coolant drain plug - The Acura Legend & Acura RL Forum
Old 01-14-08, 11:02 AM   #1 (permalink)
Black Type II's Avatar
Car 1: Carless
coolant drain plug
does anyone have a pic of the coolant drain plug? im sure if i get under the car ill be able to find it but i dont want to drag myself all over the wet ground to look for it. the pic in the helms manual only shows the bleeder screww
1995 Milano Red LS 6SPD where are you?
Black Type II is offline   Reply With Quote
Old 01-14-08, 11:16 AM   #2 (permalink)
94legendcpe's Avatar
iTrader Score: 18 reviews
No pic but its about level with the far left side of the drivers side headlight. Just follow that straight down (I had the bumper off) and its directly underneath. Also, don't torque the crap out of it when you re-tighten or you'll have to back it off about a half turn to get it to stop seeping.
94legendcpe is offline   Reply With Quote
Old 01-14-08, 11:18 AM   #3 (permalink)
Check this DIY for the pics, the pics of the plug were taken from the drivers side looking towards the passenger side.
DIY - Thermostat
Old 01-14-08, 12:07 PM   #4 (permalink)
Car 1: 91 LS Coupe
Car 2: 95 LS Coupe n/run
Car 3: Previous 89' L Coupe
It's on the drivers side. It's like a wing nut. You should be able to remove it by hand and you definetly want to tighten it by hand. Just about the easiest thing to do in this car.
manxdr21 is offline   Reply With Quote
Old 01-14-08, 04:12 PM   #5 (permalink)
Car 1: Carless
thanks guys
Old 01-14-08, 08:05 PM   #6 (permalink)
MAD DOG!
dgandul's Avatar
Car 1: 97 honda prelude
Car 2: 92 LEGEND LS
im pretty sure you have to take off that plastic shield....
dgandul is offline   Reply With Quote
Old 01-14-08, 10:52 PM   #7 (permalink)
Car 1: Carless
yea i just realized that once u said it but at the moment my bumper comes off once i loosen the bolt in the middle
Oil Drain Plug? MidgetWarrior Second Generation Legend (1991-1995) 42 11-11-08 12:35 PM
Where is the drain plug for coolant?... hotshot_cp Second Generation Legend (1991-1995) 5 08-10-06 07:52 AM
Coolant drain plug on engine block alleged First Generation Legend (1986-1990) 1 09-07-05 11:21 PM
engine block coolant drain plug? drk9ght Second Generation Legend (1991-1995) 17 10-18-04 09:40 AM
leaking coolant around radiator drain plug 90CoupefromCanada First Generation Legend (1986-1990) 4 06-16-03 12:03 AM
