Clutch Fork Problem - The Acura Legend & Acura RL Forum
Old 05-23-10, 01:32 PM   #1 (permalink)
Car 1: 1996 Honda Civic
Car 2: 1991 Acura Legend
Clutch Fork Problem
I just got done replacing the clutch on my friend's '91 Legend. We got the transmission back into the car with all the mounts in and all of the mounting bolts in but are running into a problem with the clutch fork. The fork is stuck down under the pivoting/mounting bracket and no matter what way I angle or pull or squeeze, I can't get it back up so that I can get it into the bracket. Am I doing something wrong here? Is there a good way of getting it up around the bracket without removing the whole transmission again? Thank you ahead of time.
hemix is offline   Reply With Quote
Old 05-23-10, 05:37 PM   #2 (permalink)
BIGBOY's Avatar
Car 1: 94 acura legend ls
Acura Legend Online Service Manual (Page: 0314)
Old 05-23-10, 07:43 PM   #3 (permalink)
I have been using the Helms manual throughout the process. I have actually already installed the new clutch and pressure plate and gotten the transmission back in the car. I am having problems with getting the clutch fork onto the pivoting point because it is stuck below the bracket. Unfortunately, all the manual says about the clutch fork is "Install the release fork". I guess I was hoping that someone else has run into the same issue I am having and found a way around it other than removing the transmission and trying again.
Old 05-23-10, 08:51 PM   #4 (permalink)
BIGBOY's Avatar
wish I could help more but my knowledge is limited when it comes to manual transmissions and as you said it doesn't cover your issue. I'm sure Mike D or somebody else will chime in with more experience with manual transmissions.
Old 05-24-10, 07:45 PM   #5 (permalink)
I ended up just unbolting the mounts and backing out the housing bolts about half an inch which allowed me to separate the transmission and pressure plate enough to get the fork up to the pivoting point.
Old 05-24-10, 08:13 PM   #6 (permalink)
Car 1: 1998 Honda Prelude Type-SH
Car 2: 2007 Acura TL Navi
See. It wasn't so hard afterall.
BDoggPrelude is offline   Reply With Quote
Old 05-24-10, 08:15 PM   #7 (permalink)
BIGBOY's Avatar
glad it worked out for you and now I know what to tell any body who runs into your issue.
Old 12-23-12, 10:28 AM   #8 (permalink)
Car 1: 92 legend
I just installed a new slave cylinder and when I was bleeding the clutch the fork came loose , so am I going to have to do what you did or is there another way to reset it
barryljones is offline   Reply With Quote
Old 12-23-12, 12:56 PM   #9 (permalink)
Another 3.5er
Car 1: Gold '95 G2 Acura Legend L Sedan
Send a message via Yahoo to JonsLegend
Unbolt the slave cylinder. And reinstall the clutch fork
a 3.5 hybrid 6 speed by the end of this week...
[SIGPIC][/SIGPIC]
JonsLegend is online now   Reply With Quote
