car won't crank nor start!!!!! - The Acura Legend & Acura RL Forum
Old 12-22-09, 04:20 PM   #1 (permalink)
Car 1: 92 CB7
Car 2: 94 Acura Legend
Exclamation car won't crank nor start!!!!!
i tried looking on every forum and nothing no results from anyone, my car was driving fine 2 days ago, but today, the car turns on fine but it won't crank nor start i don't know whats wrong with it, it won't even TRY to crank at least. need of help!
DipInSauce is offline   Reply With Quote
Old 12-22-09, 04:32 PM   #2 (permalink)
Old School's Avatar
Car 1: Kat - '95 KA8 T2 LS
Car 2: Jade - '95 KA7 T2 GS
Car 3: '87 KA3 LS - Donated
iTrader Score: 4 reviews
These might be your issues:
Main relay
igniter
engine grounds
injectors
timing belt
fuel pump/filter
air filter
Cam/crank position sensor
Ignition switch
Here is a link that may help you diagnose your issue. Happy reading...
Does your Legend crank but does not start? Here's a DIY diagnostic procedure
Old 12-22-09, 05:08 PM   #3 (permalink)
Car 1: 92 CB7
i've check that link many times even before i posted this and done almost all, still nothing........help
Old 12-22-09, 05:36 PM   #4 (permalink)
Car 1: 92 CB7
could it be the alternator or starter?
Old 12-22-09, 05:54 PM   #5 (permalink)
Old School's Avatar
"the car turns on fine but it won't crank nor start"? Do the starter even turn over? or do you just hear a click?
Here is another link on how to troubleshoot the ignition.
http://techautorepairs.com/ignition.html
Old 12-22-09, 07:19 PM   #6 (permalink)
Car 1: Honda Legend KA7
If it's not cranking, the ignition is not the cause for your problem.
1. Is the battery charged? Turn on the headlights. Are they staying bright when the starter motor is activated?
2. Is the switch plate on the ignition switch in good condition? If the contact is burnt, the +12V main supply will not be switched on, so the starter motor will not crank the engine.
3. Is the switches +12V supply present (blower motor is working, clock is turned on)? If this is all right, you could bridge +12V battery to +12V magnetic contactor at the starter motor. Make sure the tranny is in neutral and the ignition is on. Be careful with moving parts! Does the engine start?
Daniel_S is offline   Reply With Quote
Old 12-23-09, 07:51 PM   #7 (permalink)
LEGENDARY93's Avatar
Car 1: 1993 Acura Legend
I just recently had the same problem. I notcied that my battery clamps were a little old n rusted looking so i went and bought some gold plated clamps from kragen and havent had a problem since. Make sure all your battery connections are clean and tight. You might also try getting a battery with higher cranking amps. (Hope this helps.)
LEGENDARY93 is offline   Reply With Quote
Old 07-23-10, 12:17 AM   #8 (permalink)
Car 1: 1992 Acura Legend sedan
Send a message via AIM to david7700 Send a message via Yahoo to david7700
This was my problem until I replaced battery cables and narrowed it down to the starter. Signs of it failing were:
- slow turning over
- intermittent failure
- single clicking (sounded like it was in the dash by maintainence keyhole) at first, then
- rapid clicking ( sound came from engine area right by starter)
- finally.. Sparks would shoot out of the starter solenoid, but somehow it still started one last time to avoid a tow.
Legend .. what!
david7700 is offline   Reply With Quote
Old 07-24-10, 02:13 PM   #9 (permalink)
Car 1: 1991 Legend L Sedan Wrecked!
Car 2: 95 Legend "L" Sedan
If the battery is ok my bet would be the starter/solenoid.
91boz
91boz is offline   Reply With Quote
Old 08-06-12, 12:49 AM   #10 (permalink)
Car 1: 1995 Acura Legend
1995 Acura Legend won't turn over
I recently had a no start issue where the car would occassionally turn over but would not start. It ended up being the main relay, replaced it and it's been starting great for a week. Today, I drove about 40 miles to a friends shut off the car, went to leave and nothing happens when you turn the key.
All the normal lights come on, are bright, and I can hear the fuel pump engaging for a few seconds, but you turn the key and absolutely nothing turns over it all.
I've pretty much got it narrowed down to either the starter/solenoid or the ignition switch. Any input or guidance on how to determine the problem would be greatly appreciated.
Thank you!
awhirley is offline   Reply With Quote
Old 10-02-14, 10:46 AM   #11 (permalink)
Car 1: Acura Legend Coupe LS
My 93 Coupe is doing the exact same Thing
Thank you!
Hey did you or anyone else figure this out because I'm experiencing the exact same thing with my 93 coupe. ANY HELP WOULD BE GREATLY APPRECIATED!!!!!!
acharlie37 is offline   Reply With Quote
Old 10-06-14, 07:32 AM   #12 (permalink)
Car 1: 1991 LS Sedan
Car 2: 1994 Coupe 6speed
Send a message via Yahoo to tstint16
Smile
Did you check the wire coming from your starter to the alternator that could have caused the problem. I changed out my alternator this past weekend and after it was installed the car wouldn't start come to find out its was that wire. After 20 years it had gotten brittle and came loose with the slightest touch. Installed a new wire and she started up with no problems.
tstint16 is offline   Reply With Quote
