Bad fuel Pump? Main relay? car will not start - The Acura Legend & Acura RL Forum
Old 08-31-06, 11:43 PM   #1 (permalink)
Car 1: 94' TypeII Coupe Auto
For the last few months my 94 L has been starting kinda hard for the first start of the day, first turn several cranks. It stalled on me at a stop light 2 weeks ago.
I was driving around and made a quick stop, when i got back in it started then stalled right out and wouldnt start. It just keeps cranking away. Battery is good, i have a 6m old optimum red top. Starter fluid gets it to turn over it will putt as long as the fums hold up. I hear the click from the main relay.
I pulled the fuel pump out and hot wired it to the battery, it worked-just not that loud, like an electric toothbrush. I metered the plug to the pump 12v for 2 sec(put the car to on). Plugged it back in (pump) left it out in view and tryed it......Nothing, re metered it....plugged it back in ....nothing, no pumping at all.
I think its the fuel pump, but it did work put strait to the battery, a friend said it should be much louder.
Where can i find a new pump...autozone and advanced both do not have the right one, The one they gave me it twice the size and has 2 metal termanals not the single plastic clip i need.
I was supposed to go to atlantic city tomarrow...sucks
Please any help, experiences, links Thank you
XmodRELIC is offline   Reply With Quote
Old 09-01-06, 12:17 AM   #2 (permalink)
Ok i found the right pump for $200 on line, but it that the problem......?
Old 09-01-06, 12:32 AM   #3 (permalink)
morbo's Avatar
Car 1: I35 Sedan
Car 2: 2004 Lincoln LS
Send a message via AIM to morbo
Sounds like the main relay to me, if it works straight to the battery it could be the relay that is the weak link....
Dunno, I'd opt for the relay 1st-it's cheaper to replace, and much easier...
http://ffejbomb.blogspot.com
CODEALARM CAR ALARM W/REMOTE START 4 SALE! PM OR EMAIL ME FOR INFO!!!
Keepin it real fo the SA
The Internet wasn't designed for ridicule. It was invented so researchers could share common data sets at University. It was I tell you.........it was. --Homer Simpson
morbo is offline   Reply With Quote
Old 09-01-06, 12:40 AM   #4 (permalink)
OK before i go and buy a new pump Ill check the relay maybe its a bad solder joint...If not where can you get a new one? easy enough just to search for? Is this it? is this a good price? $68
Old 09-01-06, 12:42 AM   #5 (permalink)
morbo's Avatar
Car 1: I35 Sedan
A new one from dealer is $80 or so....
Only place I know to get one. That pic is the right one, I remember that Mitsuba name....
You could crack it open and resolder, I've heard of memebers doing it before.
These cars cost enough money, save some by doin this one yourself!
Old 09-01-06, 01:20 AM   #6 (permalink)
Car 1: 2003 Acura CLs 6spd
Car 2: 94 Acura Legend 6spd
tb clean
Try cleaning your TB and the iac.
wally1989 is offline   Reply With Quote
Old 09-01-06, 03:48 AM   #7 (permalink)
What are those?
I'm going to resolder it right now....
Old 09-01-06, 02:00 PM   #8 (permalink)
S4gunn's Avatar
Car 1: 02 Audi S4
Car 2: 97 Honda Accord SE
Throttle Body and Idle Air Control Valve.
From the Archived Threads List
Suggested Fixes for Problem: Car has low idle / problems maintaining idle
DIY: Cleaning the Throttle Body & Intake Air Control Valve (IACV)
DIY: IAC Cleaning - DIY
idle problem - suggestions
cleaning the iac - suggestions
Throttle Body Cleaning ! - pics
cleaning the iac
cleaning throttle body
2002 Audi S4
S4gunn is offline   Reply With Quote
Old 09-01-06, 02:02 PM   #9 (permalink)
morbo's Avatar
Car 1: I35 Sedan
I didn't even think of the trhottle body. Good call.
Old 09-05-06, 05:29 AM   #10 (permalink)
thanks for all the comments, i couldnt get back to you cause i was busy resoldering my main relay.... worked perfect!! One point had craked and arked, melting away the solder. quick solder job and that morning i was off to atlantic city.
also i did my headgasket 30k ago and scrubed every inch of my upper engine.
thanks again
Old 09-29-06, 02:19 AM   #11 (permalink)
Car 1: 91 Honda Legend (Base)
Car 2: 88 Honda Integra LS
Car 3: 89 Honda Integra LS
iTrader Score: 4 reviews
Send a message via AIM to onemanchan82 Send a message via MSN to onemanchan82 Send a message via Yahoo to onemanchan82
i have the problem right now....
i don't heard my main relay clicking... replaced with 3 used main relay... still no start... i don't hear my fuel pump prime at all... if the fuel pump is bad, would i still be able to hear the main relay click?
JDM CONCEPT/
1989 Honda Integra LS
1991 Acura Integra LS-Special
1991 Honda Legend
1993 Infiniti J30
onemanchan82 is offline   Reply With Quote
Old 09-29-06, 03:44 AM   #12 (permalink)
Legend Anti-Christ
The Crowing's Avatar
Car 1: 1991 Legend Coupe LS
Car 2: 1984 Jaguar XJ6
iTrader Score: 16 reviews
If I were you, I'd do some poin around with a DVOM if you really think it's electrical. Pull up the wiring diagrams from the online service manual and try testing points where you think there's a problem. If you have a dvom, this is a free check that will tell you if it's electrical or not.
onemanchan82, love the sig. Where'd you find that panda? haha
The Crowing is offline   Reply With Quote
Old 09-29-06, 04:33 AM   #13 (permalink)
You're going to need to check the voltages at the terminals which connect to the main relay; you probably have a bad connection on the backside.
Mikey851 is offline   Reply With Quote
Old 09-29-06, 06:05 PM   #14 (permalink)
Charles
Car 1: 1991 Acura Legend LS
I tell you guys what...I own a 91 Acura Legend and my car did the same thing for couple of weeks...after going to this site...I checked the main fuel pump relay..and noticed that it wasn't getting the 4 clicks that it should get. I took off the dash under the stering wheel and unhooked the wiring harnesses and replaced them. It fired up right away. It cost $80 with tax and it's easy to replace yourself. Follow the info on this site it will save you money!!!
ccasteel1 is offline   Reply With Quote
Old 09-29-06, 07:21 PM   #15 (permalink)
Queens Legend
Mike813's Avatar
Car 1: 1994 Acura Legend Type II Coupe (Sold)
Car 2: 2006 Civic EX Sedan
Car 3: 2002 Lexus GS300
Send a message via AIM to Mike813
i recently had the same problem, i thought it was the relay so i went to the acura dealer in jackson heights got a relay for 90$ and change... turns out it wasnt it... it was the plug to my fuel pump which had a loose connection, but since my car was already opened up i changed the fuel pump anyway... it cost almost 100$ for the part from autozone. it was a bosch one i believe..
Mike813 is offline   Reply With Quote
PGMFI Main Relay Removal MikeD DIYs 32 04-28-13 07:27 PM
Replaced Main Relay - again, still won't start???? jkr Second Generation Legend (1991-1995) 5 12-10-05 02:36 PM
Main Relay, Fuel Pump, or something else... MTZ First Generation Legend (1986-1990) 25 02-28-05 05:58 PM
Location of Main Relay?? thangqdo First Generation Legend (1986-1990) 12 06-26-04 10:30 AM
Main Fuel Relay jewelerz Second Generation Legend (1991-1995) 1 07-09-02 01:27 AM
