Bad Coil Packs - The Acura Legend & Acura RL Forum
Old 10-20-07, 10:35 AM   #1 (permalink)
Car 1: 1995 Acura Legend GS
iTrader Score: 4 reviews
Bad Coil Packs
how do you determine of you have a bad coil pack??
174,000
My ride
Roger is offline   Reply With Quote
Old 10-20-07, 01:03 PM   #2 (permalink)
Black Type II's Avatar
Car 1: Carless
i'd like to know as well but if i took a guess i would say some type of sluggish responsiveness from the car, misfiring of some sort. i dont know how u can diagnose this for sure tho
1995 Milano Red LS 6SPD where are you?
Black Type II is offline   Reply With Quote
Old 10-20-07, 01:20 PM   #3 (permalink)
Alperovich's Avatar
iTrader Score: 24 reviews
a good way to see is, unplug the coil pack and see for a change in RPMs or just change in the way the engine runs, based on pulling other coil packs. 1 at a time. this is often referred to as a "power balance test"
U can also try a known good coil pack and see how the car runs
or if u have a ohm meter, u can test the resistance in the coil.
Old 10-20-07, 03:39 PM   #4 (permalink)
Yeah BABY!
Dinero19's Avatar
Car 1: 92 BLK/BLK LEGEND LS (Sold)
Car 2: 96 INTEGRA LS
Power balance test huh. I'm going to try this. Unplug one by one and if I notice a change then it's bad? Good?
05 TL Wheels
OEM TL Hid's 4300k
JDM Eyelids
Clear Corners
OEM? Fogs
KYB GR-2's
Dropped
eBay Intake
V6 emblems
35% / 20% tints
Kenwood Sub
Dinero19 is offline   Reply With Quote
Old 10-20-07, 04:22 PM   #5 (permalink)
Alperovich's Avatar
if the change is different in a paticular cylinder then tehre is a issue in that cylinder. It can possibly be the coilpack. it could also be a faulty injector or sparkplug, etc. it just pin point a problem with the cylinder.
once u do find the cylinder, if u swap coil pack with another cylinder and then see what happens. if the problem follows the coil pack, its a coil pack issue.
Old 10-20-07, 07:57 PM   #6 (permalink)
Car 1: Carless
i was going to mention this but if u unplug a coil wouldnt u notice a change anyway regardless if its good or not? cus u would be cutting off the spark being supplied to the engine...right?
Old 10-21-07, 01:49 AM   #7 (permalink)
Alperovich's Avatar
yes, the idea is that, if its not firing right in the first place, it will only slightly run worse, sometimes nothing will change. your looking to make sure, if its working properly, you'll see a sudden and noticeable change in how the motor runs. if the cylinder wasn't running alright, then it wouldn't change much or at least not like the others.
Old 10-21-07, 02:46 AM   #8 (permalink)
Car 1: Carless
idk...but i did this to make sure my cylinders were firing and they sure were (after i changed my plugs) but idk if i still need coils or not. my car doesnt seem to pull like my 93L coupe and i have to hold the key for 1.5 seconds and at idle its kinda rought but only noticeable cus its me. what could this be...o and i also put oil stabilizer in the engine too with an oil change so what gives? nothing different b4 tune up or after
Old 10-22-07, 11:45 AM   #9 (permalink)
Alperovich's Avatar
/\ have u checked your fuel pressure? it might be causing something
also, my 93 coupe, most of the time i have to crank it a little longer, idk why.
Old 10-22-07, 04:25 PM   #10 (permalink)
astigracing's Avatar
Car 1: '09 Nissan Maxima
Car 2: '98 M3
Car 3: 08 Nissan Pathfinder
iTrader Score: 7 reviews
Send a message via Yahoo to astigracing
i have six coil packs. i think one or two is bad.
i can lend them to you so you can use it to check if yours are bad.
pull one coil from your car and put one of mine in replacement and start your car. if there is no change then the coil you pulled out isn't bad. do this one coil at a time until you find the bad coil. once you find the bad coil/s, simply note which cylinder/s and buy your own and send my coils back the way you got them...just pay for the shipping.
'09 Maxima | '08 Pathfinder | '00 E39 Sport | '98 M3 | '95 325i Race Inspired | '95 KA7 G2 *SOLD* | '92 KA8 G2 *SOLD* | '94 Lexus LS400
astigracing is offline   Reply With Quote
Old 10-22-07, 05:20 PM   #11 (permalink)
Lux sedan enthusiast
BigD's Avatar
Car 1: 1999 Lexus LS400
I just swapped out 4 of my 6 coils (don't know which was bad though )
I will sell them very cheap if you want to try them.
NC Legends
BigD is offline   Reply With Quote
Old 10-22-07, 05:27 PM   #12 (permalink)
Car 1: Honda Legend 3.2i AT
Check the inside of this connector in the midlle of picture, it is the positive conection to all coil packs.
If you go to a shop they can measure your exhaust fumes, keyword here is to look for unburned fuel (parts HC).
If you drive like this too long the O2 sensor will go bad....
Cees-Jan is offline   Reply With Quote
Old 10-23-07, 06:21 AM   #13 (permalink)
Car 1: Carless
hey i'd like to try this how much is shipping? and alperovich what way iis there to check the fuel pressure? once ur car warms up on ur 93 coupe does it start with no delay?
Where are the COIL PACKS? 91LS99 Second Generation Legend (1991-1995) 7 04-20-07 06:36 PM
Coil Packs amon Second Generation Legend (1991-1995) 5 02-26-07 11:56 PM
coil packs mikeymike Second Generation Legend (1991-1995) 15 02-26-03 01:49 AM
coil packs mikeymike Engine & Performance Modifications 0 02-20-03 10:51 AM
Coil packs???? Prox7 Engine & Performance Modifications 1 08-30-02 10:51 PM
