» Sponsors
» Sponsors
Old 04-26-08, 08:49 PM   #1 (permalink)
Insert key, crank, BHG.
Pinyix's Avatar
Car 1: '92 LS "December"
Car 2: 6MT Canterbury Coupe
Cluster/Speedo Replacement DIY
Please read through this entire DIY before beginning.
This DIY will cover the nuts and bolts removing and replacing your cluster and swapping gauges between clusters. It may also be useful for installing glow gauges but that won't specifically be covered here. For those of you upgrading gauges, I encourage you to swap them out into your original cluster since you then won't have to worry about a different odometer mileage, the possibility of burnt out lights, the number of doors on the indicator(coupes have two door indicators and sedans four) or the presence or lack of the automatic light tree. Also, I'm not certain if this car has its speed calibrated in the cluster or else ware but I can say with GPS certainty that my speed is 100% accurate using the original cluster base. With that out of the way,
Heres what you'll need:
Small Flat Head Screwdriver
Large Phillips Head Screwdriver
This will take about an hour.
First we're going to remove the panel under the steering wheel. First get your small flat head screw driver under this panel in the slit and gently pry it out.
When reinstalling this screw, don't tighten too hard as you're screwing into a plastic tab.
Now remove the screw as pictured below and place the panel you just removed half way back so not to get in the way.
Now remove the screw at the back right of the panel then the screw behind the hood release:
The panel is now hanging on by a clip behind the ignition. Its a little tough to get off but with a bit of muscle pulling towards you it will pop right off. To better understand how to pry, here are pictures of how its situated:
Now we need to do what we took that panel off to get to: remove the two screws securing the cluster bezel. Mine are technically not present as pictured as they are not needed to keep the bezel in place but their screw holes are circled in red in the below two pictures:
This ignition side screw can be a bit difficult to find but with a flashlight, you'll find its the only phillips head screw up there to be removed.
Now you're going to want to telescope your steering wheel all the way towards you. This should be self-explanitory, but I have a photo of it and I went through the trouble of marking it, so heres how you do it if you're genuinely lost(hope I don't confuse people with them new fangled electronic tilt/telescoping wheels):
You can now remove the cluster bezel. There are two small clips holding the top in place so pull right at the top until they pop out then pull the bezel straight out. Be sure to remove the two connectors on the right and one on the left before fully yanking the bezel out of the way.
Now we can remove the four screws securing the cluster, two on each side. Be careful not to drop the screws into the cavity:
Now before we yank the cluster out, we have to remove four harnesses from the cluster. Three on top, one on bottom. Heres the bottom:
Two on the top right:
And one on the top left:
The to connectors can be a bit tricky so take your time. Your small flat head screw driver may be helpful in getting at the releases and prying the harnesses out. Remember: Patience.
From now on, there is no reason to muscle anything. Tip the cluster all the way forward and gently wiggle it out. Be mindful of the trip reset button and the clear plastic clips on the bottom.
And thats it. You can slide it out to the left or right. On to disassembling the cluster. First we need to pull the clear plastic off the top. On the end of the trip reset button, theres a tiny tip. Pull this off. Now remove the light in back with the wire leading to the top of the cluster and then press in these three clips on top and four on bottom:
The top pulls off and now you can pull the face plate off:
The gauges are fragile so be careful how you situate the cluster while remove and reinstalling the gauges. There are three screws per gauge on the back of the cluster. Red for the temp gauge, blue for the tach, green for the speedo and yellow for the fuel gauge:
Take each set of screws out one at a time holding the gauge with your hand on the other side so it doesn't spill out. Once the screws are out, the gauges lift out no problem and you can put in the gauge of your taste.
Reinstalling all of this is essentially the reverse of the removal. When placing the cluster back in its cavity, place the wire harnesses on top of the cluster so they don't get buried behind everything once its situated. Don't forget to plug in all four wire harnesses either. Don't forget about the one screw that screws into the plastic tab... be gentle. Finally, when you get everything back together, try not to stare at your speedo too intently. Having gone from grandma gauges to modern 140s then again to 160s, I understand how distracting something so involved in the function of your driving can be, but please don't crash your car over it.
Enjoy!
.:JDM/EDM Non-Navi DIY:.
.:JDM Navi Console DIY:.
Pinyix is offline
Old 04-26-08, 09:06 PM   #2 (permalink)
AZpartsGuy
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1998 Civic EX
Car 3: 95 ZX-7
Nice pics and write up. Guess I should have done some picture taking today too, as I just pulled another dash out and pulled the above too.
or http://phoenix.craigslist.org/evl/pts/1617199221.html
ari_one is offline
Old 04-26-08, 10:11 PM   #3 (permalink)
ptan1968's Avatar
Car 1: 94 Blk/Blk Legend GS
Car 2: 07 Sienna Limited
Excellent write up with very good details and pics. This will help out a lot of newbies sometime ask such simple questions about how to change bulbs in the cluster gauge involving removal cluster, yup, those hidden Phillips screws are a bit tricky if not aware
ptan1968 is offline
Old 04-26-08, 10:20 PM   #4 (permalink)
Pinyix's Avatar
It never hurts
A write up like this was invaluable to me not so long ago. Recently the pictures went bad on it though so I decided to write up a new one. I love giving back to the community. I owe a lot to this place.
Pinyix is offline
Old 05-21-08, 10:47 AM   #5 (permalink)
Why So Serious???
-=DBS=-'s Avatar
Car 1: 1988 Acura Legend Coupe (BMW Alpine White) 5pd
Car 2: 91 Legend Coupe
Send a message via ICQ to -=DBS=- Send a message via MSN to -=DBS=-
Nice Post!
This will def help me when i need to take out the cluster to change the gauges!
Thank you for the pics and steps!
-=DBS=- is offline
Old 05-21-08, 10:54 AM   #6 (permalink)
TonyTheBullet's Avatar
Car 1: 1998 4Runner SR5 3RZFE
Car 2: 1993 Legend LS Coupe
Car 3: 1992 Legend LS Sedan
I love you dude!...err I mean thanks a lot, I was looking for this
TonyTheBullet is offline
Old 08-25-08, 06:27 PM   #7 (permalink)
mods: yes PLEASE!!!!
bboarder711's Avatar
Car 1: 1995 SE white/silver
Car 2: Flexdex Pro 36
Car 3: Nikon D300, D70
one of your green circles is off. all three screws look the same
http://www.legendaryphotos.net <-- CLICK FOR NALM PICS
Final Edited NALM Pis are UP!!!
Legendary Special:
$10 for up to 25 Digital files
$25 for 1 8 x 10 Print
Email me at Rich@legendaryphotos.net for details and a contact sheet.
A-L.com T-shirts + Hoodies for sale! <-- Click
bboarder711 is offline
Old 08-25-08, 06:38 PM   #8 (permalink)
Hey! NIce writeup!
LegendLand is offline
Old 08-25-08, 07:45 PM   #9 (permalink)
Pinyix's Avatar
Good catch, fixed
Pinyix is offline
Old 08-25-08, 10:37 PM   #10 (permalink)
Ouda147's Avatar
Car 1: 95 LS KA7
Car 2: 94 LS KA8
Car 3: 05 Chevy T'blz
Send a message via Yahoo to Ouda147
Thank you for this write up, I do have a question: Once you install the new cluster, will it automatically conform to the gas levels that you have? Do you have to do any calibrating or is it just plug and play?
Ouda147 is offline
Old 08-25-08, 10:41 PM   #11 (permalink)
NBP...
Car 1: 91 Legend LS Coupe 6MT, Black on Black
Car 2: 2008 Acura TL-S 6MT
Send a message via Yahoo to Russian
Plug and play, the needle will automatically conform to the gas level you have.
Russian is offline
Old 08-25-08, 10:53 PM   #12 (permalink)
Ouda147's Avatar
Car 1: 95 LS KA7
Car 2: 94 LS KA8
Thank man i REALLY appreciate your help! GL on the sales!
Ouda147 is offline
Old 08-26-08, 09:02 AM   #13 (permalink)
its so scary how simple this stuff is
Legendary Special:
Old 08-26-08, 09:18 AM   #14 (permalink)
Pinyix's Avatar
Easy is hard. A team of people spent a lot of time making sure all these components go in and out with ease. What really amazes me is how no screws are visible from the interior yet its still easy to peal your car away prying in the right places.
Pinyix is offline
Old 08-26-08, 10:45 AM   #15 (permalink)
yea with the removal of 2 visable screws the entire center consol can come out
Legendary Special:
