Old 09-24-07, 04:46 AM   #1 (permalink)
91cOupeWhite's Avatar
Car 1: 1991 legend coupe L
After BHG, Loud Ticking?, Please help
Well got done with my head gasket repair, new gaskets all around, everything in top notch shape. When I started her up, there is a loud ticking sound coming from what sounds to be the valve train.
Now I know about ticking lifters, but it seems louder? maybe, my lifters never really ticked. How loud do they tick?
Could this have to do with the viscosity oil I put in (10w-40)?
Should I go out and get 5w-30 right away? will that fix it?
What else could it be?
I didn't run her for long, as I didn't want to cause any damage, but the idle was weird, dropping from 1800 to 1500 or so and then back up.
Any ideas on that?
Thanks
http://i16.photobucket.com/albums/b2...r/8d09fdcd.jpg
So you say you want a revolution F**K the world
91cOupeWhite is offline
Old 09-24-07, 07:38 AM   #2 (permalink)
Car 1: 93 Legend Sedan
Double check your timing. If that's fine, just change oil again.
93lsz is offline
Old 09-24-07, 07:46 AM   #3 (permalink)
Car 1: 1993 Green Sedan
Could be a lifter tick.
After my BHG repair, I had one lifter that ticked incessantly until about 6 miles of driving afterward. It was quite loud also. I even thought I screwed up the timing too! Don't change the viscosity of the oil, it will go away.
lovelyleg is offline
Old 09-24-07, 09:14 AM   #4 (permalink)
Canis Lupus
Car 3: 1989 240SX 5 speed
Send a message via AIM to Blood Riot
I agree with 93lsz, to me it sounds like your timing is off.
Blood Riot is offline
Old 09-25-07, 09:40 PM   #5 (permalink)
Car 1: 1993 legend ls
mine did the same thing this is normal. the oil has not circulated. It did it for about 25 min then it got quiet. Make sure your oil level is normal.
fatjoe216 is offline
Old 09-25-07, 10:30 PM   #6 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
yea, sounds like probably 1 of your lifters is sticking. did you disassemble the head at all?
~Alex
Alperovich is offline
Old 09-26-07, 05:43 AM   #7 (permalink)
MAD DOG!
dgandul's Avatar
Car 2: 92 LEGEND LS
i just finished mines also.... wow a lot of people doing HG jobs lately. mines was ticking loud also after starting it up. i had a valve job done so i was pretty sure the heads were in tip top condition. after a while it got all lub'd up and it went away. check your timing, cuz as i learned the hard way a tooth off can kick your ass
dgandul is offline
Old 09-27-07, 12:35 PM   #8 (permalink)
Car 1: 1992 L Coupe
Looks like I'll finally be starting mine up tonight after a summer-long head gasket job ... i completely redid the heads, so now I know to be ready for some ticking ... thanks for the heads up.
If I don't come back to this thread soon with positive news, just assume it didn't work and I pushed the car off a cliff.
Schuttrp is offline
Old 09-27-07, 09:46 PM   #9 (permalink)
QuickLegend's Avatar
Car 1: 03 GS300
Car 2: 1995 GS300 ,SC300
Car 3: 02 DENALI
Send a message via Yahoo to QuickLegend
it will tick for a while because when u take the heads to the machine shop they resurface the heads replace the valve if they are worn replace the valves seals for sure and the valves guides so once they do all that yes your engine will tick for little bit and then it should go back to normal i had the the same issue when i replace the valves on my cousin RLthe engine for 20 mn and then went away
2JZ-NA AND THE T COMING SOON
JZS160
QuickLegend is offline
Old 09-27-07, 10:55 PM   #10 (permalink)
Of the Telion Chip
Telion's Avatar
Car 2: White 91 KA8 JDM TII
^sound advice and hope your valves are not bent if the timing is (was) off^
PS It must be BHG repair month
Telion is offline
Old 09-28-07, 08:47 AM   #11 (permalink)
Car 1: 1992 L Coupe
Well, I didn't have to push the car off of a cliff, did hear some minor ticking, but all good now ... Time to hit the track!
Schuttrp is offline
Ticking? rayj211 Second Generation Legend (1991-1995) 6 09-22-07 05:11 AM
too much ticking... Gearhart Second Generation Legend (1991-1995) 1 02-29-04 08:02 AM
how loud... 94legendsedan Audio, Video, & Electronics 3 08-05-03 09:13 PM
loud ticking noise legend107 Second Generation Legend (1991-1995) 8 04-07-03 06:22 AM
No more ticking! Hartman First Generation Legend (1986-1990) 7 02-08-02 02:00 AM
