Adjust valve clearances? - The Acura Legend & Acura RL Forum
Old 10-22-04, 02:06 AM   #1 (permalink)
Car 1: 93 Legend Sedan
iTrader Score: 4 reviews
id like to know if we are suppose to adjust the valve clearances on our cars...i just need this question cleared up because i have heard from some members that since our cars have hydralyic valves, they do not need to be adjusted...but i found this thread today that says we should...now im confused...
Daddymac117 posted:
Every 15,000 miles or 12 months
All items listed above and:
Inspect the brake system
Check clutch pedal height and freeplay
Inspect the seatbelts
Replace the a/c air filter
Replace the air filter
Inspect the fuel system
Check m/t lubricant
Check differential lubricant level
Inspect suspension and steering components and driveaxle boots
Inspect exhaust system
here is the link to Daddymac117's post:
http://www.acura-legend.com/vbulleti...ad.php?t=54131
legendarysleeper is offline   Reply With Quote
Old 10-22-04, 05:15 AM   #2 (permalink)
Stu
Car 1: 2005 Lexus LS430
I asked the same question a while back .... I was told the valves are self-adjusting so you dont have to !
Stu is offline   Reply With Quote
Old 10-22-04, 06:23 AM   #3 (permalink)
thanks Stu...thats what i heard too...
anyone else with an opinion on this topic?
Old 10-22-04, 07:43 AM   #4 (permalink)
the Gen 2 have hydraulic tappets so they adjust themselves. You cannot adjust them, they use the same principal as a hydraulic shock damper, with a cylinder inside another and the damping (or adjusting) accomplished by transfer of oil through a small bore. But they can get dirty, worn, owner uses the WRONG weight oil, etc. so they can make noise, but are usually very reliable.
bigdad is offline   Reply With Quote
Old 10-22-04, 07:57 AM   #5 (permalink)
thanks for clearing it up bigdad...so no need to adjust...but replace if worn out...
How to get ridoff Check Engine Light DJPolak Second Generation Legend (1991-1995) 3 11-21-03 10:38 AM
exhaust valve adjustment digger89L First Generation Legend (1986-1990) 0 07-17-03 11:15 PM
Adjust valve clearances??? Sean L Second Generation Legend (1991-1995) 5 01-04-03 10:25 PM
Valve guide seals! I need advice takemorepills Second Generation Legend (1991-1995) 0 03-27-02 12:58 PM
