Old 03-19-08, 11:55 PM   #1 (permalink)
Car 2: 94' Acura Lgend GS
Acura NSX Light Weight Flywheel in a Legend?
Has anyone ever considered this as an option for us guys looking to shed some punds in the drive department? Does anyone know the comparible specs bewteen the early model NSX and legend flywheel?
I wonder if this could be an option, or if this could ever happen?
Any thoughts?
SIG BY ALPEROVICH
MODS---ALL OF THEM!!!!!!!!
Check out my gallery!
http://www.acura-legend.com/vbulleti...ebirth-126357/
The project...
http://www.acura-legend.com/vbulleti...thread-120596/
http://www.acura-legend.com/vbulleti...ed-123764-new/
emaculate91ls is offline
Old 03-20-08, 02:06 PM   #2 (permalink)
Was this a stupid question or is it that nobody has a clue?
If anyone knows someone with a NSX flywheel please let me know. I would like to see if at least the OEM one matches to either the 6 speed or 5 speed legend flywheel. If we do have a winner than finding a light weight flywheel should not be a problem.
SIG BY ALPEROVICH
The project...
Old 03-20-08, 06:28 PM   #3 (permalink)
It's stock, really.
FF Drifter's Avatar
The only help I might be is that my clutch kit started as an NSX kit. No idea about the flywheel itself though =/
FF Drifter is offline
Old 03-20-08, 07:49 PM   #4 (permalink)
After reading about you NSX clutch in your Legend it kind of spark a fart in my brain.
Can you tell me what modifications were done to your clutch to make it work with your legend?
I am about to by a NSX flywheel to figure this out! This is killing me!
SIG BY ALPEROVICH
The project...
Old 03-20-08, 09:07 PM   #5 (permalink)
It's stock, really.
FF Drifter's Avatar
I'm not entirely sure. My clutch was built by a local shop when I did my engine swap. As my mechanic explained it to me, it started as an NSX clutch kit and then it was built from there. I'm not an expert on clutches or flywheels unfortunately. All I've got are pictures if that helps.
Old 03-20-08, 10:09 PM   #6 (permalink)
Would you be able to possibly talk to your mechanic and find out what he did?
I am in the process of picking up an entire used clutch, and flywheel from a early 90's NSX. Wish me luck!
SIG BY ALPEROVICH
The project...
Old 03-22-08, 01:30 AM   #7 (permalink)
Any thoughts at all?
SIG BY ALPEROVICH
The project...
Old 03-22-08, 05:53 AM   #8 (permalink)
EDM KA8 owner
lgnd's Avatar
Car 1: EDM KA8 '91
Car 2: EDM KA8 '91 RIP
I checked EPC and from 91 to 96 flywheel was offered with the clutch kit only
part number for clutch kit: 22000-PR7-305
flywheel has 8 mounting bolts like the legends.
'97 and up flywheel looks totally different. Maybe this helps a little.
lgnd is offline
Old 03-22-08, 10:55 AM   #9 (permalink)
Thanks for the tip, I noticed that to.
SIG BY ALPEROVICH
The project...
Old 03-22-08, 07:14 PM   #10 (permalink)
JDM 4 life
superstreet4life's Avatar
Car 1: '93 Legend L Sedan 5 Spd w/ Cloth Inteior
as long as it is the same size and bolt pattern then it should be cool. good luck and definetly keep us updated
http://i258.photobucket.com/albums/hh275/93KA7/acura%20legend/mangecar2.png
superstreet4life is offline
Old 03-26-08, 08:10 AM   #11 (permalink)
The NSX clutch and flywheel set-up that I was going to pick up has been sold. I have not been able to find another set, so I think I will have to hold off on this projet for a while.
I cant afford anymore down time with my car at this time, nor do I need to blow away any money than I already have.
If someone happens to find a used, shot, damaged clutch and flywheel from an early 90's NSX, than please get at me.
SIG BY ALPEROVICH
The project...
Old 03-26-08, 08:53 AM   #12 (permalink)
6 Gears
95LegendGS's Avatar
Car 1: 95 Legend GS
Make a thread on NSXprime.com if you haven't already with a want to buy.
Just another boosted legend
Parts For Sale: Fiberglassed dash, Complete T1 & RL heads, Sedan Front seats (F), Center Console (F), T1&RL intake Manifold, Complete running engines, body parts, Sedan Headlights, Clear corner lights, RL engine parts. ANYTHING YOU NEED. I have "UNLIMITED" RL and Legend Parts PM me to discuss. NO COUPE PARTS, please stop asking
For quickest reply please email me at 95LegendGS@gmail.com Thanks!
95LegendGS is offline
Old 03-26-08, 10:20 PM   #13 (permalink)
Factory Freak!
92drls's Avatar
Car 1: JDM KA8 5sp
Car 2: Lincoln LS8 RIP
I'm replacing the clutch with a "stage 2" ebay clutch and was looking for a flywheel as well.. Far as I can tell the NSX flywheel looks pretty much exactly the same and the one I have my eye on is a 6 POUND Fidanza.. Dont wanna buy unless positive tho..
92drls is offline
Old 04-02-08, 08:47 PM   #14 (permalink)
I picked up that Fidanza flywheel. Now I just have to figure out a way to see if it will work with the Legend 5 speed clutch.
If the NSX flywheel does not work with the Legend clutch, does anyone think it would be possible to use the NSX clutch?
SIG BY ALPEROVICH
The project...
Old 04-02-08, 08:52 PM   #15 (permalink)
RALPHS HANDS ARE CLEAN!
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
I think it MIGHT be possible, yes! But, what di I know lol
It's obvious they're both BAD for America!
blkonblkcpe is offline
