Collapsed radiator hoses? - The Acura Legend & Acura RL Forum
Old 11-02-07, 07:56 PM   #1 (permalink)
Jettin169's Avatar
Car 1: 1993 Acura Legend LS Sedan
Car 2: 1997 Acura Integra R
Question Collapsed radiator hoses?
Ok... so here's a new question for any experts out here.
I've been fooling around my Legends engine the last week or so to make sure everything will remain running smoothly over the winter.
1) I "Gunked" the crankcase clean
2) I "flushed" the entire cooling system with a bottle of Prestone cooling system cleaner. I used the T-flush to make sure I got all the old antifreeze and cleaner out.
3) I replaced the thermostat with OEM and replaced all the radiator hoses.
.... (The radiator was replaced about 6 mo. ago.)
4)I've also bled the system a few consecutive times trying to remove any air from the system.
I haven't really driven it anywhere since except a couple miles. I noticed the temp rise about 3/4 on the gauge while idling it in the driveway. I looked in the engine bay and noticed both upper and lower radiator hoses were sucked flat and my overflow bottle was running over?
Now, I know that a BHG will pressurize a system and run the overflow over, but it seams, in this case, the radiator is becoming empty and all of the returning coolant is being pushed into the overflow.
Any ideas on what could be going on? Would a bad radiator cap cause this
Jettin169 is offline   Reply With Quote
Old 11-02-07, 08:08 PM   #2 (permalink)
MagicMikey's Avatar
Car 1: '91 LS Sedan
Send a message via MSN to MagicMikey
I'm no expert but it's written in stone to use ONLY Honda coolant in the cooling system. All other brands risk damaging the system. Let's hope it's not that!
1991 Acura Legend LS Sedan
Granada Black
MagicMikey is offline   Reply With Quote
Old 11-02-07, 10:04 PM   #3 (permalink)
AZpartsGuy
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1998 Civic EX
Car 3: 95 ZX-7
iTrader Score: 63 reviews
When you filled it, did you have the hot/cold lever on hot and have the radiator cap off so that you could keep filling as the coolant circulated? Then after that you bled it right?
Old 11-02-07, 10:11 PM   #4 (permalink)
Jettin169's Avatar
This is correct... I had the heat on high.
04' TL 17's
New Alpine White paint
Collapsed Hose from radiator to engine?!? crikfromcincy Second Generation Legend (1991-1995) 16 09-11-05 01:37 AM
OEM radiator hoses doesn't fit ????? LV_legend Second Generation Legend (1991-1995) 10 06-26-05 03:43 PM
why was my radiator hose collapsed? thekitt Second Generation Legend (1991-1995) 8 03-11-04 01:16 AM
Radiator hoses diagram dzeinn First Generation Legend (1986-1990) 6 11-27-03 10:20 AM
aftermarket radiator hoses? bootleg Engine & Performance Modifications 1 05-04-03 07:22 PM
