Old 10-21-04, 04:27 PM   #1 (permalink)
Car 1: 91 Acura Legend LS BLACK/BLACK,GOLD PACKAGE
Send a message via AIM to PETEROCK29 Send a message via Yahoo to PETEROCK29
blown shock i thought;new shock put in and still as low as before,helpppppppp
ok boys,i have a serious problem here.my car on the front drivers side is really low.like i have less than an inch of clearance and my tire rubs when i turn the wheel to make turns,so i havent been driving it.i figured my shock is blown.so here we go i buy some shocks from a coupe and me and my bro-in-law put them in,which was a huge painnnnnn.(words dont do it justice).we put evrything back,bolt everything back up and the car is still as low as before.now we just wasted 8 hours killing ourselves to change this shock for nothing. has anyone had this problem before and what was wrong??any help here boys would b greatly appreciated.im stuck because i cant drive my car now.so please helppppppp
PETEROCK29 is offline
Old 10-21-04, 10:40 PM   #2 (permalink)
RAP
Car 1: '95 Legend 3 ea. 240SX
A shock is for shocks suffered when you drive too fast through potholes for instance.
The shocks do not support the car in any way, the springs do. You state that you bought some shocks from a " coupe ". Did you buy the whole strut assembly, shock and spring? There may be diffference in the spring length.
A simple check for a shock is to press down hard on the fender and release. If the shocks are bad/weak the car will bounce three or four times springy like as opposed to one bounce if the shocks are good. I can detect a car with bad shocks by observing, usually older cars, going down bad streets and seeing them bounce continously. Kinda funny.
The service manual does not discuss your problem either so maybe some of the guys that lower their cars will chime in with some suggestions and/or what could be wrong.
Best I can do without seeing the car.
RAP
Acurite
RAP is offline
Old 10-21-04, 11:38 PM   #3 (permalink)
PSA
Drive slowly, and stop by so I can look at it.
PSA
PSA is offline
Old 10-22-04, 01:42 AM   #4 (permalink)
Ack-Crawler's Avatar
Car 1: 1995 Sherwood Green LS Coupe
Car 2: 2003 Cadillac DTS
Car 3: 1965 Buick LeSabre
Spring sag maybe... Before I went with Ground Control & Koni Setup, I had the eibach & Koni setup.. Over time my front drivers side became lower than all other parts of the car due to spring sag... I resolved it by buying an adjustable ground control suspension.. So now if my ground control ebiach springs start to sag I can just raise the height of the spring perch to compensate for the sagging spring... I have been having the Ground Control's on for about 3 years now, and I haven't noticed any ride height change. So maybe the Ground COntrols won't sag..
DFW Meet Video
Ack-Crawler is offline
Old 10-22-04, 05:41 AM   #5 (permalink)
FIXER
My front left tire started rubbing and it turned out to be the inner fender well liner was loose and sagging.
Jetdoc is offline
Old 10-22-04, 11:14 AM   #6 (permalink)
oh boyyyy
NO it isnt the fender or liner sagging.my tire is has like an inch clearance from the top of my fender.and i just put in a new coupe shock.and the coupe shocks are actually a little taller (maybe a 1/4 inch)than the 4 door ones.im stumped boys,im goin to bring it into a mechanic and see how much hes gonna bea t me in the head for the work. thanx again boys,keep the advice coming,i really do appreciate it.
Old 10-22-04, 11:32 AM   #7 (permalink)
Car 1: 1991 Cobalt Blue KA8
Car 2: 1998 Kouki (sold)
Send a message via AIM to Gerald
Buy a front Koni red from www.tirerack.com, put the spring on the highest perch, and you'll be set. HTH
http://img.photobucket.com/albums/v502/acura_lover_85/Best-Night-Pic23again.jpg
Help Me Find White/Black KA8
Gerald is offline
Old 10-22-04, 12:34 PM   #8 (permalink)
Car 1: 90 legend LS coupe
As was already stated, the spring is what gives your car its height, not the shock.
Bobster is offline
Old 10-22-04, 11:20 PM   #9 (permalink)
PSA
As I said before, call me. 610-923-9670.
PSA
PSA is offline
Old 10-23-04, 12:19 AM   #10 (permalink)
Car 1: Gynomobile
I think you need to understand the mechanics of a car before tinkering with it. It'll save you time and $$$.
As couple people stated before, it doesn't matter what kind of shocks you have, blown, new, longer, shorter, your ride height will ALWAYS be the same.
I can get my brand new shocks, drain it of alllllll the oil, cut the rod in half, and it will still sit at the same height.
Springs and/or spring lower perch location is what changes your height. Obviously it's not your spring perch height that is changing, so it leaves you with 1 clue..... DING DING DING!!!! OLD saggy springs!!
RIMTUCK.com - Wheel fitment database
Volk Racing is offline
Old 10-23-04, 02:47 AM   #11 (permalink)
Car 1: 1992 Legend L Seattle Silver Metallic 144k miles
Shocks? I thought we had struts?
I thought we had 4 wheel struts on the Legends...not shocks.
1992 Legend L
Exterior: Seattle Silver Metallic
Interior: Taupe, Leather
4 Speed Automatic
146k miles
2nd owner (parents bought it new)
12 disc CD player
No mods & everything works!
92Legend142k is offline
Old 10-23-04, 02:49 AM   #12 (permalink)
Car 1: Gynomobile
DOH!!! 2nd time I got 0wn3d on that one.
Old 10-23-04, 02:56 AM   #13 (permalink)
Avarice's Avatar
Car 1: 2001 VW Jetta 1.8T WE
Car 2: 2002 Honda S2000
Contact PSA he's an Acura Tech.....and he's in Easton PA
[img]
My 1991 Legend (SOLD)
Sedan Type-F floor mats
Driver Side seat (free)
OE + Denso Filters for cheap
Throttle Body
TL Engine Cover
Avarice is offline
