Additional Benefit of the Sunroof Tilt Mod
Additional Benefit = Less Wind Noise
Today I did the Sunroof Tilt mod during my lunch hour using the DIY Moonroof Tilt DIY It took me less than 40 minutes (taking my time, cleaning things as I went along) and only required 4 tools. Since I purchased my car, I have noticed wind noise from the Sunroof at any speed above 40 mph. I noticed if I put a little upward pressure on the sunroof it went away. I use to close the sunshade to hide the noise. Now that I have the tilt option, I am able to slightly press the button so the sunroof raises a millimeter and seal the sunroof properly and the noise is gone. Ahhh its so quiet now... I know I have read on here about other members that complained about wind noise, so this may be an easy fix for you too. The DIY is great, but some additinal hints that may be helpful: * Step 7 - Sedan - the two 10mm nuts on each side are under plastic covers that need to be removed. * Step 7 - I had to unscrew the 2 screws and pull the drain channel out to do this mod, it was not optional for me. * Step 8 - I used a Offset Ratchet Screwdriver instead of needle nose pliers. * Step 9 - also need to reinstall wind deflector if you have a 91-93. .
John aka: Splendid '91 LS - Golden Glow Pearl Clearcoat w/ Ivory Leather 94K miles Mods 7 Spoke OEM Machined Rims, Sunroof Tilt, Armrest w/ Cupholder, Iggee Seat Covers w/ Controls mod. UnMods Removed tint Gallery Pictures Link DIY's 1) How to Install Iggee Front Seat Covers 2) Iggee front seat covers w/ seat controls mod . |
I'm the Stig!
I think the official fix for the wind noise problem is to add shims
#3 (permalink) | |
John aka: Splendid '91 LS - Golden Glow Pearl Clearcoat w/ Ivory Leather 94K miles Mods 7 Spoke OEM Machined Rims, Sunroof Tilt, Armrest w/ Cupholder, Iggee Seat Covers w/ Controls mod. UnMods Removed tint Gallery Pictures Link DIY's 1) How to Install Iggee Front Seat Covers 2) Iggee front seat covers w/ seat controls mod . Last edited by 91LSplendid : 03-28-08 at 05:27 AM. |
I don't know if you can tell but the car in my sig on the right is mine. It has the sunroof tilted up. It just tilts about 2 inches.
Modifications: Custom Cold Air Intake, Telion's Type I Stage 2 Chip, Blackend Engine Damper, TB Coolant Bypass, Custom made three point strut brace , EGR Block Plate, Brembo Rotors, EBC Greenstuff pads, Goodridge SS brake lines. 215/45 Nexen n3000's on 17X7 Enkei Evo6's. Auto Climate Control Swap (fully functional), McCulloch 5700k HID's, Alpine 8080 alarm, Moonroof Tilt, F1 Clear Corners, Clear Bumper Lights mod, 160mph cluster, Interior LED swap, Redout Taillights. |
#6 (permalink) | |
here you go...these are functional pics, not artistic pics... ![]() ![]() .
Thuggin' it since 1996!
have you done any high speed spirited driving yet? has it closed on you by itself due to the increased windforce?
this mod scares me a bit....
~Heath~ 95 Taffeta White Acura Legend L Sedan (130k) 95 Sherwood Green Legend LS Coupe (89k) "And on the 8th day, G-d created the Legend" "This ain't negotiation time. This is Scarface, final scene, fuckin' bazookas under each arm." -Christopher Moltisanti |
#8 (permalink) | |
I remember your post from earlier this month thinking you couldn't handle doing it yourself. It was that post that made me decide to do it. This is the first mod I have done to my car and usually I don't try to do more than oil changes, spark plugs, air filter changes, tire changes, etc. The FIY was easy to follow (plus see a few tips I posted above). You can do it. With all the posts about this mod, if there was an issue like you state above, it would have surfaced several times by now in the threads. .
#9 (permalink) | |
![]() but I'm wondering....I think I've read two people who've had trouble with it shutting itself..... but how many have had it done w/o problems?
HARLEM LEGENDZ
I have the sunroof mod, done and i have went way over 100mph and no problems yet, after you complete the mod...you will notice that the roof actually locks itself in place. You just have to train yourself to close it properly, it just takes a little patience at first but after you get the hang of it its nothing significant. Then again what dosent take time and needed extra attention with a legend?
I'm the Stig!
just an FYI. don't try and close the roof at speed. 60mph+ fair warning. things can break, maybe not the first time but it will happen.
also at speed. 100mph+, 80mph+ it is possible for the open sunroof to raise up a little, DON'T TRY AND CLOSE IT THEN!!! you will damage it. damn plastic components.
I did the tilt mod on my 94 Legend the day I bought it, I drove it over a year without any issues. I don't think speed will cause it to close on its own, I had my 94 up to 130mph once and it stayed up just fine. I recently did it on my 93 and it's still one of my favorite mods.
New pictures of my 93' LS sedan WTB: Type F, Drivers door weather stripping! PM me! FS: OEM 15in Legend Wheels. Great condition! PM me! |
#14 (permalink) | |
I'm the Stig!
really the biggest issue is trying to close it at speed. it will everytime break the lift up stopper. god knows how many times i've replaced mine.
#15 (permalink) | |
this is exactly what scares me....knowing my luck, it will happen to me
