALB function test in under an hour. This test will tell you exactly what the problem is.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
Old 05-31-07, 10:53 PM   #7 (permalink)
Car 1: 1991 Coupe-L 5-speed
This is how you can retrieve the ABS-code
91 Coupe-L 5-speed
TatNg is offline   Reply With Quote
Old 06-17-07, 01:35 AM   #8 (permalink)
the dank
bringbackthelegend's Avatar
Car 1: 1992 Black/Black LS Sedan
My ABS light has been on for almost four out of the five years I have owned my car. Finally had some time to install some drilled/slotted brembo rotors I purchased last August, and magically the ABS light went off! And this was after a mechanic told me it would cost $1300 for a new sensor! I had gotten used to the light being on all the time, and now its weird that my dashboard display is normal! This is the first time nothing is wrong with my car in four years!
Legends don't need to be told...
bringbackthelegend is offline   Reply With Quote
Old 06-17-07, 10:12 AM   #9 (permalink)
Yeah BABY!
Dinero19's Avatar
Car 1: 92 BLK/BLK LEGEND LS (Sold)
Car 2: 96 INTEGRA LS
Since I wasn't going to invest 1k into my car to fix the ABS that has been on for about 8 months. I just simply removed the bulb. My brakes feel the same as when I bought it.
05 TL Wheels
OEM TL Hid's 4300k
JDM Eyelids
Clear Corners
OEM? Fogs
KYB GR-2's
Dropped
eBay Intake
V6 emblems
35% / 20% tints
Kenwood Sub
Dinero19 is offline   Reply With Quote
Old 06-18-07, 03:02 AM   #10 (permalink)
Status01's Avatar
Car 1: 1992 acura legend 5 speed sedan
Car 2: 1970 Pontiac GTO :)
Car 3: 99' Infiniti G20t
Send a message via AIM to Status01
Yea my ABS light has been on since i bought the car three years ago. I'm used to having that light on its funny......it doesnt turn on until ten to fifteen minutes into driving.....
1992 acura legend five speed.
iva-c800 alpine tv
12" rockford Hx2 1000 watt rockford amp
rev speed meter gauge
Intake
17"enkei wheels
Playstation 2
alpine alarm and stock alarm
remote starter
Status01 is offline   Reply With Quote
Old 06-19-07, 10:39 PM   #11 (permalink)
brittonj85's Avatar
Car 1: 1991 Acura Legend LS
My ABS light comes on once my transmission shifts into 2nd gear. Any Ideas? One mech said, could be a bad axle.... Well, ummm, yea, I must say, my right axle is leaking fluid some where but you can't here it clicking when turning unless you drive 1 mph. I'm going to buy a new axle and will see if this will help.
Acura Legend Type 2.
brittonj85 is offline   Reply With Quote
DIY: ABS sensor replacement (w pictures) TatNg DIYs 26 02-22-16 09:14 PM
D.I.Y: Tail Light Gasket Replacement HiTek21 DIYs 9 02-15-07 03:13 PM
Abs light & Brake light came on. Two days later my AC is out... Matt Whelan Second Generation Legend (1991-1995) 8 11-03-04 11:35 AM
brake light and ABS light on??? umpalumpa Second Generation Legend (1991-1995) 5 07-01-02 01:36 AM
My ABS light just came on.... Why? Moloukhya Second Generation Legend (1991-1995) 21 05-15-02 01:48 PM
