#61 (permalink) |
Find Em Fuck Em Forget Em
As I believe I mentioned previously, a properly installed alarm e.g. Viper provides all the protection needed assuming you don't put the alarm brain under the steering column and put the starter kill right at the ignition switch.
The Ravelco is just another wiring defeat with a physical 'key.' The ONLY benefit is that you cannot simply program another remote into the system and gain carte blanche that way. That is absolutely the ONLY gain. Honestly for the money, pay the installer of your alarm to defeat the main power relay and the fuel pump relay using a N.O. wiring scheme and a couple of relays. Having wiring 'traps' hidden around the car is much better than having your Ravelco with all the wires it affects running to and from it. If you don't think of theft prevention in these terms, I think you're nuts: Passive - First and foremost this is non-electronic. Don't leave the windows down, don't leave anything out that attracts attention. Attention - Have an alarm system with a very sensitive 'warn away' function. I mean if the wind blows, it's gotta chirp. Use a proximity sensor and a tilt-sensor if it is in your budget. If your first fear is the car being stolen, then this is key. Disable - Make sure the disabling functions on the vehicle are not instantly obvious (like starter kill which has no 'click' noise from the solenoid, i.e. not a bad starter, but a starter interrupt at work). The defeats should have their controlling relays located between the alarm and the defeated part itself, physically so that e.g. the main relay doesn't have a wire spliced in, right at the plug. Notify - Somebody tries to get in the car, start it, or tow it....let it raise hell. No thief wants to deal with that crap. Regardless of what anybody says, if they want it bad enough...if they're smart enough...they'll get it no matter what.
3.5RL With/Without Nitrous Comparo Video |
#62 (permalink) | |
VIP Well Wisher
I'm still pretty intrigued by the Ravelco
check out some more info I found - All connections for Ravelco are made in the engine compartment--none in the cabin or under-dash area. - the Ravelco can disable any combination of the starter, fuel system, ignition system, or computer system. Even more, on some vehicles the cam or crank sensor can be disabled, too. - all wiring is black and protected by steel covering...no pattern for hotwiring attempts. some dummy wires are added too and the wires work in pairs...if a thieft starts clipping them, your car wont run Ravelco Anti-Theft System - GM High-Tech Performance Magazine GM High Tech Performance article about Ravelco...w/ installation pictures what I'm gathering also is that while alarms may be just as good, it's the installers that are the problem. - you said you need multiple hidden traps, etc...am I really going to be able to get an 18 yr old Best Buy or auto accessory store employee to hook it up? I dont even really know what to ask for..."dude, make this system really really good". even if I quoted what you said above on what to do...how would I even know if he did it that way? since I cant install a system, I cant really check a system either I would think - there are tons of websites that talk about how to remove/disarm Viper alarms...a lot of them talk about color coded wiring viper car alarm disarm - Google Search - you guys arent even slightly impressed by the 31 year and nearly 4 million no vehicle stolen track record? how come we dont hear stats about Viper, Clifford, etc? If ONE person out there had their car stolen when armed with a Ravelco, the company would not be able to plaster that fact all over everything they have. - from a car alarm website: Quote:
before Ravelco install ![]() after Ravelco install, can you tell a difference? ![]()
'94 GS 6MT Exterior: JDM headlights & rain visors <> paint job <> retro '91-'93 OEM fogs & bumper <> 17" Konigs Performance: tuned Apexi SAFCII <> Sr5Guy chipped ECU <> Blackend engine damper <> MLS strut bar <> sr79labrat pulleys <> OBX headers <> Custom Y-pipe, Magnaflow Cat & Resonator, Stromung B-pipe & Muffler (All 2.5") <> TB Bypass <> RJ CAI w/ AEM bypass valve <> cross drilled/slotted rotors <> RJ short shifter <> ground wires Interior: Kenwood DDX6019 w/ NAV & Ipod, 2-tone leather |
#63 (permalink) | ||||||||
More Ravelco press: Quote:
Long story short, the Ravelco is a fine theft prevention device. It isn't an alarm, won't do what an alarm can, and doesn't do anything an alarm can't. If it comes down to trusting the installer, you're possibly screwed either way.
#64 (permalink) | |
VIP Well Wisher
Good stuff though Grumperama...knowledge is power. I just feel like I could spend $200-$400 for a "good alarm" installed but get a sub-par job that some ex-con can beat in 3 minutes. So why not spend $500-$700 for a decent alarm AND the Ravelco - that was my train of thought anyway.
#65 (permalink) |
I suggest approaching an independent shop, ask for pricing on a standard alarm install.
Then ask them about: *Mounting the Alarm Brain in different locations. My favorites are near the engine ECU or under the passenger seat. This means most of your wires can be tapped at the ECU and NOT the ignition column, which is standard. *Two layer theft defeat. 1. Starter kill relay mounted IN THE ENGINE BAY between the starter solenoid and the firewall. 2. Fuel Pump relay defeat *Two sirens. One in the engine bay and one under the dash or seat, see 'pain generator.' *Tilt (Jack/Tow) sensor *Proximity sensor *Hood Pin Switch *Battery Backup - I really like the battery backup because if someone disconnects the battery while the system is armed, (i.e. crawling under) the alarm goes off. It also allows the system to continue raising hell which is no fun for them. Seriously, if you ask for all of those things and the installer doesn't bat an eye, then you're probably in good hands. The only thing I left out would be a glass break sensor, but I'm just not that paranoid. Plus they have to crawl through a broken window or open the door anyway at that point.
#66 (permalink) |
33mpg 6spd Coupe
I just carry my battery around with me when I park the car.
Someone stole maracura91's new wheels one day after he bought them. (10/09/2008) This link will search for "Nitto" + "C2" + "Racing Hart" on all of craigslist for the last 24 hours. Click it to help him find his wheels! maracura91's thread Inflation is your friend! I mean really, who doesn't want to own a $100,000 car? |
#67 (permalink) | |
putting the ass in class
sig by doubleglow the sigwhisperer ƃuıʇsod ǝɹoɟǝq ɥɔɹɐǝs plnoɥs sɹǝsn ʍǝu join the acura legend flickr group visit my flickr page |
#68 (permalink) |
for the price a good alarm system should be inclulded. Imagine your sleeping and someone breaks in your car, even tho its parked below your window, you have no idea whats going on. Even though the thieft wont be able to move the car, he would still probably rip up your interior and steel your wheels. I cant post pictures of my installation since that is my only defence from car jackers.
This is what my electrician did. I have a 3 switch combination that you have to get before you can any light in the dash. But then a relay is placed between the reverse and ignition. if the car isn't in reverse the circuit is open meaning no start. all that with a autopage 1mile alarm. I feel very secure with my setup. if you live in the bronx area and want a resonable custom kill swith this is the guy to go to. He works out of his van now because they sold the building his shop was in. but trust me, when i say this guy knows his shit. he knows his shit.
#69 (permalink) | |
It will start in neutral.
Modifications: Custom Cold Air Intake, Telion's Type I Stage 2 Chip, Blackend Engine Damper, TB Coolant Bypass, Custom made three point strut brace , EGR Block Plate, Brembo Rotors, EBC Greenstuff pads, Goodridge SS brake lines. 215/45 Nexen n3000's on 17X7 Enkei Evo6's. Auto Climate Control Swap (fully functional), McCulloch 5700k HID's, Alpine 8080 alarm, Moonroof Tilt, F1 Clear Corners, Clear Bumper Lights mod, 160mph cluster, Interior LED swap, Redout Taillights. |
#70 (permalink) | |
Renaissance.
As long as the clutch pedal is down, it'll start in any gear *lol*
A sign of things to come.... Quote:
#72 (permalink) |
Or neutral
#73 (permalink) | |
#74 (permalink) |
That would be aggravating to put the automatic car in neutral before starting...major cool points loss.
I'd just hide a momentary switch that has to be pressed to allow the starter to turn over.
#75 ( |
